#155 |
#156 |
I could tell my second set on the top spring was much better then the first. It fit the mount correctly. I rides pretty good, but it is a lowered spring and my 15ss with bmr's road just about the same. I like them a lot and have about 100 miles on them since installed yesterday. The cornering is really stellar, it just looks great and sorry I haven't gotten pictures up yet. I have been very busy at work.
#157 | |
#158 |
I will soon.
#159 | |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
A more proper solution would to relocate the connection point at the control arm to be more distant form the arm pivot axis thereby allowing the reduced travel with lowering springs to result in the same total movement at the sensor. I haven't seen these rods so am not sure how the design works but I assume its a simple link ala swaybar end link to a sensor providing suspension travel feedback to the the MRC and stability control systems. I wonder if the GM kit for MRC will include a software flash recalibrating the MRC to the new ride height? |
#160 |
coiloverssssssssssssss
#161 |
Retired from Car mfrs....
I don't think they're available yet for the Camaro, but I am very surprised that this isn't talked about more here as a solution.
#162 | |
SABIO
$250 is better than $2500. Most are going for a look not superior performance. I'm in for coilovers.....if under a grand.
#163 | |
) will be a little pricey because they will track the crap out of them.
#164 | ||
Right, waiting to see if anyone has a set.
#165 |
![]() Drives: 2016 Camaro SS Join Date: Apr 2016
There's a few mfg's working on coil-overs. I may pick up some springs in the mean time just to fill that gap (pun intended).
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad 91 Miata 1.8 Feal Wilwood Track Car 1morproject |
#166 |
ok. I just ordered them. Hopefully the updated version arrives.
#167 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
#168 | |
I'm up in Lancaster. About 2 hours from you.
| Tags |
| camaro springs, lower, lowering springs, phastek springs, springs |
