Old 06-14-2017, 08:59 PM   #183
brettman
Drives: 2016 Camaro SS
No, 3.5 is not that, unless I'm leaking like a freak, or dyno is screwed. But NO actual. (no real hard numbers). 6psi is UNEXCEPTABLE.
brettman is offline   Reply With Quote
Old 06-15-2017, 11:41 AM   #184
brettman
Dealer can't clear code, unless GM gives them an access code. Great, can't re-flash, WTF.
No matter right now, thing runs great....LOL
Old 06-15-2017, 07:52 PM   #185
nick_casper
nick_casper's Avatar
Drives: 16 2SS
Mine makes 8 PSI with a 3.25 pulley at 5800 feet - exactly what it should. I think stock kits are getting 8 to 9 psi at sea level DA. Your other mods will lower your boost a bit from stock. If the fuel system supports it you may be able to go to a smaller pulley and really crank it up. Your builds getting real now. You'll be kickin ass soon.
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 06-17-2017, 09:20 AM   #186
brettman
I knew I'd loss some boost. As far as HP and TQ with the 3.5 pulley might be better now. They seem to run better on 8 cylinders rather then 7. Tuner left a plug wire off (good help is hard to find)
Now is the wobbling input shaft, then I'll drop to 3.125 pulley.
https://youtu.be/_AyKyJegfj0
Old 06-22-2017, 06:57 PM   #187
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
How's it going? Enjoying the ride?
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 06-22-2017, 09:30 PM   #188
nick_casper
Drives: 16 2SS
You're gonna need a tire solution before you go to that 3.125 pulley. I can't hook up without your headers and custom tune. How's it coming along Brett? Are you melting asphalt yet?
Old 06-22-2017, 09:32 PM   #189
Joe's_cool_1le
You guys running 305s in the rear?
Old 06-22-2017, 10:33 PM   #190
nick_casper
Drives: 16 2SS
I still have the SS 275's and can blow them into smoke at highway speeds. Once these go bald I'm going with the ZL1 or 1LE replica rims and 305 or 315 in something that hooks up better than the stock run flats.
Funny story, I had a WRX all stickered up hopping next to me insisting on a roll race. I punched after him and left a rolling cloud of smoke for a good hundred yards as I blasted by. He had to emerge from my smoke cloud wide eyed with his mouth literally hanging open. ( This was in Mexico ).
Old 06-22-2017, 10:37 PM   #191
Joe's_cool_1le
Haha... That had to be a sight. Yeah man.. could imagine having anything less then sticky 305s.
Old 06-22-2017, 10:46 PM   #192
nick_casper
Drives: 16 2SS
Tires will make a huge difference. That's why I was suggesting to Brett to start figuring on a tire solution. We can fit a 315 on the 11" rim by moving a wire harness with minimal rubbing. That should change my car from a smoke generating machine to an honest performer.
Old 06-23-2017, 12:37 AM   #193
Hyper SS
Hyper SS's Avatar
Drives: 16 Camaro 2SS
I run 305 Mickey's, 30psi. They hook like mad!
Hyper SS is offline   Reply With Quote
Old 06-23-2017, 05:38 AM   #194
brettman
Well guys, still NOT a lot of joy yet. P/U car from dealer today. Butt heads didn't tie back the electrical harness laying on the headers...lol. They had to see it (under the radiator res) Now it does back for them to repair wiring. Then SC goes back to be fixed (wobble) I'm trying to get Whipple to send a stripped housing. Then I'll transfer parts, and reinstall. This has been the job from hell, I regret doing it (NOTE TO SELF: ....self, leave it alone)
Tires? I thought about the 305s, I thought wheel well mod for 315s??????
305s will fit without mod???
Old 06-23-2017, 12:00 PM   #195
Hyper SS
Hyper SS's Avatar
Yes. I run them on my stock 9.5in. Just relocate wiring harness.
Old 06-24-2017, 06:10 AM   #196
wnta1ss
Drives: 2017 Camaro 1SS
I've talked to a Whipple owner and he said his car is getting 9 psi, even with headers. Car (M6) showed 612hp on the dyno; the same guys dyno tested my stock A8 at 395hp for some reference on what that number means. His car is tapped out on fuel supply (regular SS not a 1LE) so my opinion is, you should upgrade your fuel system before trying 12psi at low altitude. We are at low altitude here.
