05-16-2021, 01:34 PM | #15 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Your badly low on SC coolant bud. Your going to be sucking in air into your loop if not already.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
05-16-2021, 01:35 PM | #16 | |
LOL What? Oil Starved??? That doesn't even make the least bit of sense.
05-16-2021, 02:36 PM | #17 | |
My coolant was at the res. cold fill line when at ambient temp, and is now as shown in this pic when at 108F. If this isn't right, someone let me know, thx (sorry for my rotated pic)
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
05-16-2021, 02:42 PM | #18 | |
The bottom is the outlet, so technically thats good. But the inlet (into res) is probably sloshing around air at that level and bubbles can be sucked into the res and therefore be sent right down into the bottom. See a pic of Stephens. This is the correct fill. https://www.camaro6.com/forums/showthread.php?t=587347
05-16-2021, 02:43 PM | #19 | |
If was me, i would remove the Intercooler pump relay, and jump the circuit and turn the pump on and watch the res level. Maybe even remove cap and re-bleed it.
05-16-2021, 04:30 PM | #20 |
I'll do that tomorrow, thx
'20 ZL1 1LE A10.
05-16-2021, 05:25 PM | #21 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
That's really not much oil, considering how much air is going through your engine in that 3000 miles.
If it's something critical, there would be maintenance measures for it, like walnut blasting you see on BMW and Volkswagens. Personally, I am still meh on the whole situation, at least on NA cars. Somebody posted a pic of intake valves on a Silverado with 100k miles and 0W-20 oil without catch can. It's really not that terrible, especially for something you don't even see normally anyway.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
05-16-2021, 05:37 PM | #22 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
05-16-2021, 05:41 PM | #23 | |
It doesn't take much oil to start collecting on the back of your valves. 2 Ounces of oil going into your intake is ALOT of oil. That's 2 ounces too much.
05-16-2021, 05:56 PM | #24 |
Drives: 2021 Chevrolet Camaro ZL1 Join Date: Apr 2021
Has any engineer from GM or other auto manufacturers said they should be there? Clearly they must know this happens. Is it possible they have planned for these exhaust gasses into the intake?
I ask this as they are in the hook to warranty these engines and have had decades to develop solutions. Catch cans can be drained directly back into oil pans eliminating the need to empty them If this was such an issue wouldn’t they do that? I have read some messages but little data on the issue Thanks
2021 Camaro ZL1
ADM S/C Expansion Tank Dual Aeroforce gauges Eibach Pro Lowering Kit Oracle Side markers (Paint matched) Rear window "wind screen" Xpel Paint Protection Ceramic Pro Coating |
05-16-2021, 06:40 PM | #25 | |
Drives: 2023 SS 1LE Join Date: Mar 2020
I would use one on my LT4 without hesitation if I was certain they wouldn’t deny any warranty claim I might make. But, with these oil pump failures, I won’t risk it. Be just my luck my oil pump will fail and GM will deny my warranty claim due to the Catch Can. I have a couple more years of warranty left so no CC for me. |
05-16-2021, 07:22 PM | #26 | ||
It's not like every drop of that 72 oz will end up on the back of the valves, and there is a certain temperature the valves(and other parts) will have to be in for the deposits to form, too. Too cold and the deposit won't form, and too hot and the oil droplets wouldn't bond with the metal surface. Quote:
And for ZL1 and 2.0T folks, I think potential collection and ability to interfere with intercooler's performance could be a better argument, if someone has unbiased data on that. Then again, more and more family cars are running at the downsized turbo trend, and you see some of them running close to 20 psi boost stock. If that's a concern, we should see something going on there, too.
Current:
05-16-2021, 07:26 PM | #27 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I wouldn't bother on a NA engine. |
05-16-2021, 07:30 PM | #28 |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
If I keep this car beyond the 5 year/60,000 warranty then I will investigate a catch can.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
