Old 07-01-2019, 04:18 PM   #183
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Is the 500 and 1500mi engine oil change "necessary"? I get the piece of mind aspect. Anything wrong with waiting for 1500mi?
My brother's 2014 1SS, we just changed it at 1500mi. Did a good break in over that period, followed the owner's manual. Never burned a drop, pull some great dyno numbers.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 07-01-2019, 04:49 PM   #184
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
No they're not mandatory, merely recommended.
You will find that most engine builders, engine breaking docs, GM performance guides, and on and on do recommend several early oil changes for engines, and the same goes for rear ends.
Old 08-09-2019, 12:29 AM   #185
Hille
Drives: '18 Camaro ZL1 1LE
Been reading through this thread with some great information, but I have a question about my '18 ZL1 1LE.
In the high performance owners manual supplement it lists Electronic Limited-Slip Differential (eLSD) Clutch System Lubricant (ZL1 and SS with the 1LE package) 5.4 ounces.
I'm ready to do my 1,500 mile rear diff. service and was wondering where to get this fluid. My local dealer never heard of it and suggested the 88900330 limited slip additive. I didn't see this Electronic Limited-Slip Differential Clutch System Lubricant listed on this thread.
Thank you for any insights into this.
Hille is offline   Reply With Quote
Old 08-09-2019, 06:27 AM   #186
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
No need to touch eLSD only engine and differential. And, no additives!
The differential fluid is the easiest change - takes approximately 1.6 qts, just fill until spill. Here is a YT video of what to do: https://youtu.be/c7Nnwgf34HY?t=299
viurniel is offline   Reply With Quote
Old 08-09-2019, 07:24 AM   #187
Hille
OK. Thank you very much for the information.
Old 08-28-2019, 12:10 PM   #188
SWZL11LE
SWZL11LE's Avatar
Drives: '19 ZL1 1LE
Just went through the thread and tried to search the entire forum, but does anyone happen to have the GM part number for the recommended track oil (15W-50) ?
Might be a good idea to add that to the OP.
SWZL11LE is offline   Reply With Quote
Old 09-02-2019, 05:04 PM   #189
Can'tHave2MuchHP
Drives: Fast
Having a hard time finding the right part number for it myself. If anybody gets it, please post it and I will add it.
Old 09-09-2019, 06:50 AM   #190
petek8103
petek8103's Avatar
Drives: 2019 Camaro ZL1
Cool 2019 ZL1
Good morning, I just picked up my new ZL1 last week. Obviously this continues to be of question but the recommend service intervals for the 2019 don't seem to be included in the owners manual.
Nor was my dealer recommending any service interval when the car was purchased.
After reading through previous posts, I see mention of the new oil from Mobile 1. Has anyone been running this for awhile?
Lastly, looking to upgrade the exhaust, any recommendations? I love the crackles and pops of the factory exhaust on track mode but it's just too quiet for my taste.
I see MBRP has exhausts listed for up to the 2018, but when I called them they stated it wont' fit the 2019. Has something changed with the exhaust in 2019 or have they just not "confirmed" fitment. Open to suggestions on exhaust, cat-back for now, not looking to headers at this time.
petek8103 is offline   Reply With Quote
Old 09-09-2019, 07:35 AM   #191
Can'tHave2MuchHP
Drives: Fast
Your car should already have been factory filled with the 0W-40 ESP since it is a 2019. Pop the hood and check what the oil cap says. It's great stuff and there's no reason not to run it as far as I'm concerned. You will only find the 500/1500 mile oil change recommend in the GM performance prep manual, which doesn't come with the cars but is available on the internet. Also, while I was at Spring Mountain, a place that owns over 100 performance GM cars including dozens of Z06s and ZL1s, they said they do a 500/1500 mile oil/diff change on every car, they consider it mandatory and have seen better results when they've done so.
As for exhausts, I would stick with AWE Touring (Don't let the name fool you, it's loud and aggressive) or Corsa (Same story). Don't get a cheap exhaust that's going to rattle and drone away, unless you like that sort of thing.
Old 09-09-2019, 08:18 AM   #192
petek8103
petek8103's Avatar
You would take the AWE touring over the Track version? Also would you go resonated or non resonated. Keep in mind my preference is raspy and I don't mind the decel crackle if not prefer it.
Old 09-09-2019, 08:20 AM   #193
petek8103
petek8103's Avatar
After the initial 500/1500 rear diff change, what is the recommendation on mileage before next diff change. I'm assuming the transmission fluid change isn't required during these?
Old 09-09-2019, 11:46 AM   #194
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Those of us with verts that have the standard (non-E) diff are scheduled every 72k miles per the manual.
This thread seemed to settle on changing diff fluid for ZL1 coupe and ZL1-1LE:
* After break in @ 1500mi
* Before 1st track day
* After 1st track day
* Every +20 hours on track
https://www.camaro6.com/forums/showthread.php?t=509857
Track prep guide is here:
https://www.camaro6.com/forums/showp...86&postcount=4
Old 09-09-2019, 12:10 PM   #195
Can'tHave2MuchHP
Drives: Fast
I personally would go Non-Resonated Touring with Performance link Pipes. Or Corsa Cat-back either Xtreme or Xtreme+. I think Corsa may be more raspy. Both have decel pops but the ZL1 is light on those with the stock tune.
Old 09-09-2019, 12:12 PM   #196
petek8103
petek8103's Avatar
Guys, I appreciate all the feed back! Thank you!
