Old 08-24-2024, 06:41 AM   #15513
White1SS
White1SS's Avatar
Drives: White 2024 1SS M6
Gotcha, still makes me a tiny bit nervous, I have MRR017's which are +23 offset vs. +20 OEM offset so my wheels sit 3mm inboard further... That 3mm MIGHT mean the difference from rubbing or not rubbing... I would really love 275/35 fronts and 315/30 rears as that would put me damn cloase to OEM SS specs (wheel/tire height) (as you know)... Plus 315's out back would be great! (I hated my 275's, Love my 305's but even a touch wider (0.40") would be great with 315's!)
Honestly, I'll probably go with the Atturo AZ850's again, I never drive in the rain, they balanced great and they hook nice, and you simply can't beat the cost... So I can have fun burning them up without much guilt!
You can always add a 3mm spacer to the front if they rub, it would still only poke like a OEM 1LE rim. Did you just not like the look of 275's, or was it the actual tire you weren't fond of ?
White1SS is offline   Reply With Quote
Old 08-24-2024, 07:05 AM   #15514
^^^ as White1SS says, a pair of 3mm spacers will easily make up for the difference if needed. I used ones from this company while running the MRR 017s myself, but cheaper ones abound in the lower bowels of the internet (ebay, amazon), too. The 1LE poke I'm okay with, whatever mpg loss it causes is offset by the aggressive look
Old 08-24-2024, 11:35 AM   #15515
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I was getting close to needing tires and always wanted the SS 1LE wheels, so I bought the MRR017's and a friend had a set of Atturo AZ850's in 1LE size that only had a couple hundred miles on them he sold to me for a really great price so I jumped at it... I did always feel the SS needed more width in the back so I feel the 305's look a lot better than the 275's as the 305's are about 1.2" wider...
Old 08-24-2024, 11:36 AM   #15516
2SS Capt
2SS Capt's Avatar
That's true, didn't even think about spacers... Thanks guys!
Old 08-24-2024, 12:25 PM   #15517
Just to put your mind to rest, Captain, I just retested the rubbing on both sides at full lock, and the 275/35s don't rub. It is very, very close, though. on both sides, the gap is definitely less than 1/8", I'd say about 1/16th or even a bit less. I imagine as the tires wear, clearance will increase slightly.
Remember, this was measured at full lock when you have the wheel turned 100% to the left or right, nobody drives like that for long, this is why even the 285/35s didn't rub through my liner in 4 years, not even close.
Old 08-24-2024, 02:19 PM   #15518
White1SS
White1SS's Avatar
I agree, aesthetically the 275's just aren't wide enough for a SS. The 305's and 315's are just a much better and more aggressive look. I also will be getting Atturo AZ850's when the time comes, I think they are a great all around tire at an affordable price.
Old 08-26-2024, 02:55 PM   #15519
GregH
GregH's Avatar
Drives: '23 2SS VOM Coupe
a few small things
I finally got around to doing a few minor things to my ride.
Had installed:
- window tint (llumar stratos 80% windshield, 40% sides/back)
Did myself:
- de-badged sides/rear
- washed/clayed/paint correction/polished/ceramic coated
- cleaned and ceramic coated wheels
- swapped brake pads to PowerStop Z26 pads (for less brake dust)
- installed black lugs & locking lugs
- installed smoke rear reflectors
- installed DIY NPP switch - inspiration from here: https://www.camaro6.com/forums/showthread.php?t=613102
2023 Vivid Orange Metallic 2SS Coupe
A10, NPP, MRC, BCD Brakes, Black Forged Wheels, Black Lugs, Alloy Pedals, 40% Llumar Stratos Tint, Adam's Ceramic Coating
Range AFM Disabler, Kanguru 3D Spidermax floor/trunk mats, DIY NPP Switch
Vivid Orange '23 2SS Coupe
1100: 4/19/23
3000: 5/8/23 (TPW 5/27)
3800: 5/31/23
5000: 6/9/23
6000: 6/16/23
GregH is offline   Reply With Quote
Old 08-26-2024, 04:10 PM   #15520
2SS Capt
2SS Capt's Avatar
Had installed:
Did myself:
Looks great, just need to complete the smoked look with some Diode Dynamics Smoked LED Side Markers! https://www.diodedynamics.com/led-si...amaro-set.html
Old 08-26-2024, 06:47 PM   #15521
AZIROC
Drives: '86 IROC-Z '18 ZL1
Decided to tame the car out since it's been a few months. Got in the car, closed the door, and the little push buttons for the cruise control on the steering wheel fell off. Kinda shocking seeing how I never used it and the car only has 10k miles. So off to trying to find this part.
Old 08-27-2024, 06:37 AM   #15522
GregH
GregH's Avatar
Absolutely! They're on my list.
1100: 4/19/23
3800: 5/31/23
5000: 6/9/23
6000: 6/16/23
Old 08-27-2024, 07:49 AM   #15523
Abubaca
Abubaca's Avatar
Drives: 2016 SS
Greg H, -greetings from the Greensboro/High Point area! -That's a really sharp car! Looks great!
Abubaca is offline   Reply With Quote
Old 08-27-2024, 09:57 PM   #15524
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Added some more decor to the garage! Had my electrician wire in a lighted Griot’s Garage sign to the same switch that lights up my unused original Camaro taillights.
Old 08-27-2024, 10:10 PM   #15525
Haha, great minds and all I did something similar with my original tails in March, but I still need to clean up all the stuff around them (oops)
Old 08-28-2024, 06:36 AM   #15526
Joshinator99
Moderator
Looking good!
