Old 10-10-2025, 05:22 PM   #2507
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Updated
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 10-11-2025, 10:37 AM   #2508
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Track = Hallett ccw
Time = 1:22.25
Year/Model/Trim/Trans = 2018 SS 1LE M6
Date = 9/27/25
Tires = Pirelli scrubs
Mods = MSD INTAKE, HEADERS, 444WHP, SPL, MCS, RACING SEATS, CMS ROLL BAR, NINE LIVES WING, 6" DIY SPLITTER, APEX 18X11 VS-5RS SQUARE
Old 10-12-2025, 08:29 PM   #2509
CallingMrBenzo
Drives: 2022 Camaro SS 1LE
Track = Dominion Raceway
Time = 1:31.66
Year/Model/Trim/Trans = '22 SS 1LE M6
Date = 10/11/25
Tires = OE SC3
Mods = SRF, Blackwing Brake Ducts, Track Alignment
RaceCrono Pro with a 10hz Dual GPS
https://youtu.be/cVc6NKwyWSo?si=Ju8-ooRA0DhZl9jL
CallingMrBenzo is offline   Reply With Quote
Old 10-12-2025, 09:44 PM   #2510
Oldslowtired
Drives: Bought hooligan317’s ZL1
Track = VIR
Time = 158.27
Year/Model/Trim/Trans = '20 ZL1 1LE
Date = 10-10-25
Mods= APR Rear wing, front splitter, AP Brakes, SRF, full AWE exhaust
https://youtu.be/Z3TGxtqEQdM?si=vgTNxJCAkrevtcFM
Last edited by Oldslowtired; 10-19-2025 at 07:45 PM. Reason: Wrong video clip linked
Oldslowtired is offline   Reply With Quote
Old 10-13-2025, 12:09 AM   #2511
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Track = Summit Point Main
Time = 1:20.55
Year / Model / Trim / Transmission = 2019 ZL1 1LE M6
Date = 10/05/2025
Tires = OEM SC3R
Mods = Castrol SRF, Track Alignment, RotoFab CAI, SPL Toe Arms, DTC70/60 Pads
YouTube
Old 10-14-2025, 01:31 AM   #2512
Baddawg53
Drives: 17 hyper blue 2SS M6
2017 Camaro SS M6
10/13/2025
Thunderhill East Bypass
1:57.47
Aero, 600whp, mcs two ways, weight savings
315/30/18 square pirelli trofeo track
https://youtu.be/vrWmvLUrHQY?si=DtvaHGVfDVruGdMP
Baddawg53 is offline   Reply With Quote
Old 10-14-2025, 09:31 AM   #2513
FollowMyLine
Driver for Hire
Updated!
Luan Zeqollari
YouTube Channel
Old 10-14-2025, 10:37 PM   #2514
sgreer78
Drives: SS 1LE
Track = WWT Raceway (Gateway Motorsports Park)
Time = 1:10.263
Year/Model/Trim/Trans = '24 SS 1LE 6M
Date = 10-14-25
Tires = WORN, DEAD! 275/35-19 285/35-19 RE71RS's
Mods= Whiteline Rear Sway Bar, Ferodo DS1.11, AP Racing R4
sgreer78 is offline   Reply With Quote
Old 10-15-2025, 12:48 AM   #2515
cdrptrks
cdrptrks's Avatar
I made it out to Hallett for the first time this summer! They ran it CW at the end of Sunday which I enjoyed; hopefully I can make it back there to do a full day/weekend CW another year. Bits of gravel from the recently repaved surface were getting pulled up throughout the weekend and they didn't have time to clean them all off of the track so I won't post my slow CW lap...others have posted faster videos on YouTube on a clean track. It was very tricky to even stay on track in some corners while driving through that stuff. It looks like they repaved the corners again since my visit based on carguy55's recent video...hopefully that fixed the issue.
Track = Hallett CCW
Time = 1:25.93
Year/Model/Trim/Trans = 2017 1SS 1LE M6
Date = 6/8/25
Tires = OE SC3
Mods = Estimated 450whp on E85 with flex fuel sensor & tune, BBK CAI, 95mm TB, GPI ported LT2 intake, Track alignment, SPL Rear Toe Links + Eccentric Lockout, BMR BK063 Diff Lockout, FEA front lower front control arms, 2021 SS 1LE EBCM, SRF, GM track brake cooling kit
Note: I haven't dynoed it yet but I plan to in the future. Engine internals, headers, cats, and exhaust remain stock.
The Garmin Catalyst I borrowed for the weekend had my optimal lap time as 1:25.30 at the end.
Be careful to stay out of the grass at the turn 8 apex. The corner entry is blind (except for the top of a tall cone they put at the apex) so that's easier said than done. I went a little off track there on one lap and slightly bent both passenger side OEM wheels; thankfully they were not bad so I could still drive on them and they were able to be quickly (but not cheaply) straightened by a local wheel repair place after I got home.
Reminder to myself and others: downshifting while turning is risky even with auto rev match. I had a big moment in turn 1 because of that:
https://youtu.be/ZWBym86X5GM
I also got to drive Eagles Canyon 2.7 CW (not the usual direction) on my way back from Hallett which was great (except for it being 90+ degrees and sunny)! I haven't edited/uploaded that video yet but it was only 1 day and I didn't quite achieve what the car is capable of but the stock SC3 tires were overheating quickly in the heat so I didn't have many chances. Hopefully I can drive that track direction again too to get faster...I might actually prefer ECR CW instead of CCW!
Old 10-15-2025, 01:24 AM   #2516
cdrptrks
cdrptrks's Avatar
New NOLA track layout to add from my video archives that I finally edited/posted. It is the same as the normal layout except for a straightaway that bypasses the esses...this one is hard on brakes!
NASA Gulf South Region is going to do this layout again next month (possibly for the first time since I drove it in 2021):
Track = NOLA Indy Straight 2.72mi
Time = 1:54.46
Date = 3/13/21
Tires = OE SC3
Mods = Track alignment, Front strut mod, -2.8f, -1.4r, toe: 0f, +0.05r per side, STR600, StopTech Sport Brake Pads, GM track brake cooling deflectors
Note: All things being even, I estimate this layout is around 3 seconds per lap faster. That's a guess because I had different brake pads than usual and my braking g-force was a little lower than optimal so I had to brake earlier.
Old 10-15-2025, 11:54 AM   #2517
FollowMyLine
Driver for Hire
All Updated!
Luan Zeqollari
YouTube Channel
Old 10-21-2025, 10:45 PM   #2518
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
High Plains Raceway
2:04.77
'21 ZL1 1LE A10
10/19/2025
Goodyear SC3R
Corsa NPP catback
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 10-24-2025, 11:18 AM   #2519
FollowMyLine
Driver for Hire
Updated!
Luan Zeqollari
YouTube Channel
Old 10-24-2025, 08:28 PM   #2520
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
ThunderHill Raceway East w/ Cyclone
1:54.36
'22 SS 1LE 6M
10/12/2025
Nankang CR-S 200TW
Mods: 19" Forgeline Wheels, Katech Competition Spec Engine, MSD, QA1, Hurst, MCS 2WRR, MFR Engineering, G-Loc Brakes, Nine Lives Racing, Anderson Composites Carbon Fiber, Auto Addicts USA,
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake
SCCAForums is offline   Reply With Quote
