Old 06-28-2017, 08:00 AM   #155
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
Originally Posted by glamcem View Post
I also ran off track once and bent one of the front wheels as I went over the concrete bumps but it passed the test! It didn't break but just slightly bent as I would expected from a forged rim. Total cost of that mistake = $250 :P Since it looks like it's repairable I will keep that as a spare
What no* PDR footage of the off?
JK man glad it wasn't serious and only a bent rim out of it. Great thread so far.
RXtacy is offline   Reply With Quote
Old 06-28-2017, 03:37 PM   #156
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by RXtacy View Post
What now PDR footage of the off?
Thanks
glamcem is offline   Reply With Quote
Old 06-28-2017, 10:09 PM   #157
hzycamaro
hzycamaro's Avatar
Sure. I would go with at least -2.0 camber up front and -1.5 camber in the rear if possible
Is it because of your experience? Or simply the more negative camber, the better?
hzycamaro is offline   Reply With Quote
Old 06-28-2017, 11:11 PM   #158
glamcem
glamcem's Avatar
both from experience and because tire manufacturers recommend at least -2.0 camber for track use (many suggests -2.5 or even -3.0). GM Performance supplement also recommends -2.0 F and -1.5 camber for track. It is very easy to destroy tires from the outer edges without sufficient camber
Old 06-28-2017, 11:52 PM   #159
hzycamaro
hzycamaro's Avatar
Thanks, I see. I'll see if the camber can be adjusted to -2.0 and -1.5 after I have the new wheels and tires on my car. What about driving on the street with track alignment? Will that cause problems on the inner edges?
Old 06-29-2017, 01:30 PM   #160
glamcem
glamcem's Avatar
I personally wouldn't mind driving with -2.0 camber on the street even if this was my DD. I am at -2.9 camber up front now. It may cause premature wear on inner edges in the long run but that would be least of my worries since tires will be long gone before that due to track use.
Old 07-03-2017, 02:34 PM   #161
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Hey Cem! Just curious; how many days do you have on your DBA rotors, and how are they holding up compared to the stock rotors?
Cheers,
Ryan
Old 07-03-2017, 08:09 PM   #162
glamcem
glamcem's Avatar
Cheers,
Ryan
rotors feel and look pretty good after two events. I have to note the last two events were definitely warmer than the first two.
and here's how to OEM rotors looked after two events . I will take some more pictures after Wednesday's event
Old 07-04-2017, 04:30 PM   #163
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Thanks for the update!
Old 07-06-2017, 02:39 AM   #164
glamcem
glamcem's Avatar
sure!
Old 07-07-2017, 03:14 PM   #165
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
How wide is the zo6 flare add on? I'm curious to see if it would completely cover an 11" front.
seanblurr is offline   Reply With Quote
Old 07-08-2017, 03:25 PM   #166
Dwille
Drives: 2022 SS 1LE
Just finished reading this whole thread. AWESOME. Thanks for documenting all of your hard work!
Dwille is offline   Reply With Quote
Old 07-08-2017, 08:06 PM   #167
glamcem
glamcem's Avatar
It looks like it sticks about 3/4" (~18mm) from the wheel lip so if the 11" wheel is about the same offset with the Oem Z28 it should cover I think. That's with the -2.9 camber though and the bottom portion may poke out slightly
Sure, Glad you liked it
Old 07-09-2017, 02:11 PM   #168
glamcem
glamcem's Avatar
slicks and the spare set of rear tires (NT01-325/30/19) arrived. Pirelli DH slicks mounted on the new wheels
These Michelin tire bags are great They do a good job covering the wheel lips for eliminating scratches ..etc
