#183 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
It does provide a "zip" to the car for sure!
#184 |
![]() Drives: 2017 Camaro ZL1, 6M Join Date: Dec 2019
I've liked what I've read and seen online about this TB so far so I ordered one. Looking forward to the results.
#185 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Sounds like the controller is going to take care of that issue.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#186 |
![]() Drives: 2017 zl1 camaro Join Date: Feb 2019
I run his 95mm one on my setup and it’s amazing what it does for the car. My blower is ported to use a 103mm if I wanted to but my car runs so good on his ported 95mm I have no reason to use the much more expensive 103mm that has been known to not drive that great. My 9.52 was using his throttle body and what I see on my logs I do see an improvement for flow as my maf hz increased on my logs. The way he is cutting them it holds great drive ability and is adding the flow of other companies ported setups. He definitely has something going on with this very unique cut on it. You will even notice you automatic 8/10 speed shift better as it’s increasing maf flow lower tps range which is adding pressure to the trans so making it shift better. That’s just one of the pluses you will get from one of his setups.
9.52@143 first bolt on only car to reach 9.50s. First zl1 in the 9s on stock unported blower. Sbe LME heads gptuning cam typical mods jokerz prototype port blower 9.30@150 best so far work in progress. 4.70 60-130 at 3800da now in Tennessee.
#187 |
The car drives much much better now when pulling away from a traffic light or a stop sign or launching aggressively. I really do appreciate how less prone to bogging the car is on launch now. I drive a manual car; it probably makes an A10 feel like it has more bottom end torque.
Mike from Soler Performance was very responsive to my inquiries during the few hiccups I had during the learning procedure. I recommend this mod. |
#188 |
I installed my throttle controller 2 weeks ago and it makes a hell of a different. The car seems like it gained 100 pounds of torque!
The supercharger wine and exhaust seem louder. Anyone else experience this?
#189 |
![]() Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
Does your whine and exhaust sound louder because your pedal is more sensitive? RPM Racing had a video about throttle controls and basically how they just make your gas pedal more sensitive and to just press the pedal down more if you want to get on it.
I do have a throttle control ready to install just have not took my car out of storage yet. Maybe this weekend this social distance is a good reason to go for a cruise. Just need the weather to |
#190 |
I believe the motor is now taking bigger breaths of air due to the throttle body opening faster and wider. That’s what’s contributing to the louder noises.
Side note, as far as the “you don’t need a throttle controller, just give it more gas” argument. I disagree with that, you’ll see when you install yours. Giving this car more gas in OEM form will never produce the same effect the TC does. I believe the throttle controller tricks the ECM and overrides the stock throttle input tune. Giving these cars more gas pedal in OEM form gets you more of that annoying lag. TC takes care of that completely.
#191 |
![]() Drives: 2018 ZL1 Join Date: Dec 2017
I purchased one of Soler Performances replacement LT4 throttle bodies used from another Camaro6 member. He sent all the original paper work with it. I disconnected the battery, and swapped throttle bodies. Left the battery disconnected for a few hours, and went through the recommended learn procedures. Not a single stumble whatsoever, I did it to improve throttle response, I couldn’t be happier. Much improved. Thanks.
#192 |
RPM had the video and must have had some lower grade cheap throttle control on the car I think it was a Corvette not all are created equal.
I cant wait to give mine a go!! |
#193 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
The Soler Throttle Controller is a game changer. While I have both the TB and the controller, the controller made the most difference in feel and drivability. Best mod I have spent money on.
#194 |
![]() Drives: 2022 ZL1 1LE Join Date: Apr 2019
You've all seen my posts in this thread. The TB and TC are, dare I say, game changing mods for the LT4. Mike's follow up on questions is inspiring. Soler really does understand the science. Very refreshing to say the least!
#195 |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
So after reading all the good things about the TB and TC I want on the Soler website to order, and the TC is out of stock. Does anyone know when it will become available maybe Mike can chime in.
#196 | |
![]() Drives: 2015 Corvette Stingray Join Date: May 2019
TC's will be available by the end of next week. We'll PM you as soon as we update our Webstore inventory.
Tiffany,
Soler Performance LLC, support@solerengineering.com www.solerengineering.com (251) 468-9786 |
