#15 |
![]() Drives: 98 camaro turbo Join Date: Nov 2009
Mid 12's makes sense but i think a 3.9 0-60 is also a possibility.
#16 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#17 |
![]() Drives: 2006 Honda accord v6 6sp manual Join Date: Apr 2015
I am with you on the 8 speed auto as I am sure it will be quicker than the 7 speed manual, I am a row your own kind of guy,
There is something about shifting into second and leaving a couple of stripes that is intoxicating |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Subtract around a half second from everything the 5th gen has done in the quarter mile stock or modded and that will be pretty close to how the 6th gen will perform respectively. I know other areas besides power and weight play a role but the 6th should be on par or better in these other areas such as gearing, traction, power curve and aerodynamics. It's gaining ~ 30 hp and losing ~200 lb. and don't forget now we don't have a neutered engine for the auto and it will have a nice 8 speed.
Therefore mag times will be in the mid 12 range. Hero time someone may crack into the 11s with the auto...with the stick I doubt it. 0-60 doesn't matter to me it's a test of traction and driver skill more than anything. Not enough distance to prove much no one races to 60 and shuts down lol... At least I never have. It matters but the 1/4 will tell the whole story. But it should be low 4s. The numbers im thinking it will show is what I was expecting from the camaro in 2010. My car felt slow to me stock. My 98 ls1 would run right with it stock for stock. Last edited by ULTRAZLS1; 04-19-2015 at 12:14 PM. |
#19 | |
145lb Powerlifter
Drives: 2013 Camaro 2SS RS LS3 Join Date: Jan 2014
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2ss Join Date: May 2013
#21 |
Agreed if a 4000lb+ Challenger can do it with 485hp, as long as we get the weight loss and 460hp.
#22 |
Challengers 392's put down around 420rwhp.
The lt1's also put down around 420rwhp. The is definitely going to be faster. My guess is that at the very least it should be a mid 12's car @ 114-115mph. Anything more than that would be icing on the cake!
#23 |
![]() Drives: 2005 Cobalt Base - 5 speed Join Date: Apr 2015
Just curious, where did you see that the LT1's put down 420 rwhp? The LT1 in the C7 is rated at 460 hp, so that would be a drive train loss of ~9%, which seems way too good to be true.
#24 |
![]() ![]() ![]() ![]() Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
#25 |
![]() ![]() ![]() ![]() Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
The c7 has gone 11.4's bone stock so add another 300lbs and I could see 11.9's in a perfect hero run. Low 12's should be the norm with good conditions and a lot of high 12's low 13's for those who can't drive. Let's not forget you now get an 8speed auto with mag ride so it should launch pretty hard.
I like my woman like my milk shakes, THICK!!!!
#26 |
Until all the official details are released yes I agree it's hopes and dreams. But if it comes in with the weight and power we are expecting I stand by my predictions. It's simple bench racing math looking at the improved power to weight and what other cars are running that are somewhat comparable.
#27 | |
415rwhp @ 12.5% is right at 475hp crank. Its dyno numbers so its not exact. The point is the new SS manual should plenty of potential to be the mid to low 12's. in otherwords.. faster than the stang! Ford better be working on a DI version of the 5.0 unless they're not going to be competitive. Wouldnt be surprised if Ford does a 2013 gt500 and tries to rain on gm's parade with a "release" on may 17th. Those punks at ford like to play dirty.
#28 |
I lol at all the under rating posts etc. dodge guys are the worst. Under rating ended around 2007 with the updated sae standard. The motors make within 1% of the rating witnessed by an independent engineer as well as one from the given company. Don't feel like finding links but under rating is a myth now...very easy to google it. Differing drivetrain efficiencies and dynos are the culprit for people believing this. No factory freaks either... Gm certifies every motor.
