TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 09-30-2011, 12:49 AM   #15
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Stroking a boosted motor is an exercise in futility. You're limited by what the boost device pushes into the motor, not by the motor itself.
DietCoke is offline   Reply With Quote
Old 09-30-2011, 03:59 AM   #16
91Z28350
Drives: 2012 GT500 SVTPP 2010 Traverse LTZ
2.9L doesn't limit it! Just saying And for that matter, I think you would be good with the 2.3 up to 750-800, at least ADM, SLP, Lingenfelter, Hennessey (and other tuners I missed) seem to think so.
91Z28350 is offline   Reply With Quote
Old 09-30-2011, 07:56 AM   #17
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
All great comments gentlemen, and taken under advisement. In my gut I felt like keeping the LSA would probably be the best route to take as I understand that it is basically a detuned LS9 which upgrading the supercharger and forging the bottom end can easily fix. As one of you pointed out, modding the LSA would be cheaper in the long run VS relpacing with the LS7, but you must admit there is something a bit sexy with saying you have a 427 sitting under the hood
I really dont know much about all of this engine detail stuff, that is why I am asking. The little bit I have picked up just by asking questions is just enough to be dangerous, but I have never owned a muscle car and I would rather shell out the bucks to get it right the first time instead of continually going back to add this or that later on.
One of you stated that stroking doesnt necessarily add HP and that could be true. But since I am having the bottom end forged I may as well, right? I understand it does improve torque, but someone (possibly Ted Jannety) stated that you gain about 1 hp for each cui added so going from 376 to 416/417 would add about 40 hp and a bunch of torque so I am told.
BiggFoot is offline   Reply With Quote
Old 09-30-2011, 09:47 AM   #18
djsnoflake
Faith Keeper
djsnoflake's Avatar
Drives: 2012 Silverado LTZ, 2010 2SS/RS
Why not Sell the LSA and buy an LS9?
Pretty good starter motor. You could mod after if you still felt the need.
Although if you have never owned a muscle car, you should try renting an SS and see what you think. That might be more than enough car for you.
Originally Posted by fbodfather View Post
.........we are far from finished.................
djsnoflake is offline   Reply With Quote
Old 09-30-2011, 09:55 AM   #19
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by 91Z28350 View Post
My understanding also is the LSA block has additional reinforcement in the block over the LS3/LS9 block, though I do not know that for fact, I seem to remember reading it in the description of the LSA motor. If you are going for increased boost, forge the LSA, get a larger twin screw blower or TT and have at it!
As pointed out in later posts, I believe the blocks are now the same, since LS9/LSA came out. The only differences now, are steel caps in LS9, while LS9/LSA share the honing proceedure. I believe the cylinder walls in LS7 are also a different metal casting, and the way they're anchored into the block itself doesn't really lend as well to boost as opposed to most of the rest of the aluminum LS-blocks. I was thinking the heat treating on LS9/LSA were of higher standards (T-319 or something...), but I can't verify LS3 blocks are any different...
I believe the R2300 rotors are good to 800 horsepower (R1900s are like 100 less), just like you were saying. I know I have the compressor maps, but there are too many colors and numbers I think the 2300 runs out of breathe after 850. Lingenfelter's LS9-car is running +1200 RWHP, but it also has a 500-shot, lol. Either entry-level twin screw (2.8/2.9) for these cars will easily support near 1000-horse.
I was only saying stroke because I was expecting the later comment by the OP about getting 427 CI
I also suggesting stroking because boring will put you back into a similar wall-thickness situation like LS7s sort of have. Adding CI will add power if everything else is matched, but it costs more $$$. If you have it though, why not get it to where you want it the first time?
The best suggestion I can offer (because I'm certainly no expert on anything) is to figure out where you want to be. If you're only looking for 700 horsepower, you don't need to do a fraction of what you were thinking. If you want 800 horsepower, you'll definately want to get into that shortblock and get at the valvetrain and heads, and probably upgrade the SC and intercooling system. If you're looking for more, you're certainly looking at probably going down the road of a completely re-worked long block and SC. There are many Sponsors here that can help you with a plan once you know where you want to go. I'd urge you to establish the goal, and seek out a Sponsor to help you get there
Good luck and please keep us posted
'20 ZL1 Black "Fury"
radz28 is online now   Reply With Quote
Old 09-30-2011, 10:00 AM   #20
Z4me
Z4me's Avatar
Drives: 2013 ZL1 IOM Vin #169
Mod LSA if I was to choose. They have just placed so much research into this project, plus the caddie has been using the LSA for awhile now. So
I would stay with the LSA and do whatever you can afford up to the capabilites that the LZ1 can handle.
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=36987&dateline=1334886195 border=0 alt= />
Z4me is offline   Reply With Quote
Old 09-30-2011, 10:04 AM   #21
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I would still with the LSA and do whatever you can afford up to the capabilites that the LZ1 can handle.
I can't post the companies link because they're not a Sponsor, but I'll definately be looking into similar mods' for mine. They're all pretty simple and push that "little" 1900 to it's limit. I think they can pulley to 19 psi with their H/C package... They don't really have anything too much more special than our Sponsors, but I see they just make LSA one of their top focuses.
Old 09-30-2011, 11:39 AM   #22
GM4lyfe
A GM nut-swinger!
GM4lyfe's Avatar
Drives: A Car
To be on the safe side while you have the bottom end apart go with good ARP bolts. I would also do ARP head bolts with MLS gaskets. Boosted motors put more stress on parts than a equal powed NA motor. Do it right the first time and save yourself the trouble later down the road. You notice the LS9 have larger head bolts with only 80hp more than the LSA.
2004 GTO Quicksilver
2009 G8 Liquid Red
2005 CTS-V Black Raven
GM4lyfe is offline   Reply With Quote
Old 09-30-2011, 12:57 PM   #23
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
That's still more expensive than just modding the LSA to have the same power.
Old 09-30-2011, 06:21 PM   #24
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by a_Username View Post
Apparently they listened to ya... I just got "page not found."
I couldn't find the exact page either, at first I had the same thought you did ... that they have since fixed the page. But I went looking through their site (to try and find the page he tried to link to) and every engine package they have for the 6.2L V8s (LS3, L99, LSA, LS9) describes them as '378 CID'. Whoopsie.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 09-30-2011, 06:40 PM   #25
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
Biggfoot
Stick with the LSA and do your mods. I transplanted an LS7, race cam, 305cc intake chamber Mast heads, FAST intake, ZR1 injectors and all forged internals, mahle pistons 11.4:1 compression. The motor makes almost 600 lbs of torque @ 630 hp.
The trouble with all that power is you start breaking, drive train parts, suspension parts and the like. My car runs great however foot to the floor shifting through four gears, lots of stuff breaks.
GM did good job of upgrading the drive line in the ZL 1 however that might require more upgrades still.
The LS 7 block and forged internals are bulletproof and the cylinder walls are more than strong enough for a street car.
Save some money in the budget to replace broken drivetrain components.
Go Fast Kid is offline   Reply With Quote
Old 09-30-2011, 07:49 PM   #26
OldScoolCamaro
Drives: Camaro's, always have, always will.
When I purchase my ZL1 I won't touch a thing. I believe as designed it will be The Mother Of All Camaro's. Just my .02 cents. It will be a piece of living history as is. After watching clip 1 and clip 2 I was physically moved and shaken by it's prowess. This ride is more than enough for most and plenty enough for me. Why attempt to alter perfection? Just my thoughts from an old guys perspective.
In Scott We Trust...all others must show proof.
OldScoolCamaro is offline   Reply With Quote
Old 09-30-2011, 08:02 PM   #27
IOMZL1
IOMZL1's Avatar
Drives: 2015 Z/28 | 2017 Viper ACR Extreme
My thoughts exactly. And age doesn't matter - Im just a young guy.
IOMZL1 is offline   Reply With Quote
Old 10-01-2011, 08:34 AM   #28
actireman
Drives: 2011 denali hd2500
I own a chassis dyno company and have watched several customers have us give them more horsepower because they feel they need the big number because they know somebody else has it. When in the long run they find out that it is way more than they can handle and scare themselves at different times in dry and wet weather. They come in the shop and we ask how they like thier car and they reply they sold it because of what happened when driving. So my advice to everyone who has never had this much power, drive it quite a bit and in dry and wet and make sure YOUR ABILITY can stay ahead of it so you don't go and kill yourself or somebody else. Theres a big difference between drag racing horsepower and street driving horsepower. Just my two cents.
actireman is offline   Reply With Quote
