Old 09-15-2024, 11:14 AM   #15583
GroundhogSS
GroundhogSS's Avatar
Wow, Arpad. That's an incredible looking car. Beautiful work.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 09-15-2024, 12:23 PM   #15584
Thank you, Richard She is looking new again, or even better, and has more protection. Sure, there are a few small "battle scars" that can't be fixed or hidden, but I've embraced them, after all, this car is 6 1/2 years old.
Old 09-15-2024, 12:28 PM   #15585
Here are two closeups of the Panther badge if someone is considering it for their ride.
Old 09-16-2024, 01:49 PM   #15586
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
Detailed it yesterday.
I got a new wheel barrel brush that works better than anything else I've used with tight spaces. It also came with a nifty lug hole sponge/cleaning attachment which is awesome.
Old 09-16-2024, 01:57 PM   #15587
Junction65
Junction65's Avatar
Drives: 2011 GMC Sierra 1500
Looking good!
2023 LT1 M6 Coupe - Black (GBA) on Black (H1T) - Build Date: 8/22
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W)
LT1 PBC engine - Shane Parker
Current mileage: 400
Junction65 is offline   Reply With Quote
Old 09-16-2024, 05:42 PM   #15588
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
Looking good!! .Nothing quite like a nice, clean and shiny Black Camaro, is there GearheadSS??? (even IF it only stays that way for 10 minutes! ). Still wouldn't change colors though!
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 09-16-2024, 08:18 PM   #15589
Green82
Green82's Avatar
Drives: 2022 camaro 2SS
wished i could get my black camaro that shiny
Green82 is offline   Reply With Quote
Old 09-16-2024, 08:31 PM   #15590
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Cleaned off the bugs, which had baking for almost a week in the hot sun. Superior Products Dark Fury works great.
My Camaro Journal
Old 09-16-2024, 08:48 PM   #15591
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Agreed! It's definitely a bitch, but it's so worth it when she's shiny and clean. The lines of this car also just look so good in Black.
Speaking of keeping clean, I cleaned the alcantara steering wheel and shifter today... I'm embarrassed at what came out! I swear I'm not a sweaty brute (Probably denial by the looks of it..). I end up cleaning it twice over a year period, with about 6,000km of driving for each
That was clear water before I wiped off all the Sonax and dirt it picked up. Clean your steering wheels, folks!
After It's dry I brush it with my natural bristle brush and it looks and feels like new again. The softness after a clean makes the pain in the ass upkeep also worth it (sounds kind of familiar...)
End result (yup, it's a steering wheel, but.. I think you can tell it looks clean?)
speedyink1 is offline   Reply With Quote
Old 09-16-2024, 09:19 PM   #15592
david_acm
david_acm's Avatar
Drives: LT1
Ha, same. I went to Tampa this weekend and the drive back left the entire forward facing parts full of bugs. They were only on the bumper overnight so they cleaned right up in the morning.
david_acm is offline   Reply With Quote
Old 09-16-2024, 09:22 PM   #15593
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Agreed!
Do you have a link of the product(s), type(brand) of brush etc.. you used as well as step by step instructions for cleaning it? I'd like to file it away for when it's time to do mine.
Old 09-16-2024, 11:02 PM   #15594
speedyink1
speedyink1's Avatar
Sure!
Need:
Sonax
Brush: Not quite my brush but pretty darn close
Small micro fiber towels
Instructions:
-Squirt one or two squirts of Sonax on one of the towels. Rub across the steering wheel, spreading evenly(It's a foam, so fairly easy). Apply enough to slightly wet the areas, especially those where your hands end up the most. Does not need to be soaking wet!! Apply more Sonax to the towel as needed to cover all the areas you want to clean, including shifter.
-Let sit for at least 15 minutes (I let mine sit more like 20-30 mins)
-Grab a new towel and a small bucket with clean, warmish water. Wet the towel(wring out) and start gently wiping a small portion of the wheel. You'll notice grime picking up onto the towel. Rinse the towel, wring out, and repeat the same area until you no longer see grime lifting. Move onto the next area and repeat the process.
-Grab another, dry towel and squeeze the steering wheel all around to suck up any remaining moisture.
-(Optional) I'm sure you could use a hair dryer on low heat to help dry.
-Once dry, use the brush to "puff up" the fabric. Swipe across the fabric in different directions until you find the direction that it "sticks up" the most. Repeat that direction for the piece of fabric. Each different piece of fabric can change what direction you need to brush.
That's about it
Old 09-16-2024, 11:47 PM   #15595
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Sure!
Need:
Sonax
Instructions:
That's about it
Thank you for all of that!!! APPRECIATE IT!!!
Old 09-17-2024, 02:17 PM   #15596
beowulf556
Drives: Camaro SS 1LE M6
Sure!
Need:
Sonax
Instructions:
That's about it
This is excellent. I'm somewhat obsessed with cleaning by wheel but I'm going to give your technique a go.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
