Old 08-29-2015, 10:19 AM   #15
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
The manual cars still need a bump in rear gear to cross the traps around redline.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 08-29-2015, 11:17 AM   #16
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
It will be faster than the M6.
Old 08-29-2015, 11:39 AM   #17
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
As others have said, with the 8 speeds and super short 1st and second gear, the rear end ratio doesn't have to be 3.73. The gears in the auto compensate for it.
Yes it will. I'm very curious to see how much faster. I wonder if it'll be as dramatic as the 8 speed auto Hellcat vs. the manual Hellcat.
Blackdevil77 is offline   Reply With Quote
Old 08-29-2015, 12:23 PM   #18
SpeedIsLife
Drives: Current Camaro-less
I've driven a A8 Scat Pack and I assure you...taller final drive ratios are quickly are easily negated with how aggressively geared that transmission is.
With the automatic the new Camaro is going to pull like crazy out of the hole and up top
Old 08-29-2015, 12:49 PM   #19
GearheadSS
GearheadSS's Avatar
Probably not. In the ATS-V, it's pretty close but the 8 spd auto is faster.
Old 08-29-2015, 01:11 PM   #20
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
See this post comparing the M7 vs A8 Stingray acceleration. I'd expect the M6 vs A8 Camaro SS will be similar.
http://www.camaro6.com/forums/showpo...0&postcount=37
Old 08-29-2015, 01:16 PM   #21
Blackdevil77
Excellent! I wanted a manual anyway, I don't feel as bad about getting the stick now lol.
Old 08-29-2015, 01:21 PM   #22
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Don't, at all.
Unless the same pro is racing both cars on the same track at the same day, the times between the manual and auto are close enough where it's a drivers race every time.
It'll come down to do you wanna row your own, or let the car do it's thing.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 08-29-2015, 01:33 PM   #23
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
Originally Posted by cyberbro View Post
AutoTrans comes w/ rear axle, 2.77 ratio
Gas mileage move? not going to be very aggressive with that.
My 2006 C6 Corvette had that ratio and it ran right at 11.99 with bolt ons. Never had any trouble launching and it was fun to beat most Mustangs and all of the Dodge Hemis. The auto's transmission gear ratios made it very competitive with the manual transmission C6s with 3:42s or whatever they are.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 08-29-2015, 01:41 PM   #24
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
I'm wondering if the new SS (auto) could pull off a 4 second 0 to 60 based on this (C7 run)? more likely 4.2 ish I would guess
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 08-29-2015, 02:02 PM   #25
SpeedIsLife
If a 4200lb Challenger can do it in 4.5 I'm sure a Camaro that is 400 lbs less can do it in about 4.2
Old 08-29-2015, 06:46 PM   #26
NASTY99Z28
Originally Posted by Curr View Post
Don't, at all.
Not true. A pro could come close to the same times but an average driver would have a hard time post times within a few tenths of each other. Most people struggle with launching a high powered car on stock tires. Autos are very easy and anyone can simply smash the pedal. Plus the manual car will need gears to be in the proper rpm in 4th.
Old 08-29-2015, 07:16 PM   #27
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Don't, at all.
Half a sec in the 1/4 is a driver's race (in the ATS-V tests)? That's about 5 car lengths. That's a pretty big margin. I can see a couple of tenths, but the manual driver is by the most likely to screw up. Anything is possible but to me a driver's race is a much smaller margin.
Old 08-29-2015, 08:57 PM   #28
vtirocz
vtirocz's Avatar
I think he was basing that on the Stingray auto vs manual comparison where there's only a 0.2s difference in the 1/4 and all of that was in the launch (0-30). After 30 the manual was just as fast or faster.
I think the auto shows a bigger difference on the ats-v since it would allow the turbo to get spooled up at launch. With the lt1, as seen on the vette, the difference will be smaller between the two trans options.
