#197 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
I still struggle with the fact that we have one from the factory. Why is adding another even needed.
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
#198 |
![]() Drives: Chevy Camaro ZL1 Join Date: Apr 2020
#199 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
factory one is "clean side" and being clean the oil that is caught goes back into the engine. the 'dirty' side has fuel and other contaminants in it, so it shouldn't go back into the crankcase. that is why it is burned in the combustion chamber. a dirty side can needs to be drained periodically.......it is the general consensus that the maintenance will not be performed by the average consumer........
there is opinion in this explanation
#200 |
Geoff
It is great to have the ability to have a choice. You probably shouldn't get one.
#201 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I was a skeptic as well, I found oil sitting inside my supercharger when I did my install, my car only had 1900 miles at that time. For $400 I’ll take a chance at keeping oil out of where it doesn’t belong. As far as GM engineers (and other car makers) not building the cars with some sort of catch can if it’s an issue, consider this...... the new GT500 comes with a catch can installed form the factory. BUT, the 350 DOES NOT. Ford will sell you not one, but two of them for your 350 (one for the driver side and one for the passenger side). My point is that, as big of a paradox as it may seem, these cars are not always engineered to the extent they should be, in other words, corners are cut by the manufacturer. Mainly due to cost savings. My purpose is not to try and convince you, I’m only sharing my thoughts since I used to be a skeptic as well.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#202 | |
2019 Crush A10
#203 | |
It is on the front of the block about halfway down on the passenger side. Black box with several hoses going in and out.
2019 Crush A10
#204 |
Geoff
No maintenance required. It separates the oil from the gasses and drains itself
#205 |
Petro-sexual
It drains, directly, back into the oil pan, if I recall.
#206 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
And the CC debate rages on...
Upfront, blow-by is largely NOT oil. It is a mixture of air, burned and unburned gases (sulphuric acid) and oil mist. Over time it contaminates oil causing viscosity to breakdown and left unchecked will foul the intake side of DI engines, robbing power and reducing fuel efficiency. Blow-by is created by compression and combustion forcing liquids and gasses past cylinder rings and into the crankcase. With the LT4 being supercharged, it WILL increase the amount of blow-by over an NA motor. While I do think that some/most of the blow-by glasses are consumed in the combustion process not all of it is and it does accumulate. While I respect everyone’s right to do what they want, for the above mentioned reasons is why I choose to run one. The shite that the can scavenges is nasty stuff. |
#207 | |
Elite Engineering, Thanks to you and a few others here who have presented compelling evidence on the subject, I am now thoroughly convinced that the CC is indeed a worthy investment for anyone concerned about the internal health of their DI engine. After a lot of research, I believe your product to be the absolute best on the market. To that end, I’ve ordered the E2-X directly from you, expected to arrive in a few days. Thank you for your thorough explanation on the various intricacies of how and why CC’s are a necessary component of DI technology. I hope you’ll accept my sincere apology if you believe I was attacking you, I can assure you that was NOT my intent. Thank you, Chris |
#208 |
![]() Drives: Camaro ZL1 Join Date: Apr 2019
Well Said Chris and thank you to Elite as always for facts.
As a side to Elite - this is installed here in the UK
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving... |
#209 |
That is a nice setup you got there !!!
#210 |
![]() ![]() ![]() Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Ordered the Elite E2-X as well, but still have reservations about how it may affect the GM warranty (2019 car)
