#197 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Yes, they are a pain in the axx. The 1LEs where easier to install, but 4 hands are better than 2.
#198 | |
![]() Drives: Chevrolet Camaro ZL1 Join Date: Nov 2019
Do you have a picture of the factory ZL1 grille for comparison? Id like to know if it can have slots dremel'd into it to receive the 1LE front splitter. All the tabs on the 1LE splitter and bumper seem to be in alignment, so if the slots in the factory grille have spaces in between, I dont see why not. Thanks |
#199 | |
#200 |
![]() Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
All I know is......
1. It was a PITA! 2. It's over! Welcome to the club...... But here's what I compiled..... ***Pro-Tip*** shove thin popsicle like sticks into every tab of the grill and it just pulls right off in about two yanks. I wish I had done this with every other piece. How to get these bezels out? I am afraid to break these fasteners. Finger strength (The bezels were the toughest, just wait til you put the new ones in they are very hard to press in) especially the lower outside corner, had to use something to press against the bezel, fingers couldn't do it.. You have to work slow... keeping pressure on the part so once you unlock it by pushing up or down, the tab has a lip that has to clear the slot on the fascia... keep pressure on it once it clears or you go to the next one and it locks back in place with out you knowing! Start along the top outside edge and move inward.. then the lower side, starting on opposite edge |
#201 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
ZL1 1/2LE Done, Thanks for the tips
Thanks for all the tips.
My Tips: 1. Get extra fasteners from LB Auto. They sell the white clips and the square nuts for the front spoiler winglets. I thought I had bought a ton of extra white clips, but only had 2 left after it was all said and done (I bought 20). 2. Some of the install requires two people and possibly a rubber mallet with a towel wrapped around it. Make sure all tabs are lined up, before the mallet. 3. I used 5 gallon buckets to become my work bench. It saved my back. 4. A dremel with a routing bit and a small file set make cutting the 6 slots easier. I used painters tape on the painted side to keep from chipping the paint. 5. I kept the stock upper grille and can't tell a big difference even in direct sunlight. 6. The bezels suck. They are an interference fit. Use a plastic trim tool to pry the bezel and I also used an exacto knife to slightly trim the edges of the tight tabs. 1st one took two hours, the 2nd took ten minutes.
#202 |
aka BeastZL1
Pics
Pictures
#203 | |
Another alternative would be to cut off the tabs on the 1LE splitter that there are no slots for......and for those considering.....the upper grill gave me a much harder time than the others for some reason.....probably do to the limited space.....
#204 |
![]() Drives: ZL1 Join Date: May 2020
I want to thank everyone to shim in and help me pulled the trigger on the front end 1le conversion. Pretty much all my questions were met in this post.
One advise though: Don't buy the front the Splitter and lower grille online, although much cheaper than the dealership, the onilne shipping cost from places like GMpartsDirect is astronomical! I saved $379.00 total accounting for the parts price difference. The shipping cost of the rest of the parts purchased online and required for the conversion came down to $59.00
#205 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
#206 | |
#207 |
Drives: 2015 Camaro Z/28 Join Date: May 2019
Complete waste of $. No wonder Americans are so in debt.
#208 |
#209 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Thx for reviving this one Falconer.
Sub'd for reference
#210 |
![]() Drives: Corvette GS w Z07 Package Join Date: Mar 2019
What I have seen, the regular lip and the 1le lip are very similar in total surface and shape.
The big difference are the side winglets. 1LE are very tall compared with almost non-existent ZL1 Those who were brave enough to do the swap alone, can confirm this?
MY02 S2000 > MY11STI > MY01 E46 M3 > MY05 S2000 > MY06 911 C2S > MY88 944 TURBO S > MY17 STI > MY17 SS 1LE > C7 GS w/ ZO7 package > MY18 ZL1
