Old 06-14-2025, 10:39 AM   #16507
WyreTheWolf
WyreTheWolf's Avatar
Drives: Chevrolet Camaro 2LT RS
I'm very partial to the SS 1LE wheel style but those are some great aftermarket wheels, what are they? What size(s) did you go with? I love the color of them...
Manufacturer: VMR
Site: https://vmrwheels.com/
Model: V710
Color: Gunmetal
Size:
• Front: 20x9+25 | 245/40ZR20
• Rear: 20x10+35 | 275/35ZR20
Tires: Continental ExtremeContact DWS06 Plus
WyreTheWolf is offline   Reply With Quote
Old 06-15-2025, 01:08 AM   #16508
vaeron
vaeron's Avatar
Originally Posted by Green82 View Post
make sure to use the foam blocks in the center or you will hear louvers vibrating down the highway
Yep, already on and worked great on the highway... the fitment is... tight... but works.
went for a road trip today and took some more photos. Was itching to go for a drive!
vaeron is offline   Reply With Quote
Old 06-15-2025, 09:03 AM   #16509
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I've been running the same louvers since 2018, there are some things to do to it, like running foam tape around the perimeter, adding an extra plate in center bottom, but I've never heard of using foam blocks in the center. BTW, love the louvers man!
Old 06-15-2025, 11:34 AM   #16510
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Went for a short road trip to Tofino with my Brother. Damn these cars handle well, what a fun drive!
speedyink1 is offline   Reply With Quote
Old 06-15-2025, 12:42 PM   #16511
Green82
Green82's Avatar
Drives: 2022 camaro 2SS
the foam blocks come with the the louvers install kit. the go in the centers of the louvers where they flex
Green82 is offline   Reply With Quote
Old 06-15-2025, 12:54 PM   #16512
Booher
Booher's Avatar
Interesting, they must've revised it, I've never had any issues. /shrug my bad
Old 06-16-2025, 08:34 PM   #16513
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Yes that version sticks onto the current piece. This one replaced the stock triangle piece and can be swapped back easily.
Left modified version
Right stock piece
Sent from my iPhone using Tapatalk Pro
I have been unable to get into the Facebook group where these were offered. Is there any other contact info available for the seller?
Old 06-17-2025, 01:04 AM   #16514
vaeron
vaeron's Avatar
Thanks so much! I had to remove them today to check adhesive and was going to wash the car and found 3 of the pads hadn't adhered well, I'm sourcing new adhesive and will reinstall them either in the next couple days or after my trip. Not sure I'll have time to work on it before I go.
Old 06-17-2025, 07:33 AM   #16515
clg82
Drives: 2020 Camaro ZL1
Originally Posted by vaeron View Post
I'm sourcing new adhesive.
Sourcing? You looking for aircraft grade material? Just go to your local VatoZone...
Old 06-17-2025, 08:02 AM   #16516
sklippi2018
Drives: 2021 ZL1 A10
In case there are others I first saw them under this FB Group: 6th Gen ZL1 Camaro
sklippi2018 is offline   Reply With Quote
Old 06-17-2025, 10:05 AM   #16517
DeuceCam
Drives: LT1
Originally Posted by sklippi2018 View Post
Found this the other day...
That was a good watch. Thanks for posting
DeuceCam is offline   Reply With Quote
Old 06-17-2025, 11:28 AM   #16518
Ryanbabz71
Ryanbabz71's Avatar
Not sure, his FB user name is Meeko-And Kyle
Ryan
Old 06-17-2025, 09:05 PM   #16519
SPLATT
SPLATT's Avatar
Drives: 16 Camaro 2SS
New wheels and tires. American Racing TTF in 20x11 and 20x9.5 with 285/30R20 and 305/30R20 Continentals. Wasn't quite what I wanted but close. I also installed the rock guards. Never mind the dirt, I live a few miles down a gravel road and haven't washed this week.
SPLATT is offline   Reply With Quote
Old 06-17-2025, 09:52 PM   #16520
Booher
Booher's Avatar
Try gorilla glue double sided permanent tape for the stud plates or whatever they're called, thats what I used, and don't worry, it will come off when you need it. I heard 3m works too, I suggest not using the tape it comes with.
