#183 | |
I believe it went both ways. When I had this no one really paid much attention to it until more and more started reporting in. I listed a few of the threads here for reference. https://www.camaro6.com/forums/showthread.php?t=500793 |
#184 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
It is likely the rear cradle swinging side to side as the factory bushings have a ton of slop in them. yesterday at Mir my car wasn't exactly perfect with the cradle lockout installed but I could make it go down the track straight with corrections. There was also in nasty 15mph crosswind compounding the straight line stability. My 5th gen ZL1 never had any of those rear sway instability issues.
#185 |
I haven't foudn the Camaro 1LE to be that bad in the rear, my Mustang was very bad with slop in the bushings and wheel hop it was pretty dangerous and almost spun it out more than a few times. I had to put in about a Grand worth of Steeda parts under the rear to get it under control.
So we're using the BMR lockout for this on the Camaro??? |
#186 |
Yes, BMR lockout kit
#187 |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Ran at Beech Bend the other way, and she was going side to side pretty good. Obviously some wheel spin due to the cold track temps, but it was a bit sketchy. The whole BMR rear kit is on my Christmas list this year.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
#188 |
![]() Drives: 2016 Camaro SS Join Date: Jan 2016
For those of you who say you fixed this with a 4-wheel alignment:
Did you have the dealer perform it? Or did you go to NTB or some tire shop?
2019 Camaro ZL1 6M, Crush
#189 |
![]() Drives: ZL1 1LE Join Date: Jul 2020
Sorry to revive an old thread, but did anyone figure this out?
I just got my car an 18 ZL1 1LE with a Magnuson Heartbeat blower upgrade, but still well under 700 whp. I've driven it a couple times and this feeling is very unwelcome. So far I love the car other then this issue. I was very surprised passing at 80 when I rolled into it about 50% throttle and changed lanes. Changing lanes while passing on the highway is by far the worst and it's even happened while the car's in 6th gear, so it def def not wheel spin. But it's bad enough to have to counter steer through and I let off. It gives the sensation that the rear toe is changing under load, but like others said it's strange because it's not consistent. I had already chalked it up to the E-diff and looks like others have suspected that as well. I'm going to get alignment specs checked but this car was supposedly aligned by a race shop prior to buying it. Car is on MPSC2 tires in stock Zl1 1LE sizes |
#190 |
This is the only BMR part I DON'T have, but it might be the one to put a nail in the coffin of the problem.
https://www.bmrsuspension.com/?page=...628&superpro=0
#191 |
To fast is not enough
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo Join Date: May 2019
You got to have same or close to the same air pressure in all tires, Low air pressure will make it sway. I don't have that problem all tires are equal. Soft compound in the back will also do that.
#192 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
This must be an edif issue. I've got ZL1 takeoff wheels and tires and a good bit more than stock ZL1 power. I have the ZLE solid cradle bushings but did not have this issue with the original parts
Baby Blue
#193 |
![]() Drives: 2019 Zl1 Vert Join Date: Aug 2020
2019 Zl1 running stock my car did the same thing changed rear tires to 315/30/20 Toyo R888R still the same thing Im put down 895rwhp
I took the car in to do 4 wheel alignment and my problems are solved. Car now pulls straight down the road My front left was off by 0.20 and my rear right was off about the same |
#194 | |
#195 |
Mine does the same thing and I have Eibach springs, make sure your in track mode and it's less noticable. I'm also going to install the oem zl1-1le craddle lock out bushings very soon. I'll report back with the results.
#196 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
I’m getting an alignment next month... I’ll follow up with results.
