Old 10-11-2017, 09:13 AM   #253
IOMike
Drives: 2022 F150, 87 Monte Carlo
Originally Posted by lpe403 View Post
I don't think an LT2 or LT3 is in the cards:
We know updated LT engines are in the works most likely for the new 2019 trucks and that they will have dynamic skip fire. I assume they will be in the Corvettes and Camaro too.
What we don't know is if they will make more power.
IOMike is offline   Reply With Quote
Old 10-15-2017, 05:21 PM   #254
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
That's some cool technology!
The Delphi-Tula Dynamic Skip Fire (DSF) Cylinder Deactivation System is an industry-leading, fully variable engine displacement technology.
It combines Delphi cylinder deactivation hardware with an engine control strategy that fires each cylinder only as necessary during each engine revolution,
depending on engine torque demand.
Fundamental control algorithms are provided by Tula Technology, Inc.
The Delphi-Tula DSF System significantly improves engine efficiency and reduces fuel consumption by firing fewer cylinders at lower torque loads to reduce pumping and heat losses.
It also reduces noise, vibration and harshness by dynamically choosing firing sequences that avoid vehicle and driver resonance frequencies.
https://www.delphi.com/manufacturers...ivation-system
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 10-15-2017, 07:12 PM   #255
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
How much more hp and mpg gains will it need to make in order for it to to qualify as "significant" in the gain in efficiency and fuel consumption? 25 hp / 5 mpg?
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 10-15-2017, 08:21 PM   #256
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
Originally Posted by Bhobbs View Post
Or, it just sets up the next generation for an even bigger deal. GM has yet to beat the GT500 in power, not to mention the Hellcat, Demon and future GT500.
Nothing a tune, intake, and pulley swap can't handle. Considering the GT500, if it comes out will easily run $125k. Don't care too much for the Dodge brand as they are heavy pigs and can only do 1 thing correctly. I'd take a Zl1 all day, tune, intake and pulley swap it and call it a day. It eat all those other cars mentioned. Just my .02. Plus, it looks better. Looks are subjective, I get it. Not to mention it's quite budget friendly.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 10-16-2017, 12:57 AM   #257
Bhobbs
Bhobbs's Avatar
Yeah, and the same mods will keep the GT500 in front.
How do you figure the GT500 will cost $125k?
Old 10-16-2017, 01:00 AM   #258
1slowssm6
Drives: 2016 1ss m6 Camaro
because the gt350 was $60kish and sold for $90k-$100k lol why would ford not basically make the same happen for the gt500? IF there is a gt500,ive heard rumours for like 3 years now,still no gt500 to be seen
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step.
Best 1/4 mile of 11.2@122mph
1slowssm6 is offline   Reply With Quote
Old 10-16-2017, 02:28 AM   #259
gringo
gringo's Avatar
Drives: Camaro V6
That ZL1 can't fit more than two people unless the other two are amputees. It's basically a slightly cheaper alternative to the Z06 Corvette.
You have to give Dodge a lot of props. They've created the modern muscle car out of what is basically an old Mercedes E-class platform with a legendary nameplate attached to it. Straightline performance still rules the stoplight/drag/brag races and the new Demon triumps all.
gringo is offline   Reply With Quote
Old 10-16-2017, 09:14 AM   #260
shaffe
Drives: 21 Bronco
That's on the dealers not Ford.
Lets keep it simple. ..
Old 10-16-2017, 10:35 AM   #261
KMPrenger
KMPrenger's Avatar
25HP....sure.
But 5mpg resulting from just an engine re-design would be a mind blowing game changer. I'm going to assume it could result in the engine being somewhere around 10 - 20 percent more efficient, resulting in maybe 1 or 2 mpg in real world testing.
Old 10-16-2017, 02:22 PM   #262
Bhobbs
Bhobbs's Avatar
Ford isn’t responsible for what dealers add to the MSRP.
Old 10-16-2017, 02:54 PM   #263
TunaMelt
Drives: 2017 Camaro SS 1LE
Dodge makes some really cool cars that are probably the best daily drivers of the whole bunch. A Hellcat or SRT will be the next move when kids come along.
TunaMelt is offline   Reply With Quote
Old 10-16-2017, 03:23 PM   #264
SpeedIsLife
Drives: Current Camaro-less
You're higher than a kite if you believe the GT500, if one appears for the S550 generation, will push past even $75,000.
Ford doesn't make a single penny from ADM. Limited production does help make sure there is a higher demand than supply, thus promising eventual sales, but they don't benefit from ADM.
Old 10-17-2017, 02:12 AM   #265
camaro5
camaro5's Avatar
No evidence that skip fire will increase hp - it's AFM Deluxe
However:
Rumor has it General Motors is also working on a 6.2-liter small-block V8 christened the LT2,
essentially a better version of the LT1, with around 500 horsepower on tap.
Will the mid-engined 2019 Chevrolet Corvette (C8) get it first?
Oh well, only time will tell if the rumor turns out to be true.
https://www.autoevolution.com/news/2...t7-107508.html
We have heard that GM is planning to offer the Corvette C8 with three different powertrains.
These will include the engines codenamed LT2, LT6 and LT7, with one of them being a hybrid powertrain.
http://www.carscoops.com/2017/08/mid...pied-gets.html
LT7 is the hybrid
Originally Posted by KMPrenger View Post
25HP....sure.
Benefits
Independent control of each cylinder enables broader and smoother torque management capability, and provides full control of cylinder firing while maintaining optimal emissions
10% to 20% fuel economy improvement
compared with conventional spark ignition engines depending on the engine and driving conditions (based on advanced development testing),
and the potential to
reduce CO2 emissions by up to 20%
Torque pulse optimization algorithms can prevent adverse vehicle resonances and objectionable pulse frequencies
Broad applicability across a range of engine sizes and types
Compatible with 3-way catalysts for gasoline engines
Fast response allows full cylinder deactivation in a single cam revolution at speeds up to 3500 rpm
PDF: Advanced, specially designed Delphi valve train technology
Delphi-Tula Dynamic Skip Fire Cylinder Deactivation System (656kb)PDF
i
STANDARD DISCLAIMER
Old 10-17-2017, 04:54 AM   #266
1slowssm6
In my opinion you’re high as a kite If you believe 3rd year rumors about the gt500 coming now,hasn’t come in 3 years,ford would make it more expensive than the gt350,seeing how they now know what ppl will pay,but we won’t ever know cause it’s not coming,so it’s a pointless argument.
