Old 09-16-2015, 10:31 PM   #15
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Originally Posted by khell86 View Post
I dont know if they can drop the price on a Z28 replacement. Look at the increase in price we're seeing with the SS. This new Alpha platform, while light, is expensive. Margins are already low for GM. I think we're going to see some pretty expensive Hi-PO models for the camaro. After seeing this weight loss though, i'm sure they can match the weight.
The ls7 and the suspension was the big priec tag items of the last z28. This car wouldn't have those so it could drop while offering a better package.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 09-16-2015, 11:51 PM   #16
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
The Z/28 eliminates the creature comforts. A lot would go, and chop off weight and cost.
Sledgehammer70 is offline   Reply With Quote
Old 09-17-2015, 01:35 AM   #17
crysalis_01
Iron fist, lead foot
crysalis_01's Avatar
Drives: 2003 Mustang Cobra
Development of a NA LS7 replacement would cost a bit. Also, developing a Z/28 worthy suspension that's a noticable step up from the SS, which looks to be already awesome, wouldn't be all that cheap.
Removing content tends to add to product cost As the assembly lines aren't necessarily designed to do this. Usually it goes to a sort of niche line for that. Added labor equals added cost.
crysalis_01 is offline   Reply With Quote
Old 09-17-2015, 01:46 AM   #18
Sledgehammer70
Lethal Camaro
Keep in mind they have a lot of things they can take from the Caddy big bad V that they have already spent cycles and dollars on. They also already have the stripped down interior... it's a 1LT. Simply remove more speakers and a few other odds and ends and they are good to go.
Old 09-17-2015, 02:09 AM   #19
Sledgehammer70
Lethal Camaro
Speaking of Caddy's.... Added the CTS-V and ATS-V along with making misc edits and adjustments from comments above.
Old 09-17-2015, 10:55 AM   #20
khell86
Drives: 2012 Ford Focus
Theres not much more to use on the Camaro though. It already has MRS as an option. The only suspension better is the DSSV that the z/28 already uses. Same thing for the breaks. I dont know if the CCB's are used on the CTS-V, but if they are that might drop the price of those some. But like crysalis said, its usually more expensive to remove options, like the rear seat and what not.
khell86 is offline   Reply With Quote
Old 09-17-2015, 11:16 AM   #21
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
Neat, can you add a column calculating price per horsepower (=H/I) and a column calculating weight per horsepower (=C/I).
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 09-17-2015, 01:22 PM   #22
Sledgehammer70
Lethal Camaro
Updated:
Added Dollar per HP, Dollar per Torque and lbs per HP.
Old 09-17-2015, 01:49 PM   #23
joemosfet
joemosfet's Avatar
Awesome!
I made a couple of charts based on the data you've collected:
Old 09-17-2015, 02:11 PM   #24
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
For model year 2015 the challenger hellcat and rt weights are as follow. Hellcat is at 4449 https://www.google.com/#q=2015+chall...hellcat+weight, and the RT is at 3834 pounds https://www.google.com/#q=2015+challenger+weight
RenegadeSS is offline   Reply With Quote
Old 09-17-2015, 02:41 PM   #25
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Pretty sure the 3834lbs is the V6, not RT.
Old 09-22-2015, 01:27 AM   #26
Sledgehammer70
Lethal Camaro
Originally Posted by joemosfet View Post
Awesome!
Fairly cool to see all the data. Can't wait for Oct 16th to update the 16 Camaro numbers.
No word on when we will see real GT350 and GT350R numbers.
Old 09-22-2015, 07:38 PM   #27
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I will give you a A for effort but there are way too many variables to account for when trying to compare all those cars and then picking and choosing the test results. The closest fair comparison that you could do is just use MT's best recorded data for each car. Last I checked MT was still DA correcting its times and if you used the best times, from one publication, who DA corrects, it would be as fair as it could get without a head to head. I would suggest posting trans type for each result as well. I'm not going to call them out but I see some poor results from some cars and cherry picked results from others. That's because of different drivers, on different days, on different tracks, in different conditions.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
