Old 03-18-2015, 11:34 AM   #15
IOMike
Drives: 2022 F150, 87 Monte Carlo
The 7 speed, in my opinion, will stay Corvette. Would be nice to see the active rev match and no lift shift make its way to the Camaro though. To be honest, that's the only way I'd consider a manual. I didn't grow up driving them and find them to be annoying in any circumstance other than banging gears at WOT.
IOMike is offline   Reply With Quote
Old 03-18-2015, 12:41 PM   #16
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Originally Posted by SuperSound View Post
Same things got said when we went from 5spds to 6spds. People have to relearn.
why would you have to relearn on a 6spd? 1-5 all stay the same...
Old 03-18-2015, 12:48 PM   #17
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Originally Posted by ssmike View Post
It's all about MPG's these days!
While this maybe true....
In my opinioin, when your drving a muscle car, one would think that MPG isn't as big of a deal as true muscle. Now, this is why we have v6's that way you get a combination of both. To me, MPG isn't that important over HP. I guess if you can afford a 35+ car, you can afford 3.00 - 3.50 a gallon (currently).
oneredry is offline   Reply With Quote
Old 03-18-2015, 12:53 PM   #18
Z/284ever
Z/284ever's Avatar
Drives: A few Camaros
Another think to consider, a 7 speed trans weighs more than a 6 speed trans....
Z/284ever is offline   Reply With Quote
Old 03-18-2015, 01:01 PM   #19
PoorMansCamaro
Drives: Really Slow
going to have to get one of these, with 7 speeds...
Old 03-18-2015, 01:03 PM   #20
PoorMansCamaro
Drives: Really Slow
Car manufacturers aren't making muscle cars get better gas mileage because it's what people want. It's because of CAFE standards.
Old 03-18-2015, 01:09 PM   #21
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
False.. And True. Depends what you're comparing. TR6070 weighs less than the TR6060 I believe.. I guess they probably have a newer version of the 6 speed that weighs less though.. Idk.
ChefBorOzzy is offline   Reply With Quote
Old 03-18-2015, 01:20 PM   #22
Z/284ever
Z/284ever's Avatar
All things being equal.
Old 03-18-2015, 01:34 PM   #23
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
I'm sure the M7 will be in the new Camaro. I wouldn't mind the auto rev match feature because you can turn it on and off. I've read a lot about the M7 which mostly seems to get favorable reviews (including rev match)except for the tighter gates because of the additional gear which takes getting used to.
However, the A8 is quicker ET wise, lighter than the outgoing A6 (better mpg as well) and is more popular (and $$$). The only bad knock I've read on the A8 is it's not good for heavy track use (GM recommends the M7 for track use at least on the ZO6). That's related to cooling which might not affect the new Camaro because it might have better cooling. I guess we'll have to find out.
DrkPhx is offline   Reply With Quote
Old 03-18-2015, 01:37 PM   #24
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
People went from 3rd to 6th instead of 4th because they weren't used to another bottom gear on the right. I'm sure people missed 2 to 3 and went 2 to 5 when they first drove a 5 spd.
Old 03-18-2015, 01:47 PM   #25
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
I can confirm this statement. I learned on a CJ5 4 speed Jeep... and when I got my 91 YJ with the 5 speed I went from 2 to 5 a lot at first.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 03-18-2015, 01:53 PM   #26
Z/284ever
Z/284ever's Avatar
If I'm just putt putting around, I go from 2nd to 4th or 3rd to 6th all the time.
I've also unconsciously reached for the phantom 6th gear in my IROC-Z, from time to time . Crunch.
Old 03-18-2015, 01:57 PM   #27
SuperSound
SuperSound's Avatar
I've went looking for 7th in mine before...well before there was a 7spd manual lol.
Old 03-18-2015, 02:00 PM   #28
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
I agree! I was referring to the manufacturers having to be creative to conform to the new Café laws.
By track use do you mean drag strip or road course? I haven't heard anything negative yet about the A8.
ssmike is offline   Reply With Quote
