#2073 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I understand yours, though, too.
#2074 | |
Honestly, if you’re messing with cams, you better be, at least, considering valve springs and maybe even retainers or valves. Mostly springs... There’s a lot going on there that needs to be considered. |
#2075 | |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
Yeah, those are pretty terrible too....
Indeed, the differences are what makes the car world so much fun...
#2076 | |
Drives: 2013 GB GT Join Date: Mar 2016
#2077 |
...err double post
#2078 | |||
point is as already stated it is NO BIG DEAL whether the long block is "stock", a complete non-issue. The 5.0 is expensive and difficult to work on hence the long block = "stock" on the vast majority of builds. To me and this is just me, I would always build a long block before anything but the most minimal boost. It is just the way I rolll. $1000 is cheap insurance, I wish I added it when I did heads and cam, I did not, as I thought I would be happy with stock P1sc, not really, but happy for a few years. Well it was 1 month before the D1X went on...LOL, stuff happens. Now I'm stuck on "low" boost till the forged engine goes in. Does it need it? Dunno, but I beat on the car and Texas is at 111 degrees so heat is an issue. IMO, at the 700+ RWHP range, a few thousand is just a rounding error. If I did not have $10,000 just sitting around AND a spare car, my Camaro would be stone stock. Quote:
![]() ![]() Quote:
Must be thinking of somebody else, I've already changed my cam by myself, no issues. Don't tell anyone but the pan does NOT have to be dropped. 1) don't pin the tensioner, it can move even further if not pinned 2) pry the chain backwards, not forward . BTW. I don't troll the Mustang sites, but I would be intrested in any 5.2 NA builds, I absolutely love the 350 and the engine.... My dream car is this: https://revologycars.com/car/1966-shelby-gt350/
#2079 | |
Cam, springs, and filter got 58 rwhp on a Vette http://www.superchevy.com/how-to/eng...-lt1-cam-swap/ to my mind it looks like a 7000 RPM engine still AFM compatible. I would have stuck with an AFM cam, but Pray sold me a package with a spec'd cam that was no way AFM compatible. We have all see the 5.0 vs LS3, I don't think the new 5.0 vs LT1 will be all that different. https://www.enginelabs.com/engine-te...-dyno-results/
#2080 | |
So IMO, if the factory springs are still working, you ain't got enough cam and RPM....
#2081 | |
#2082 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
You can get 100 hp gain from a cam
I make more power than that car using bolt ons. That cam swap is a weak as hell example Gains from a cam compared to a coyote isn’t even close. And if one wants to spend the money on pricey valvetrain to really hit some high rpm things get super ugly. You can’t lump cam together as one broad term. Results vary wildly depending on the grind etc |
#2083 | |
#2084 | |
https://www.texas-speed.com/p-5417-t...-camshaft.aspx 110 hp gain from vvt-3 cam. And it’s not there biggest cam nor anywhere near max effort Hills auto car put down 585 rwhp through a stalled auto with his track attack cam. He was at 465 before heads cam. And the converter costs people about 10rwhp. Head porting is worth 20-30 hp. So he gained roughly 100 rwhp from the cam I’d say around 130 hp gain is possible with an average joe. More if you went nutty with a high dollar valvetrain and solid roller. |
#2085 | |
I see BlackIce had to cut the pistons for that cam, did that require a rebalance? |
#2086 | |
P to V clearance isn't great on the lt1. Most of the larger cams require a flycut. Im not familiar with HPAs cam. 40 of that gain was from the longtubes and e85. So it looks like a 60 rwhp cam I guess. Or 80-90 if they had flex before. 60 whp is worth doing for sure. Not sure I would waste the time for 30-40 considering whats involved. Id love to do a max effort heads cam coyote if I owned one. I would just hate how much low end would have to suffer. It would be fun im sure but having nothing down low daily driving or on small sprints would be annoying imo. From what ive seen to put down big numbers with cammed coyote you need 8000+ rpm and nothing at home below 3500 or so. Maybe the newer ones are different. I seen a 600hp + build livernois did that was pretty impressive. |
