Old 10-02-2023, 08:20 AM   #2213
991.1le
Drives: 2018 SS 1LE
Dude I’ve been chasing that for so long and get shit for it every time I go through tech. It seems like it’s just a tolerance thing between the two pieces that make up the Recaro sliders. I’ve had the mounts apart and checked nut and bolt tightness but they’re never loose. Just the top slider piece physically move laterally on top of the other one. I have the same setup for my passenger seat and it does the same thing. This seat back is drilled for a roll cage brace though so maybe I can pick up one of those and see if that helps stabilize it. I don’t really wanna ditch the slider because it makes getting in and out of the cage a lot easier with the door bars. Open fo any other suggestions and thanks for looking out!
991.1le is offline   Reply With Quote
Old 10-03-2023, 10:07 PM   #2214
Baddawg53
Drives: 17 hyper blue 2SS M6
Sonoma raceway 10/3/23
Lap time 1:47.56
2017 2SS cam/heads/FBO E85 silvers 2 ways, Hoosier R7 313/30/18 square. GTC 300 wing, custom splitter.
https://youtu.be/gKgXAwJ-ntI?si=t8dozqbPhciPfPG5
Baddawg53 is offline   Reply With Quote
Old 10-04-2023, 10:02 AM   #2215
meterman
meterman's Avatar
Drives: 2018 ZL1 1LE
Mid-Ohio Club Course 1:37.82 '18 ZL1 1LE on 9/30/23, stock wheels and Goodyear 3Rs, Track Alignment, SLP Rear Toe Links, Eccentric Lockout, Borla Atak, OMP HTE-R seats, CMS Performance Roll Bar, Rear Seat Delete, Sparco Martini Racing 6 Point Harness, Momentum GT Cold Air Intake, Blackwing Front & Rear Brake Cooling Ducts
https://youtu.be/EQMQRdV8_-g
2007 Shelby GT500 Vista Blue (SOLD)
2019 Shelby GT350R Magnetic Metallic (SOLD)
2018 ZL1 1LE Hyper Blue
meterman is offline   Reply With Quote
Old 10-04-2023, 03:21 PM   #2216
meterman
meterman's Avatar
Mid-Ohio Pro Course 1:36.05 '18 ZL1 1LE on 9/29/23, stock wheels and Goodyear 3Rs, Track Alignment, SLP Rear Toe Links, Eccentric Lockout, Borla Atak, OMP HTE-R seats, CMS Performance Roll Bar, Rear Seat Delete, Sparco Martini Racing 6 Point Harness, Momentum GT Cold Air Intake, Blackwing Front & Rear Brake Cooling Ducts
https://youtu.be/oFCBjMy1g7o
Old 10-04-2023, 04:54 PM   #2217
tomster
RedLine
Drives: 2022 ZL1 1LE
Time is posted at the 3:17 mark on the below Video
https://youtu.be/lrBxHb23pWQ?si=ny9ruvdHuWWZhhwa
Track = Mid-Ohio Club Pro Course
Time = 1:33.12
Year/Model/Trim/Trans = '22 Zl1 1LE M6
Date = 9/30/23
Tires = OE SC3R
Mods = Track Alignment, CAI, Rear Cat Delete, SRF
tomster is offline   Reply With Quote
Old 10-04-2023, 04:57 PM   #2218
tomster
RedLine
Time is Posted at the 1.42 mark of the below video
https://youtu.be/MFUb4_W0tTU?si=Nuxid311bpMcZGIl
Track = Mid-Ohio Club Club Course
Time = 1:36.15
Date = 10/1/23
Tires = OE SC3R
Old 10-04-2023, 05:05 PM   #2219
tomster
RedLine
I just watched the below video posted as Mid-Ohio club course 1:35.4x. Looks like the time per their PDR in the video is actually 1:36.45. Still a great lap but I believe it was entered wrong.
3. 1:35.4x - tm5 in '18 ZL1 1LE on 9/16/18, OE SC3, track alignment Video
Old 10-04-2023, 05:42 PM   #2220
meterman
meterman's Avatar
I just watched it too and agree and it actually shows 1:36.47 before the lap timer changes, it's still a fast lap though but your time will put you in 3rd and tm5 into 6th.
Old 10-04-2023, 09:06 PM   #2221
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
Track = COTA
Time = 2:28.29
Year/Model/Trim/Trans = 2017 SS 1LE
Date = 10/1/23
Tires = Toyo RR 295/18 Square
Mods = SRF, Stock pads, track alignment, race seat/harness, removed back seat, gutted trunk.
https://youtu.be/IiVuL_Nrxqg
JTRATX is offline   Reply With Quote
Old 10-05-2023, 11:32 AM   #2222
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Noted. Adjusted.
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 10-05-2023, 12:04 PM   #2223
FollowMyLine
Driver for Hire
All times updated.
Luan Zeqollari
YouTube Channel
Old 10-06-2023, 02:46 PM   #2224
tomster
RedLine
Originally Posted by FollowMyLine View Post
All times updated.
Your the MAN!
Old 10-06-2023, 09:49 PM   #2225
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Track (which config if applicable) = NJMP Thunderbolt
Elapsed Time (please include times to the hundredth if possible) = 1:30.10
Year / Model / Trim / Transmission = 2019 ZL1 1LE M6
Date = 10/06/2023
Tires = OEM SC3R
Mods = Castrol SRF, Track Alignment, RotoFab CAI, SPL Toe Arms, Ferodo DS1.11 pads
YouTube
Old 10-07-2023, 03:30 PM   #2226
FollowMyLine
Driver for Hire
Updated!
Luan Zeqollari
YouTube Channel
