#211 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
You had to be there Sent from my iPad using Tapatalk
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#212 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
Pretty much. Won't forget it. Sent from my iPhone using Tapatalk
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
#213 | ||
Awesome vid. Thanks for the share! Sent from my iPhone using Tapatalk
#214 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
I did it Kaizer_911 DBSSNH is coming.
Peer pressure is a wonderful thing.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
#215 | |
Camaro Fest VII - Official Announcement
Yes it is. I hounded him some as well. He called me earlier saying he was going. Party in Bowling Green! Sent from my iPhone using Tapatalk
#216 | |
Cajun Mariner
Drives: 10 Camaro SS/RS 15 Camaro Z/82 AGM Join Date: Mar 2010
wish
'10 Camaro 2SS/RS Red Jewel VVTLS3/A6
'15Camaro Z/28 Ashen Gray |
#217 |
![]() Drives: 2002 Camaro SS Join Date: Jun 2012
Awesome. Not too far a drive for me.
2017 1SS Hyper Blue M6
2001 Ford Lightning |
#218 |
![]() Drives: 2013 Victory red/white stripes SS Join Date: Mar 2013
Thank You
To All who are on the Committee(s) for selecting and planning The Camarofest, (more specifically, Mlee and Mr. Wyndham)...Thank you. Some of my posts have been critical of how things were coming about. I certainly hope you did not take umbrage at my remarks. While they were heartfelt, they were never meant to offend or upset. All I ever wanted is this Camarofest. I need it for multiple reasons....one reason should be adequate but I have like seven or eight!!! So, thank you. Thank you. I hope there are no hard feelings. Did I mention thank you?
faSSteddie |
#219 | |
Drives: Camaro Justice Join Date: Jun 2007
#220 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Is DOT 4 brake fluid a requirement or a suggestion???
Orange Krush II
#221 |
CamarCross
I'm in!!!!
Need to try out Pete's parts from last year.
Orange Krush II
#222 | |
I used to be Dragoneye...
Member input is important to what we do, and when we do it. And of course - there wouldn't BE a CamaroFest if nobody shows up! ![]() It's a fantastic time, an awesome collection of motorsport and show events...and most importantly, hundreds of wonderful people who all share an excitement and passion for the same thing: the Camaro!! So....as long as you promise to be patient with us...we promise to field your criticisms. ![]() Going on the Road Course? EXTREMELY STRONG SUGGESTION...to avoid brake fade, and losing your brake pedal halfway through a lap due to overheat. At the very least, get your fluid changed/bleed the brakes so you have fresh fluid in there. CamaroCross? Not necessary, but it's a good idea...chances of getting to the heat levels of a road course are lower than the road course. Ditto for drag strip. |
#223 |
#224 | |
Booooosted.
![]() Quote:
