Old 05-14-2017, 07:33 PM   #225
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Ok so here are some laps of the first session out in the 1LE at Sonoma Raceway. Given that, it's not the most efficient or smoothest driving, but a couple of 149.2's ain't bad for a showroom car. I'm amazed by this car in factory form on the track, even the brake pads handled everything I threw at them. Car tends to get a bit greasy and has progressively worse mid to late corner push as the session goes on. I'm excited to give a 305 square set up a go soon. BTW, is anyone elses PDR brake sensor off? I'm definitely into the abs and mashing the pedal more than the PDR displays.
seanblurr is offline   Reply With Quote
Old 05-14-2017, 07:39 PM   #226
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by Provoste View Post
My PTE Miata buddies swear by them (though now they like the RS4's more because of better wear), and they are universally the GT4 go to track tire. Most GT4 guys report their personal best times on nearly corded RE71R. My experience corroborates this- In the last session last weekend, I was 1.2 seconds down on my best time at NCM MSP until I hit traffic in the last corner.
The RE71R frinction circle reminds me of NT01's, plus... they're insanely good in the wet. I REALLY wish Hankook made a 295/30 RS4.
Originally Posted by seanblurr View Post
I'll be trying 305/30 RS4's after my NT01's.
I posted this in somewhere but not sure if in this thread, sorry if it's a repost. They tested them against each other and found the NT01 and Rivals faster than the RS4s:
http://www.tracktuned.com/feed/2017/...nd-hankook-rs4
Here is my almost recent alignment. A little metal persuasion is required on the front struts for those front camber numbers (slightly extending factory oblong camber adjustment hole). I'm planning to keep toe the same front & rear but increase rear camber to -1.9 just to help tire life.
Pads- I'm just done with my first set of front Hawk DTC 60's. I'll be ordering a new front pad set for the Glen. I also used the factory pads on track for a couple days, they're at about 50%.
That's awesome that you could get that much of camber up front, mine fronts maxed out at -2.4 and it looks like I will have to wait till I get my Multimatics to see ~-3.0 camber (will probably run -2.0 in the rear).
glamcem is offline   Reply With Quote
Old 05-14-2017, 07:46 PM   #227
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
PDR shows pedal stroke, not effort. I had the same thought until I noticed when pads were getting thin/needed brake bleed PDR showed more brake pedal.
Provoste is offline   Reply With Quote
Old 05-14-2017, 07:47 PM   #228
Provoste
Provoste's Avatar
Thanks for the link, good info.
Old 05-14-2017, 07:50 PM   #229
glamcem
glamcem's Avatar
Very cool and great driving btw, this and the Thunderhill are the tracks that I want to take my car to
305s upfront felt great on my car especially with the Wickerbill in the rear
Old 05-14-2017, 07:51 PM   #230
glamcem
glamcem's Avatar
Old 05-14-2017, 07:53 PM   #231
Provoste
Provoste's Avatar
Oh Sonoma, I wish I lived closer! Such an awesome track. Nice driving Sean. Pretty sure flat shifting next to walls on track is the sound of freedom.
Old 05-15-2017, 07:44 AM   #232
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
Great driving, lap times and vids! Thanks
JRL1LE is offline   Reply With Quote
Old 05-15-2017, 10:17 AM   #233
Provoste
Provoste's Avatar
Interesting read, and it was the R888R, not NT01. If anything though, it intrigues me that the RS4's took the longest to come up to temp on an autocross ; maybe an advantage for track guys and would help answer why my PTE Miata buddies say they wear like iron in 8 hour enduros... harder compound more resistant to overheating and faster wear.
Old 05-15-2017, 10:45 AM   #234
TrackClub
TrackClub's Avatar
I guess this review gives a thumbs up to the new R888R albeit in a limited fashion as their car broke down. OTOH autox comparos in 30 second runs is neither here nor there as compared to 30mins road course stints. And indeed RS4 could perform very differently there. Either way, a clear sign that uber street tires have gotten very close to "R-comps" except perhaps for prolonged heat management (and this would be expected IMO).
Speaking of tires, a forum member OminouSS loves Cup2s on his ZL1 and he ain't a novice by any means. He's now on his 3rd or 4th set (last one being the first brand new set to boot!). You can see his vids and comments in Road Course section of the forum.
So, it looks like we have at least 3 decent choices for tires on stock rims: GY stockers, RE71R in 295 square and Cup2 in square or slight stagger. This ain't bad, albeit not as plentiful as 19 inch choices of course, especially with a wider, 10.5F wheel.
Old 05-15-2017, 10:58 AM   #235
TrackClub
TrackClub's Avatar
BTW, as far as Cup2s, in 20s I only see make specific spec tires (PCARS, Bimmer and Benz) and they list super expensive at least on Tire Rack (pretty much $500 per tire)...
Cem, where did you see them in $300 range?
Old 05-15-2017, 01:50 PM   #236
glamcem
glamcem's Avatar
That's correct, my bad. And you may be right about that it may take longer to heat them up. I see mixed reviews about them some claim they're on par with RE71Rs and some say they're not. They're not currently offered in 20" sizes so it won't be possible to compare them against to OEM G3s :/
I was referring to the 19" sizes, see post 212
Old 05-15-2017, 04:49 PM   #237
TrackClub
TrackClub's Avatar
Got it Cem - thx!
Great vid Sean!
Old 05-22-2017, 01:27 AM   #238
glamcem
glamcem's Avatar
I attended to another club event at the ORP yesterday (2017-5-20).
Ambient temps were about 15F degrees higher this time so my best lap was 1:55.. I had understeer issues maybe because of the tire temps . Overall I am not that impressed with the Trofeo R tires probably because of the softer sidewalls or the fact that it's recommended with 30 hot psi and -3.0 camber (it was easily 37-38 psis after a few hot laps). I will see how the NT01 will do next time at the ORP
Since I accidentally hit the SD card (when I was testing the new OBD Adapter ) my best lap was not recorded on PDR but luckily I had my external GPS on so I could create a video with overlay..
Sorry for the shaky video
