Old 09-04-2018, 09:10 PM   #183
ecko04
Drives: Too many to list
I did not install them today. However, I did wire put the fiberglass wrap around the hot components. There’s a 50w 7.5ohm resistor for the backup light and a board for the electrical sequencing that was wrapped in shrink wrap that I didn’t bother with other than putting fiberglass wrap around it.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 09-05-2018, 11:28 AM   #184
ecko04
Alrighty, after a long wait, the revised harness does the trick. No more hyperflashing! If you have LED bulbs in your front turn signals, you still need resistors for those.
No hyperflashing and no lingering reverse light. All is resolved with the new harness. I wrapped mine in finerglass wrap to help with any heat issues. Other than that, with the new harness, they’re plug and play.
Old 09-05-2018, 04:15 PM   #185
sonikk71
sonikk71's Avatar
Drives: 2017 Summit White V6 1LE
Do you know if the new harness also works for us LT/LS non RS/SS owners? Anything extra needed for us?
sonikk71 is offline   Reply With Quote
Old 09-05-2018, 04:38 PM   #186
ecko04
Everyone should opt for the modified harness regardless of trim.
Old 09-05-2018, 05:03 PM   #187
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
So what web site do we need to go visit for these lights and harness?
warren3537 is offline   Reply With Quote
Old 09-05-2018, 11:47 PM   #188
sonikk71
sonikk71's Avatar
Right. When you say modified harness do you mean the new VLand harness or the Gen5diy harness? I am just just wondering if I will still need to buy the Gen5diy harness.
Old 09-06-2018, 04:31 AM   #189
H(.)(.)ters
H(.)(.)ters's Avatar
Drives: 2SS - Black
Will the harness be pre-installed from the seller?
Procharger D1X
Kinda fast, I guess
H(.)(.)ters is offline   Reply With Quote
Old 09-06-2018, 05:49 AM   #190
ecko04
No longer need the Gen5DIY harness. I removed the reverse light harness that I had. TBH all VLand needed was 1 resistor for the reverse light but they included one on each harness. At any rate, it works.
Old 09-06-2018, 07:46 AM   #191
Sheriff37
Do it for Dale
Sheriff37's Avatar
Drives: '16 NFGray V6 M6
Thats great to hear, I hope we will be seeing some installation pictures from you soon. Thank you and anyone else who guinea pig'ed these for everyone!
Sheriff37 is offline   Reply With Quote
Old 09-06-2018, 08:15 AM   #192
ecko04
New rear tail lights
See post 149 for videos
No installation pics as the install is exactly the same as the GM dark tails install videos available on YouTube.
Old 09-06-2018, 08:09 PM   #193
sonikk71
sonikk71's Avatar
The video link in post #149 isn't showing for me.
Old 09-06-2018, 09:15 PM   #194
ecko04
You can’t view it from your phone using Tapatalk. You need to use the desktop version.
https://www.camaro6.com/forums/showp...&postcount=149
Old 09-06-2018, 10:55 PM   #195
Sheriff37
Do it for Dale
Sheriff37's Avatar
Well I really meant pics of them installed, I just grouped all of them under the same category . Glad to hear that it's the same as that install, super easy process.
Old 09-07-2018, 03:39 PM   #196
sonikk71
sonikk71's Avatar
Not showing for me on my desktop or phone or any other device. I did click reply and check your tags. Turns out you used [img] tags. Thats probably why it wasnt showing.
Here lets try this...
https://i.imgur.com/BVA2cg2.mp4
Hyperflash
https://i.imgur.com/Obc1fmC.mp4
Hazard + Running Lights
https://i.imgur.com/gkImVzP.mp4
Brake Light
https://i.imgur.com/RmQemZ7.mp4
Running Lights + Brake
https://i.imgur.com/jahw103.mp4
