Old 09-07-2022, 09:21 PM   #1835
travislambert
Drives: '17 ZL1
Originally Posted by 5.M0NSTER View Post
Exactly.
So I rest my case once again. Let Luan do his thing. Case closed.
Is there anyone smarter than you around who could read the posts and explain them to you?
travislambert is offline   Reply With Quote
Old 09-07-2022, 09:24 PM   #1836
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Originally Posted by travislambert View Post
Is there anyone smarter than you around that you could have read the posts and explain them to you?
Clearly not. Need someone to tell you when to stop talking?
5.M0NSTER is offline   Reply With Quote
Old 09-07-2022, 11:22 PM   #1837
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Travis, I don’t have any issue with you occupying the #1 and #2 slot. It does not affect me one way or another. I will re-add your time to the board. This is supposed to be fun and informative. Not worth all this hassle.
For the other 3 or 4 I deleted, they can reach out to me via PM and I’ll re-add. I don’t have a change log. I’ll get to this tomorrow some time. Apologies for any issues I have caused.
We will leave the list as-is.
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 09-08-2022, 10:45 AM   #1838
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I'll throw in my 2 cents. I think letting people put in an unlimited amount of entries is pointless. No one wants to see someone's name up there 10 times for the same car on the same track.
I think if your car is not mostly stock your time should be deleted, just kidding.
It probably makes sense to limit it to 1 time per type of tire. I don't see the issue with having 2 times up there if 1 is on slicks the other is on regular tires that seems like pretty good information. The problem comes in when people mod 1 thing and post a new time. Maybe limit entries to 2 per driver per track config.
Christian1LE is offline   Reply With Quote
Old 09-08-2022, 12:14 PM   #1839
FollowMyLine
Driver for Hire
Originally Posted by MechanicalEng View Post
Track= Pocono International Raceway N/S Option 2 (2.26 Miles)
Elapsed Time = 1:41.22
Year / Model / Trim = 2022 Camaro SS 1LE 6sp manual
Date = 8/15/2022
Tires = OEM wheels and tires (Goodyear)
Mods = GM track alignment and DTC60 pads and SRF brake Fluid
Please let me know if this is the same as the Double Infield Configuration
Luan Zeqollari
YouTube Channel
Old 09-08-2022, 12:19 PM   #1840
FollowMyLine
Driver for Hire
I can certainly appreciate what you're saying. I suppose that policy must have changed at some point since I do have multiple times already posted for a ZL1 at PittRace, one being stock and the other being modified.
It's going to get convoluted regardless. I'd also argue that a tire can and often does make more difference than ZL1 vs ZL1 1LE or SS vs SS 1LE. Most modifications people list make very little, if any, lap time difference. Tires are a huge factor though. There's a lot of value in seeing differences in lap time per tire with all things equal due to classing differences at times events. Or, perhaps someone might just want to see the best lap time achieved on a particular tire at a given track.
I don't know. Lots to consider. I'm thinking there is value in keeping multiple times when the tires are different if the list is to serve as a point of reference. If it's just for bragging rights, then maybe a 1 entry per person per track makes sense. Just my 2 cents.
I now actually own a 23 ZL1 1LE and I have an 23 SS 1LE on the way. I'll be starting to track these other cars soon. I suppose we'll see what works out going forward.
All times have been updated. Travis your times have been re-added to PittRace. I'm looking forward to seeing what the 2023 cars bring.
Luan Zeqollari
YouTube Channel
Old 09-08-2022, 12:20 PM   #1841
FollowMyLine
Driver for Hire
And a picture to go along with the lap time. I guess jumping the "jump" is inevitable at speed.
This may be one of the best "jump" shots from Grattan I have seen yet. Well done! I need to get back out there.
Luan Zeqollari
YouTube Channel
Old 09-08-2022, 12:52 PM   #1842
MechanicalEng
MechanicalEng's Avatar
Drives: SS1LE
Hi, it is the same but officially Pocono Raceway calls it N/S Option 2.
Thanks a lot for keeping these times, I really appreciate it!
MechanicalEng is offline   Reply With Quote
Old 09-08-2022, 12:57 PM   #1843
FollowMyLine
Driver for Hire
Thanks for the quick response! I’ll get it updated a bit later today.
Luan Zeqollari
YouTube Channel
Old 09-08-2022, 01:34 PM   #1844
FollowMyLine
Driver for Hire
Updated
Luan Zeqollari
YouTube Channel
Old 09-08-2022, 05:52 PM   #1845
LESS1
Drives: Chevy Camaro
Luan no worries and thank you for taking the time to do this for the community. We appreciate your time and effort in keeping this excellent resource up to date.
LESS1 is offline   Reply With Quote
Old 09-09-2022, 08:15 PM   #1846
cdb95z28
cdb95z28's Avatar
Pitt Race Full Course
1:56.76
2022 1SS 1LE A10 BCD Brakes
9/2/2022, 84*F
OE F1 SuperCars
Track alignment
"KEEP THE FAITH"-Fbodfather
Old 09-09-2022, 09:16 PM   #1847
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
simply...if someone makes an improvement with their exact car on the same tires at the same track (& configuration), the fastest time should remain and the slower time/entry should be deleted. This is just my opinion as all of the data will be fresh and the best for observation & analysis.
Old 09-09-2022, 11:29 PM   #1848
cdrptrks
cdrptrks's Avatar
While we are making suggestions, it would be beneficial for the post template to add the ambient temperature, time of day, and cloudy vs. clear skies (since that affects track temperature) to help give a better idea of how optimal the track conditions were. Humidity and/or DA might be useful too but idk if anyone normally bothers to look at those. Track conditions can currently be estimated based on reviewing the video for any clouds and the sun position plus looking up historical weather for the date.
For example, at MSR Houston going clockwise, the fastest lap I could manage on the same set of tires with the same car setup on an 85°F sunny afternoon was about 3% slower than my overall personal best that I set about 3 months earlier on a sunny morning around 9am when the ambient temperature was about 50°F. A little over a month before that PB, my previous PB was just 0.003% slower. It was set near sunset when the track temperature was cooling off even though the ambient temperature was a bit warmer at 61°F.
Basically it is not a fair to directly compare a lap time set in the middle of a hot sunny summer day to one set on a cool day especially if track temperature was also lower due to clouds or time of day (early or late) because the available grip and horsepower are lower on the hot sunny day.
