#15709 | |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune l GM Lowering Kit Ported LT2 Intake Manifold l Ported 95mm LT5 TB l BMR Rear Cradle Lockout Kit Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l 480whp/467wtq |
#15710 |
![]() Drives: 2018 Camaro SS Join Date: Jan 2021
![]() Another thread reminded me I need a trunk liner. Was gonna order a smart liner as it was $70 with good reviews but checked eBay before buying. Found the 3D MaxPider one for $80 brand new open box. Looks great! Sent from my iPhone using Tapatalk |
#15711 |
![]() Drives: Chevrolet camaro rs Join Date: May 2023
New Rims
Just had discount tire install new Z28 chrome rims on my 2019 riverside blue camaro.
#15712 |
![]() Drives: 2022 1SS 1LE RB Join Date: Mar 2021
#15713 |
#15714 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#15715 | |
#15716 |
![]() Drives: VOM 2022 2SS Join Date: Feb 2022
#15717 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
![]() Took this Saturday. Sent from my iPhone using Tapatalk Pro
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#15718 |
Moved my subwoofer amp to the trunk floor. Put rubber spacers under the MDF base, fastened to the existing studs on the floor, and put rubber spacers under the amp as well. It's a bit of a tight fit with the LOC - I'll probably replace with a smaller amp eventually. I upgraded the power & ground wiring to OFC, and will replace the RCA cables with appropriately sized cable, and upgrade the speaker wire to 12-ga OFC as well. And I'll clean up the wiring too. But I like it so far. Better than having it take up space in the trunk.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#15719 |
![]() Drives: 67 Orange Mustang Coupe Join Date: Aug 2023
California Special
#15720 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
Regarding the CARB sticker for the CAI on the post above. I'm curious... For those in the know, do the smog techs actually check the number to see if it matches like the year for the car, etc? I'd like to get the CAI intake however the available CARB cert is for the prior year and wondering if I could get away with it. I think the cert is for 2020 6.2 and I have 2021.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
#15721 | |
![]() Drives: 2023 ZLE M6 Join Date: Jun 2022
Just depends if the shop you go to does any funny business or not. Most places I've been to they take it seriously as there can be massive fines for mucking with smog results. Even then, they are usually helpful to get you passed legally. It takes like 15 mins to swap intakes for a smog. Easiest path to take out here in cali, imo.
2023 ZLE M6 Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid 2024 Polestar 2 AWD |
#15722 | |
84134250 is the original. I have both. DM if interested. State Ref is the only one who will hassle. Most CHP and local SO on the side of the road or highway will google the number and see what intake pops up. Regular Smog Shops will need to see a sticker. If the CAI matches up to the cert number that's 50 state approved you'll pass the visual. Dealerships were installing these still without tunes until their supply's ran out even on 2022's and early 2023's |
