Old 02-06-2012, 12:28 PM   #197
MauriSSio
Drives: 1968 Ford Galaxie
Originally Posted by YourBlindingBias View Post
You're acting like the ZL1 isn't held back by traction...
or pretending it isn't at least.
You know that ANY car with 500hp and street tires may have some traction issues no matter the suspension right?
i agree. Both cars are gonna be traction limited. Combined with the gearing (tq multiplication), the ZL1 actually makes very similar power in 1st gear, just that it is for a much shorter time than the GT500 due to running out of breath earlier in the upper rpm range and 3.73's vs 3.31. If you can get the ZL1 to hook you should be able to get the GT500 to hook just as well. or you can make the case the same the other way around with the traction problems.
On the road course you can argue it different ways for each car and technically youd probably be right because its pretty much just speculation for now.
MauriSSio is offline   Reply With Quote
Old 02-06-2012, 02:36 PM   #198
eolson
eolson
eolson's Avatar
Drives: 2006 premium Package Mustang GT cou
Again, there are a lot more than minor tweeks to the 2013 GT500. I agree that Ford should have gone with 305/35/19's in rear giving a tire height of 27.45 and a sidewall of 4.2 inches, same sidewall as the ZL1 on it's 305/35/20's.
But Ford gave in to the giant wheel look of this decade, so thy had to go with the 285's. Drag racers can put phat tires in the back since they don't care about total driving balance like road racers. Erik
2006 Prem Pkg Mustang GT coupe. Saleen SC,10psi, 454rwhp,442rwtq, Complete Steeda/H&R, suspension change out, with weight loss, Techco Watts link, Stoptech big brakes, Race clutch, Alum. flywheel, Alum 1 pc driveshaft, 9x18,10x18 chrome bullit wheels, 285/40/18,255/45/18 nitto 555 tires. 3545 lbs currently. New car scent air freshener.
eolson is offline   Reply With Quote
Old 02-06-2012, 08:14 PM   #199
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by GT5Junkie View Post
Which one of those categories is the CTS-V with the LSA and MR legal for?
As far as I read - all the ones I mentioned. In those classes, if it comes OEM, it's okay.
Old 02-06-2012, 09:18 PM   #200
SIRLOIN
Drives: Ms. Daisy
Originally Posted by ParisTNDude View Post
Well, it happens to have more HP than the 13 GT500 and the same suspension (minor tweaks). As others, including Ford guys have said, the 285 tires are going to be a joke on the 2013 car as they were on the Super Snake. IMO, it's an indicator that a lesser HP car will, um, uh, run lesser times, so why isn't that relevant? If you don't like my posts, skip over them and read someone elses.
Consistant 3.7's 0-60, and mid 11's 1/4 mile reported from multiple magazines...Sounds like traction is most certainly NOT an issue. It has also been reported that the LC/TC is so good, that it will perform as good, if not better than a professional driver. What were you saying about those 285's again???... Saying, "the Supersnake has the same suspension as the 13 Shelby(minor tweaks)"...would be like me saying the HPE Camaro has the same suspension as the ZL1 (minor tweaks)...
Here is some reading material for ya
http://www.caranddriver.com/features...-gt500-feature
P.S. If you don't like this post, skip over it and read someone elses...
SIRLOIN is offline   Reply With Quote
Old 02-06-2012, 09:44 PM   #201
Rock36
I just like V8s
Drives: 2007 Corvette Z06
Can't we just call it a plain ol' SVT Cobra again?
Rock36 is offline   Reply With Quote
Old 02-06-2012, 11:25 PM   #202
GT5Junkie
Drives: Toyota
Not unless they've revised the rule book in the last month. Last time I looked the LSA CTS-V was eligible for none of those classes.
GT5Junkie is offline   Reply With Quote
Old 02-07-2012, 10:26 AM   #203
MauriSSio
that would be ideal
Old 02-07-2012, 11:33 AM   #204
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
I was speculating on the poor drag strip performance of the 2011 Mustang and how much difference an additional 100 HP could make in it's straight line performance. Since the GT500 simply didn't get the drag strip performance down (30 HP less than the ZL1):
2011 Mustang GT500
Car & Driver 12.4
Motor Trend 12.35
Edmunds 12.4
Autoweek 12.3
Road & Track 12.4
Muscle Mustangs and Fast Fords 12.02 (using their best driver and every trick in the book)
Even if the 100 hp brought times down by 4/10s second, we're looking at 12s or about what the ZL1 will do (Motor Trend video today says the ZL1 ran under 12 seconds on a crappy track). It's going to be an interesting comparison. No one has tested the 13 GT500 in production form, so for you to say "multiple magazines say it runs mid 11s" is kinda speculation. The basic suspension for the 13 GT500 is basically the same as the 2011 "with minor tweaks".
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 02-07-2012, 11:47 AM   #205
Stew
Drives: 92 Luminadead/01 Dakota/97 F150 4x4
2011 Mustang GT500
Car & Driver 12.4
Motor Trend 12.35
Edmunds 12.4
Autoweek 12.3
Road & Track 12.4
To me it looks like the 2011 GT500 is running right with the ZL1 (makes sense 30 HP difference, 300 pound weight difference.
Car and Driver got a 12.3 from the ZL1, Motor trend got a slightly better 12.1. Seems pretty close to me, so i don't see how the 13 GT500 with it's added HP, better suspension, and launch control could possibly NOT be quicker than the ZL1????
Stew is offline   Reply With Quote
Old 02-07-2012, 11:54 AM   #206
tooslow
Drives: 4 Wheels, Gasoline Engine
Originally Posted by Stew View Post
?... i don't see how the 13 GT500 with it's added HP, better suspension, and launch control could possibly NOT be quicker than the ZL1????
You must be wearing the wrong glasses. Look around for the rose-colored ones it seems like so many others are wearing these days.
tooslow is offline   Reply With Quote
Old 02-07-2012, 12:01 PM   #207
SS 376
SS 376's Avatar
Drives: 2010 IBM 1SS (Former)
I believe the Mustang Boss, which has 444hp or so, ran a 12.3 or thereabouts as well. So by your logic, the 2011 GT500 should be deep down in the 11s since it has 100+ hp than the Boss. But it's not. So "added HP, better suspension, and launch control" isn't the end-all-be-all. You're welcome to keep on guessing and speculating but that's all it is: guessing and speculation...
SS 376 is offline   Reply With Quote
Old 02-07-2012, 12:06 PM   #208
ParisTNDude
Look for today's post on the Motor Trend test. Motor Trend's best test driver says clearly the ZL1 ran under 12 seconds there's a thread on it. If that's the case, the 2011 GT500 is on the average a half second slower. The 2013 GT500 could very possibly and most probably will be faster than the ZL1...it should be with a huge weight and HP advantage, but not by much. The advantage is that Ford now knows what the performance of the ZL1 is, they WON"T release the GT500 until it beats the ZL1. They did that with the 5.0 Mustang. When the Mustang 5.0 was in it's planned production configuration, it wouldn't beat a Camaro SS and couldn't match the HP...what did Ford do, they added Tubular headers and Ford racing CAI. That gave them the slight advantage they needed. The GT 500 will follow that pattern.
Old 02-07-2012, 12:15 PM   #209
Stew
That was not my point at all, i was simply comparing the times here. Please tell me how better HP, better gearing, better grip, launch control could NOT make the 13 GT500 quicker than the 12? Please answer that? Yes, I am guessing, but that is the fun part and my guess is only logical, to believe otherwise, you will more than likely find, is wishful thinking at best.
Old 02-07-2012, 12:17 PM   #210
TheReaper
TheReaper's Avatar
Drives: 2018 Mustang GT
The times you guys are posting really makes me feel good about 5.0 A6.
TheReaper is offline   Reply With Quote
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17976 12-27-2021 12:07 PM
HOT WHEELS CAMARO CONCEPT SEMA 2011 Debut tribone 5th Gen Camaro SS LS LT General Discussions 116 02-20-2014 03:08 AM
GM Camaro SEMA Press Release JusticePete Suspension / Brakes / Chassis 19 11-23-2011 10:40 AM
Rendering of 2012 Z/28 in New Hot Rod Magazine! Blue Maro Demon Camaro ZL1 Forum - ZL1 Specific Topics 67 09-03-2010 09:09 AM
Hot Rod Power Tour Featuring the Concept Camaro Convertible TAG UR IT 5th Gen Camaro SS LS LT General Discussions 14 09-18-2007 05:08 PM
