Old 03-18-2024, 08:16 AM   #2297
BoilerUP
BoilerUP's Avatar
Drives: Cadillac ATS-V
Originally Posted by Christian1LE View Post
Track = VIR
Elapsed Time = 1:59.881 (From NASA Transponder)
Year / Model / Trim / Transmission = 2022 / SS / 1LE / Manual
Date = 03/18/24
Tires = Hoosiers A7 315/30/18
Mods = Hawk60, DSSV, SPL rear arms, BMR toe rod, 75lb Ballast to get 3901 min weight.
I know the A7 is a time trial/qualifying tire not a 30min session HPDE lapping tire, but how many fliers do you get before it becomes greasy?
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber*Pitt Race*VIR
BoilerUP is offline   Reply With Quote
Old 03-18-2024, 06:50 PM   #2298
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I know some people do races in them. The ideal lap on them is either your first or second flyer. After that they will lose time. After 3 laps you won't be getting them most out of the tire. They are going to be fast the entire session but they won't be in their optimal grip range, still better than a street tire. I've ran an old set of corded A7's for HPDE session and they were great the entire session, temps were like 50 degrees though. Not sure how they would do in the summer.
Christian1LE is offline   Reply With Quote
Old 03-18-2024, 06:54 PM   #2299
Christian1LE
Originally Posted by FollowMyLine View Post
Alright everyone, I need some help. Since we are at the post limitations, I am thinking a Google Sheet would be best for this list. Who is better at Google Sheets than me? I may need some help on figuring out the best way to bring this data over to a Sheet file. PM me and lets talk. I am willing to do the work, just not sure where to get started.
Thanks,
If you create a google sheet document I'll donate some of my time to start transferring data over. I'm not an expert in google sheets either, but with enough people over time we should be able to transfer everything.
Old 03-19-2024, 12:09 PM   #2300
cdrptrks
cdrptrks's Avatar
I spent some time working on an Excel spreadsheet. I'll try to finish it later today and convert it to a Google Sheet (assuming that is possible...not sure). I don't think it will be practical for one person to separate each mod of each car into individual columns but I was able to get username, car, date, and video links separated into columns using mostly automated/bulk methods.
Old 03-19-2024, 11:00 PM   #2301
cdrptrks
cdrptrks's Avatar
Thanks,
Here's the Google Sheet I made in Excel. You're welcome to make your own copy to update or use this one or I can send you the Excel file to import into your own Google Sheet. I think the link below is probably read only but I'm not too familiar with Google Sheets. I have a Freeze Pane for the top row so that I can see the headers as I scroll down but unfortunately this is apparently not supported on publicly shared Sheets per Google.
I did some spot checks and tried not to remove any information but there were a lot of bulk processing steps involved so please let me know if anything looks incorrect. I have a copy/paste of the original data from post #1 as of this morning saved in Excel and could restore missing/incorrect info if any is found.
https://docs.google.com/spreadsheets.../pubhtml?pli=1
Old 03-19-2024, 11:57 PM   #2302
Coded4SS
Drives: 23 Zl1
Hoping this is valid to get me in the ranks. I got Streets of willow CW and CCW here. Both in my 23 ZL1 on stock tires. Rotofab intake and awe axleback. Track alignment. (Basically stock) would be happy if user listed is "hot1le" but ill take what i can get
Coded4SS is offline   Reply With Quote
Old 03-20-2024, 12:01 AM   #2303
Coded4SS
Drives: 23 Zl1
Size:  68.3 KBI also have big willow (willow springs road course). 23 ZL1. Awe axleback and gm track alignment only. Will be happy if user listed is "hot1le/coded4ss" but ill take what i can
Old 03-20-2024, 01:02 PM   #2304
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Try this...
Double click (or right click) the Row number. In this case, Row 1. Then select "View more row actions" then "Freeze up to row 1"
And FYI... it is read only
Dabjbr is offline   Reply With Quote
Old 03-24-2024, 11:03 PM   #2305
991.1le
Drives: 2018 SS 1LE
Track = Willow Springs International Raceway - Big Willow
Elapsed Time = 1:20.69
Year / Model / Trim / Transmission = 18 SS 1LE 6XD Sequential
Date = 3/24/24
Tires = 335/315 A7’s
Mods = HPR 454ci LT1, MCS 2-ways, RS Future wing and splitter, 6XD
Very successful shakedown day of the new 454 at Big Willow!
https://youtu.be/coXjqw32ItU?si=JTsd1laUYA6F5e0c
991.1le is offline   Reply With Quote
Old 03-25-2024, 06:01 AM   #2306
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
Date = 3/24/24
Epic!
khcoaching is offline   Reply With Quote
Old 03-25-2024, 01:42 PM   #2307
Steelankles
Steelankles's Avatar
Drives: 2017 Camaro SS 1LE
Track = Road Atlanta
Time = 1.32.95
Yr/Mdl/Trim/Trans = '20 ZL1 1LE M6
Date = 3/16/24
Tires = R7
Mods = SRF, AWE axle back, Rotofab CAI
https://youtu.be/ZF01uqBWGCo?si=HW7WkobdUYh7dlzF
2020 ZL1 1LE Crush
2017 SS 1LE Hyper Blue sold :(
1995 Mustang GT 427ci Road race car
Youtube: Steelankles
https://youtube.com/c/steelankles
Steelankles is offline   Reply With Quote
Old 03-26-2024, 02:33 PM   #2308
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
G2 Motorsports park on 3/23/24
2:17.53 - Pcormier66 - '19 ZL1 1LE, 3/23/24, no mods, SC3R
Pcormier66 is offline   Reply With Quote
Old 03-26-2024, 08:02 PM   #2309
Diamond
Nightfall Gray ZL1
Diamond's Avatar
Drives: 2018 ZL1, 1992 Celica AllTrac Turbo
2 Mar 24 COTA 2:33.70
Track = Circuit of the Americas (COTA)
Time = 2.33.70
Yr/Mdl/Trim/Trans = '18 ZL1 Non-1LE A10
Date = 3/02/24
Tires = GY SC3 (not R)
Mods = SRF, AWE touring, Rotofab CAI, 1LE rear wing
https://youtu.be/OkLNPTCen-w
Diamond is offline   Reply With Quote
Old 03-27-2024, 01:27 PM   #2310
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
I am working on the lap times Google Sheet. I have currently completed the tracks that start with "A."
Please keep sending the updates, as I will add them in while I get this converted over to a Google Sheets file.
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
