#211 | |
![]() Drives: 2016 2SS Join Date: Feb 2010
2016 Hyper Blue 2SS, A8, NPP, MRC
#212 |
![]() Drives: 17 1SS 1LE Join Date: Aug 2017
So....its been almost four months since someone asked about 1LE Satin Black. The last post on 9/20 made no mention of whether or not this was in process, you merely listed what is already available.
ARE you guys working on 1LE satin black or should those of us trying to match our cars go somewhere else? Lastly, you also promised an install guide. Any chance that's still in process? Thanks! |
#213 |
So my delivery has changed. I am at home waiting for FedEx today. Yes the skirts are coming in early.
No sooner than I hit enter, I get a knock on the door. Yes fedex just dropped off my skirts. I opened the box for a quick inspection. It was in perfect condition. Then I went out to put them on the car, temporarily, with spring clips. They fit perfect. The wait was well worth it. Thanks C7 Carbons.
2016 Camaro 2SS "Black Widow" Last edited by Tazz3069; 09-23-2017 at 07:16 PM. |
#214 | |
#215 |
HAHAHA. Now I just need to wait for my wing to come in from ACS. Once I get that, then I can send in all the parts to get painted. So far, everything fits really nice.
2016 Camaro 2SS "Black Widow" |
#216 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
Current lead time?
#217 |
Owned gen 4, 5 and 6
Drives: 2017 Camaro 2SS Join Date: Jul 2017
Can you ship these in mosaic black?
2017 2SS, Mosaic black <3, NPP Exhaust, MRC, GM CAI, Loaded.
#218 |
![]() ![]() ![]() ![]() Drives: Camaro Join Date: Aug 2013
Hey guys its official: the 1LE style Satin Black finish will be available on our Camaro products!
We'll post more details on this very shortly! |
#219 |
![]() ![]() Drives: 16' Camaro E-Force SS Join Date: Jul 2016
Since the lip is fiberglass can we assume that the second it hits anything it will crack vs scrape of abs? Anyone tested durability yet?
Leo
2016 e-Force 2SS Instagram @cleoent |
#220 |
Since I'm still waiting on mine to arrive, I thought I would get everything in advance to install. Does the skirts come with the mounting hardware? Do they arrive with black pop rivets or should I get some (don't plan on using screws). If none are provided, what size is recommended?
#221 | |
#222 |
SoCal HT5! SD
Is the drilling isolated to the underside of the factory rockers near the pinch welds? Or do you have to drill in more visible areas. Concerned with leaving visible holes in the body if the side skirts were to come off.
#223 |
![]() Drives: 2014 c7 corvette and 2017 camaro ss Join Date: Jun 2017
ordered my full set yesterday , almost went with the carbon fiber skirts and lip
#224 |
Hi guys, our ZL1 style side skirt sets come with .5" long self tapping screws. If the preferred choice is to go with pop rivets instead, we recommend using 3/16" diameter .5" long aluminum pop rivets. Drilling on the rocker panel is required for either option.
The side skirts have several pre-drilled holes located on the inner flange surface that can be fasten with the mounting hardware. These pre-drilled holes sit bellow the rocker panels and also on the lower angled edge of the rocker panel. Without the side skirt installed, the holes drilled on that lower angled edge may be visible from ground level. The side skirts can be attached to the Camaro combining the self tapping screws/pop rivets with double sided tape [not included] through out the flange surface for extra grip and help suck in any slight gaps. That being said, the location and amount of bolting points applied when securing the side skirts to the vehicle will be to the installer's discretion. We'll make sure to post further news on our products soon. Thanks again! Last edited by C7 Carbon; 09-27-2017 at 01:57 AM. |
