04-13-2022, 12:49 PM | #15 | ||
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
04-13-2022, 11:01 PM | #16 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
This! If anything you should measure the depth of the tread depth holes and compare with the inside of the tire.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
04-14-2022, 01:44 PM | #17 | ||
Mine!
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
04-14-2022, 02:58 PM | #18 |
Nice work, and well done! The Lap Time board shows a few members here running in high 1:38s and 1:39s there.
I will get there, that was my first ever Camaro track day, so I was amused with how playful the car is and how easy it is to slide. But arguable sideways is not the fastest way around. Do you have a Grattan lap? I'd love to see your line there. |
04-17-2022, 08:44 AM | #19 | |
https://youtu.be/cr6WjLM_Iyo
04-18-2022, 08:28 PM | #20 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I have been seeing a bit more wear in the middle of my rear tires than on both edges so I dropped my rear street pressures to around 29psi cold instead of 32 but I am still seeing the same thing. I have always corded the fronts first so far so the slightly uneven rear wear wasn't an issue. My track alignment with front strut mod is: camber: -2.8° front, -1.4° rear, toe: 0° front, +0.05° rear per side [+0.10° total rear toe]. Yes measure the tread depth holes near the outside if you haven't already. Last edited by cdrptrks; 04-18-2022 at 08:47 PM. |
04-19-2022, 08:37 AM | #21 | |
Measuring Tread depth holes... returning shortly. *elevator music*
04-23-2022, 04:26 PM | #22 | |
Alignment shop gave me an extra 0.5 on all 4 corners. Well see how it wears. F - 3.4 R - 2.6
