Old 06-18-2025, 01:48 AM   #16521
vaeron
vaeron's Avatar
Originally Posted by Booher View Post
Try gorilla glue double sided permanent tape for the stud plates or whatever they're called, thats what I used, and don't worry, it will come off when you need it. I heard 3m works too, I suggest not using the tape it comes with.
The sad part, it was 3m tape from Ikon. I'll find the gorilla glue double sided and order some so it's here when I get home and have time. I won't be able to do it before I leave. Thanks for the tip! I normally have good luck with 3m, even used the adhesion promoter on it too. Oh well, glad I caught it when I did.
vaeron is offline   Reply With Quote
Old 06-18-2025, 03:49 AM   #16522
Green82
Green82's Avatar
Drives: 2022 camaro 2SS
i had the louvers on my last car for 2 years and my current car for 2 months with no problems.
make sure you clean the around window good with alcohol because if there is any residue of wax or anything that would prevent it from sticking
Green82 is offline   Reply With Quote
Old 06-18-2025, 06:05 AM   #16523
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Give it time, they will fall off. I take my louvers off once a month for cleaning, and occasionally have to replace the adhesive on one. Just rip off old tape, put the new tape on, tighten it down to louvers then set it down in your window, super easy. There are different strenghts of tape adhesives, and the 3m one that it comes with, isnt the best, but obviously is working for some.
When they first came out, It was common knowledge to swap out the factory tape, but after all these years, that step must've been forgotten. But it gets over 120 degrees here, I enjoy higher speeds, and have a sub in the trunk, so I could just be extra, lol, anyways, glad to have another louver car in the club, enjoy!
Old 06-18-2025, 05:06 PM   #16524
vaeron
vaeron's Avatar
Yeah cleaned it completely with isopropyl alcohol and then wiped it down with the adhesion promoter. That being said, I ordered the 60 lb gorilla tape that will be here when I get back from vacation. Thanks for the tips y'all. Excited to get them reinstalled.
Old 06-18-2025, 09:25 PM   #16525
Joangelsview
Drives: 2018 Camaro 2ss
Exclamation 4k stall
Serious question, I’m currently running a GPI ss2 cam on my 2018 Camaro 8a and it only had kooks long tube headers but I just purchased a 4k-4.2k stall from circle D since that’s what they recommended but my tuner is saying that’s too aggressive of a cam, would this bring me many issues to my car since it is my daily? Should I change it to something smaller?(circle d said even if I do 3600 Id still have issues if I don’t tune my trans) but since it is my daily I can’t really send my trans to get unlocked, or should I just apply it in hopes of not having anything break for the foreseen year? yo
Joangelsview is offline   Reply With Quote
Old 06-18-2025, 09:28 PM   #16526
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
That’s too much stall for a daily driver IMO. Hit up KingLT1 on this board for a stall recommendation.
You should tune the transmission regardless of what stall converter you do. You do not need to pull the transmission, just the TCM. Overnight it in to HP Tuners, they’ll unlock it and overnight it back. Or buy an unlocked core from them. Much easier than pulling the transmission lol
Old 06-18-2025, 09:33 PM   #16527
Joangelsview
Do you think I should send it back? I do plan on going FBO soon but don’t
Know if I should just deal with it then since imma need a trans tune no matter what or should I still go smaller?
Old 06-19-2025, 06:39 AM   #16528
clg82
Drives: 2020 Camaro ZL1
I would listen to your tuner, since it sounds like you have no idea what's going to happen to your car with the parts your wanting them to install. Do you even know what a stall converter does?
Old 06-19-2025, 01:18 PM   #16529
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
What did I do today?
1. Finally got my new Katech Dual Drop In Fuel Pump "dropped in" Now I need to wire it up...
2. Did my final test fit for my rear bumper belly pan... Damn she fit perfect!
3. Drilled and tapped the back of my blower in two spots for some additional IAT sensors... more on that later...
Old 06-19-2025, 05:27 PM   #16530
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf R
Very excited about the belly pan! Not having something like that has been my #1 reservation on getting a cat back.
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG
PowerDemon is offline   Reply With Quote
Old 06-19-2025, 05:53 PM   #16531
Lethal6SS
Drives: 2017 Camaro 2SS Fifty
Originally Posted by TRUEOGRE2SS View Post
Nope, Absolutely no issue what so ever of them falling off, even though it gets pretty warm under the hood, just make sure to put a decent amount of silcone (don't glob it) on the backs of each plaque and around the outside edges of the frame, after you take liner off take your time getting everything lined up perfectly square, because once that silicone dries, it'll be very hard to get them off without tearing up your liner.
How do you remove the black clips without damaging them?
Lethal6SS is offline   Reply With Quote
Old 06-19-2025, 06:17 PM   #16532
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
My first though when seeing the the fuel pump access panel was "Damn! That took some big balls to cut and drill that close to the plastic fuel tank!"
Nicely done. Love the threadcerts, nice and clean. Do you have pics of the new access panel? Did you fabricate a custom gasket to seal the new access panel? I'm thinking 1/8" rubber or neoprene gasket material would be a good choice.
Sure as hell beats having to drop the rear subframe and fuel tank to access the fuel pump.
-Ray
Ray3768 is offline   Reply With Quote
Old 06-19-2025, 08:14 PM   #16533
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
Tell me more about the rear belly pan. What purpose does it serve?
Camaro SS - (almost) FBO/E85: Tuned by Snackbar Tuning/21st Century Muscle Cars
tortilla-flats is offline   Reply With Quote
Old 06-19-2025, 09:36 PM   #16534
Rnovrit
Drives: 2018 NFG ZL1-1LE
When you remove the stock suitcase muffler it exposes the back of the bumper cover and causes a parachute like condition with the air flowing under the car. The belly pan across the back smooths out the air to go past the bumper cover and reduce drag. At least this is the theory I have read.
Rnovrit is offline   Reply With Quote
