Old 01-20-2020, 06:23 AM   #169
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
LPE supplied this insert to make the swap a little more appealing! part number #L850212017
Pretty simple install I added a pic to show the comparison of the way that Redline did their's in that article that came out last year vs how LPE does their's.
Edelbrock hooked me up with a new lid and now I can install my Kong badges with no rubbing. I cut short knowing I would do the insert eventually. That's what led to the rubbing.
Old 01-20-2020, 06:48 AM   #170
Markoz28
Drives: 18 ZL1 nightfall grey A10
That piece does look good but you really should clean up the edges of metal that you cut on the hood. Make sure to seal them so the paint doesn’t lift and corrosion sets in.
Markoz28 is offline   Reply With Quote
Old 01-20-2020, 07:02 AM   #171
2ltrgsr
AXLERODZL1
2ltrgsr's Avatar
Drives: 2019 Riverside blue ZL1 Camaro
I brought this up on the ZL1 group on FB. I just have a hard time seeing a ZL1 get cut up.
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout
Roto-Fab Big gulp
103 TB
Lingenfelter Lower Pulley(9.17)
1 7/8 ARH headers and Exhaust
Meth injection(single nozzle)
733whp/788tq
2ltrgsr is offline   Reply With Quote
Old 01-20-2020, 08:18 AM   #172
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
To answer your question/statement. Here and FB.
Well it was crap ton cheaper than going the maggi non cut route using e85 only no meth for fueling at the power level I wanted to be at. I wanted to fill up on 93, e85, or both and not worry about it. I drive my car not trailer it to the track.. For instance in march we are going to San Antonio.. If I went the maggi way I would be taking cans of meth or having to source it when i got there (LT4 fuel system w meth for 1000 rwhp).
Seems like a no brainer to cut the hood now, right?.. Before someone mentions it ya I saw GPI is working on a port kit all ready. But as I stated before the the maggi is 1200.00 more than the eforce initially, Then 200 for a snout, then the port injection cost $$$ from GPI?
or I have the option of the Fore and XDI DI system for about 15k w labor to fuel it like I want to fuel it..
Nah I'm cutting the hood!
what else ya got?
Old 01-20-2020, 09:57 AM   #173
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
You forgot about the coil relocate or $$$ of new valve covers. The end of the day, the eforce is significantly less $$ and has more fueling choices.
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 01-20-2020, 10:56 AM   #174
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
I’d like to see a picture of the top of the hood all finished.
Old 01-20-2020, 12:45 PM   #175
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Okay I was all by myself yesterday no help to put it back on wife and kids be home today so I can put it back.
Old 01-21-2020, 07:46 PM   #176
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Top pick nothing changes
Old 01-21-2020, 08:04 PM   #177
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Turns out I gained some room by adding the insert
so I installed the 19mm spacer i had been using a 3/8 spacer.
Could probably run a 1 inch spacer if I cut the hood like gotswap and used no carbon insert but, you would need to make these suttle changes. See pic.
Here are a few pics of the spacer. If you want one call Western Metals in Houston tx they have my cad file under my name less than 30 bucks can make any thickness.
I may have one made out plastic so I can stop some transfer of heat.
Old 01-22-2020, 08:44 AM   #178
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Sheesh!!! You're really getting into it, HAHAHA. KUDOS to your bravery. I DO hope it comes out how you want it to.
'20 ZL1 Black "Fury"
Old 01-22-2020, 08:52 AM   #179
Scottyz
Scottyz's Avatar
I like that it still looks factory on the outside.
Old 01-22-2020, 09:05 AM   #180
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Thanks Man!
I'd like to say I'm done but I have the Carbon Fiber tipped Borla Atak system on the way, I still need a carbon rear diffuser(need the Chinese New year to end), and trunk mount reservoir to install.
Old 01-22-2020, 11:08 AM   #181
gtfoxy
Drives: '21 Wild Cherry ZL1
I’d like to see some numbers comparing various spacer heights.
If I was in your shoes, & I wish I was, I’d go as much as a 2”-3” spacer in say .5” increments to really evaluate runner length impact. May not fit under the hood but for research purposes on the Dyno the hood could be removed for testing.
Either way, love the car & what you are doing.
Also, have you considered an inter-chiller?
Old 01-22-2020, 12:17 PM   #182
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
That was the plan, I had 3/8, 1/2, and 3/4 spacer. The plan was to test all these parts along with the 103 vs the 112mm TB.. Just ran out of time I was down 10 months and wanted the car back.
I plan to do some more testing with Vararam Industries on the 6 gen intakes they have a 5 inch intake that looks promising I picked up 42 rwhp now that I'm back and running with unlimited fuel I'll see if Patrick want to start testing again and I'll see if we can test spacers..
I really don't want to mess wit the AC system. I do have a tank for trunk that i need to install and a EMP stewart pump. I made mine a little different...
