#239 |
![]() Drives: 2016 Camaro SS Join Date: Jul 2016
#240 |
When I checked the logs, just in my personal opinion
Whipple 3.0 Pros 1. A bit more potential. 2. Seems have slightly better cooling system 3. Whinning sound Cons 1. Extra works like subframe spacers. 2. As a bolton kit, Meggi has better kit design. 3. Whinning sound Again, just my personal opinion. I love the both. Last edited by shinysun; 03-30-2023 at 06:41 PM. |
#241 |
I'm doing test n tune Saturday and Sunday and mine will probably make 19 to 20 lb of boost depending on the weather, and most would not call that high. Your boost?
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#242 |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
23 psi
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#243 | |
#244 |
I had a... surprising conversation with Greg early this year, wherein he said that focusing on boost is the wrong thing look at it. High boost tells him that the engine should be modified to flow the available air. I haven't tried to calculate the head flow cfm to accomplish this, but it would probably be >550.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 03-31-2023 at 10:35 AM. |
#245 | |
#246 |
Moderator
How much did the new headers help, in your opinion?
#247 |
The best I can say is that the car went very lean with them on the all in pulley setup where it didn’t before. That was at the track. They had to remove 10% from the DI because they got up to 8ms, and then crank up the base pressure for the port injection. It also dropped 1 psi of boost. That’s about the best data I have unfortunately.
#248 | |
Moderator
But it sounds like the headers definitely helped. Is Kooks going to offer them to the masses or are they going to stay under wraps for a bit?
#249 | |
The headers are available now but exclusive to Vengeance Racing. It was a deal they made with Kooks. Vengeance will sell them outside of an in house build though.
#250 | |
Moderator
#251 |
Petro-sexual
Are those primaries bigger than the typical 2"? I saw going bigger for your kind of build helped a lot.
#252 |
They are stepped 2-2 1/8” to 3.5” collectors and x-pipe.
