05-22-2011, 06:32 PM | #155 |
Drives: 2010 SS/RS M6 Inferno Orangle Join Date: May 2011
What's the best center section option? I had a drag car once before that had a truetrac in it, it worked great but made a "linear" gear noise at 50+ MPH. I like this 9" kit, but it's got to be close to as quiet as the stock unit before I'll consider it.
05-22-2011, 07:27 PM | #156 | |
Drives: 05 GTO Join Date: Jul 2009
Or you can't go wrong with a Moser modular iron case with a wavetrac, more money but the wavetrac comes with a lifetime warranty. We designed our 9" kit to bolt right in with the Strange Pro Iron case. Thanks Chris |
05-22-2011, 08:07 PM | #157 |
INTHECLOUDS
Drives: 2010 2SS/RS Join Date: Aug 2009
No noise with the moser/wavetrac...You do have to do some minor metal trimming to fit that monster in there.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA www.6l80tuning.com www.6l90tuning.com |
05-22-2011, 08:29 PM | #158 |
INTHECLOUDS
Official Install Writeup
Like I posted earlier the entire swap took about four hours, but I've done this before. It's actually harder to disassemble. Since the new axles come in multiple pieces, I took all the stock stuff out then put the suspension back together before any 9" stuff went in. Some of the pluses are ease of assembly and custom pieces. The minuses are: much heavier than stock, trimming of the cradle, and the custom tranny yoke requires you to cut off the little alignment stub on the output shaft. If you don't go with the custom yoke and use the adapter no cutting is required. I did not mind the mod, as I never plan on putting the stock carrier/driveshaft back in. I did/do have some driveshaft issues, but Chris is all over it and I expect it will be resolved this week. I do need to remove and tweak my exhaust as the big driveshaft and my three inch tubing are less than an inch apart in some areas. Overall I'm very pleased. It performed well at the track with no vibration and is very quiet going down the highway. I believe I buggered up an outer axle seal during install as I have a pretty good leak on the passenger side. I do plan on pulling the carrier back out this week to swap out the gears and fix the leak. The 3.5 gears are not aggressive enough for the NA car, a whole 3/10s slower compare to the 3.70s. I'm going to put in some 3.89s so I'll update when I run those.
05-24-2011, 07:56 AM | #159 |
Drives: 2005 silverado ss 2010 camaro ss Join Date: Feb 2011
Thanks wacker, that helps some with the gear selection I made. I went with the 3.70 n i was worried i went too low, especially since i just found out i'm gonna lose 20hp with the swap " which i didnt know"
05-24-2011, 06:13 PM | #160 |
INTHECLOUDS
Where is the power loss coming from? Are you referring to the power loss from turning the larger unit?
05-24-2011, 10:24 PM | #161 |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
05-24-2011, 10:29 PM | #162 |
INTHECLOUDS
Hmm...I'd like to research that, what are your sources? If that's true G-Force owes me a power adder worth 20 LOL!!
05-24-2011, 10:37 PM | #163 | |
"The mechanical efficiency of a gearset will be at its highest when the ratio is at 1:1. This is because both gears have the same pitch diameter and the "sliding" of teeth is minimized, reducing friction. The farther the ratio gets away from 1:1, the larger the difference in pitch diameter of the two gears. This causes much more tooth sliding, and as a result, more friction and less efficiency (and hotter differential fluid in this case). Sometimes the same gear ratio in a different differential can be more or less efficient as well... Ford 9" rears are notoriously inefficient. This is because the pinion height is much lower relative to the centerline of the ring gear than it is in most rearends. The lower pinion height causes more sliding, more friction, and less efficiency. In the Ford's case (no pun intended ), this makes the rearend stronger also, as the lower pinion height translates more force forward into the thrust bearing and therefore places less of a moment (rotational) load on the pinion shaft." That was from here: http://www.z06vette.com/forums/f5/ca...-dyno-s-99548/ |
05-24-2011, 10:50 PM | #164 | |
INTHECLOUDS
05-24-2011, 11:07 PM | #165 |
Wacker, if you're increasing the gear ratio the efficiency will actually go down (increase in parasitic loss) because the pinion teeth are sliding more on the ring gear teeth. But, the increase in torque from the higher ratio should improve your ET.
05-25-2011, 06:55 AM | #166 |
INTHECLOUDS
I guess that makes sense...
06-06-2011, 10:15 PM | #167 |
We now have 9" kits on the shelf ready to ship
I also have a couple Strange Pro Iron pumpkins with dyno time only that could be included with the kits at a discount if anyone is interested. Thanks for the orders guys! Chris |
06-06-2011, 10:44 PM | #168 |
INTHECLOUDS
How is the new driveshaft coming? I will have the gears back Monday...BUSY week, but I'll try and get the old shaft in the mail.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
New product from Gforce Engineering - Billet pinion yokes | GFORCE1320 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 10 | 06-17-2010 07:17 PM |
BMR has picked up the Gforce Engineering product line | GFORCE1320 | Transmission / Driveline | 0 | 04-27-2010 08:54 PM |
