Old 05-23-2017, 11:13 PM   #155
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Roto fab looks like a very good option. Sooner rather than later.
Evolvedx27 is offline   Reply With Quote
Old 05-24-2017, 12:02 AM   #156
ELS1
Drives: N/A
Originally Posted by hawk02 View Post
Found this over on the HP Tuners forum. It's a 2016 SS with a magnuson supercharger that repeatedly hits a limiter at 5700 rpm. The cause turned out to be the rubber inlet tube collapsing.
https://www.hptuners.com/forum/showt...r-at-5-700-rpm
If this is the case, perhaps there is a manufacturing defect on certain batches? I wonder what the short term fix from GM will be if that's not the case...maybe they'll release their "performance" intake to solve the issue. Nice find!
Modded 99 Z28 - Gone
ELS1 is offline   Reply With Quote
Old 05-25-2017, 03:22 PM   #157
dcosta
dcosta's Avatar
Drives: 17 ZL1 6M
Found it!!!!!!!!!
We have found the problem with these two cars that is cutting out at wot!!!
The op with chime in to inform you soon to what GM has said..
But we both already knew just needed confirmed..
DCosta9
dcosta is offline   Reply With Quote
Old 05-25-2017, 03:56 PM   #158
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
cwebster is offline   Reply With Quote
Old 05-25-2017, 04:15 PM   #159
ssrallyred
ssrallyred's Avatar
Drives: 2017 Summit White ZL1 M6
Just spill it brother
ssrallyred is offline   Reply With Quote
Old 05-25-2017, 04:17 PM   #160
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Is there a YouTube video that we're going to have to click on to find out the answer?
Old 05-25-2017, 04:21 PM   #161
Zepp
Zepp's Avatar
Drives: 2017 Camaro 1SS 1LE
2017 Camaro SS 1LE - Garnet Red
Zepp is offline   Reply With Quote
Old 05-25-2017, 04:49 PM   #162
dcosta
dcosta's Avatar
Drives: 17 ZL1 6M
No this is his post and he is a very nice person..
I could do it on mine but I will let him inform you all.
We found it before the dealer did or a least my dealer for sure.
DCosta9
Old 05-25-2017, 04:50 PM   #163
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 05-25-2017, 05:00 PM   #164
ORLYHPD
C.O.T.W. 10-27-2014
ORLYHPD's Avatar
Drives: 2017 zl1
just start your own thread then and tell us
lol
ORLYHPD is offline   Reply With Quote
Old 05-25-2017, 05:21 PM   #165
dcosta
dcosta's Avatar
Drives: 17 ZL1 6M
Originally Posted by ORLYHPD View Post
lol
I do already
Rev limiter hits at 5000 to 6000 rpm,,,,,
lol
DCosta9
Old 05-25-2017, 05:34 PM   #166
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Just say it... Not a big deal
Old 05-25-2017, 05:45 PM   #167
SkunkJunk420
SkunkJunk420's Avatar
Drives: camaros
SkunkJunk420 is offline   Reply With Quote
Old 05-25-2017, 05:49 PM   #168
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
Mystery Solved
Well, I think we have solved the problem. After having the "black box data recorder" for the last couple of days and duplicating the issue, here is what the engineers have found. There is a sensor in the clutch pedal that will cut the spark to the engine if your foot touches it while under WOT. It is apparently VERY sensitive and you CANNOT touch the pedal with your foot while under WOT or the sensor will cut power at 5100 RPM's. The engineers have designed this as a safety measure to keep from over revving the engine. He explained that this a very powerful engine and very expensive to warranty. So they made this safety feature very sensitive. An over revved engine would NOT be covered by warranty. So you must keep your foot off of the clutch until you are about to shift, the slightest of contact with the clutch pedal while at full throttle over 93% depressed will cut the spark and power to engine. You don't even have to press the pedal at all, just resting your foot on clutch pedal in anticipation of next shift will activate sensor and cut power. I wasn't sure I believed them at first because I have had multiple stick shift cars over the years and I am driving the same as always. They said they understood, but most cars are not set up like the ZL1. So I went out and tested the car and put it through multiple hard 0-60 pulls with my foot OFF of the pedal and it never cut power. I tested again resting foot on clutch pedal and bingo, cut the power at 5100 RPM's. He said it was the third known case recently that they have put a data box on and all had the same results. It makes me wonder if it is TOO sensitive? I would like to thank the dealer, GM Field Engineer and the GM engineers who analyzed the data. The were very courteous and determined to get to the bottom of it. Also, Dcosta, on this forum for figuring out the issue before the engineers could confirm. I guess I will need to adjust my driving technique from here on out.
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
