Old 06-10-2023, 07:40 PM   #141
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Hey guys... After a casual 70 mile drive to HAUS of POWER in FULLERTON, we strapped her up, and she belted our 730rwhp and 740rwtq... still waiting for the graph, but attached are a few photos.
I drove the car easy on the way up and averaged 16.7mpg over 69 miles...
IAT.1's were 66 and IAT.3's were 106 all the way there.
IAT.3's were 130F on the dyno pull, which i think is still pretty cool...
HAUS has a super clean shop, mostly late model BMW's but his dynojet is welcome to all
I think its already clear to say that this power level wont last long...
I think the car could use another 100rwhp...
I wonder how much more E / boost / power XDi 30's would help me make?
My injector pulse width was around 5.9max and boost level seemed to be around 12.
Thoughts?
Old 06-10-2023, 11:03 PM   #142
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Nice numbers Gabe! Torque monster.
My guess is another 30whp if you can hit e60 with the injectors, same boost level. However not sure if it will hit e60 with just the injectors, they'll be depleting the rails faster and highside pump will need strong pressure behind it to keep up. IF you could up the boost and hit e60 maybe another 75whp total. That would probably be Port injection with a lowside. But it'll get you as much boost as the blower can handle and full ethanol. $2500 for new injectors, vs $3200 for lowside and port(depending on lowside selection). Port will also be more involved labor and tune wise.
Another 100whp? bigger blower
Old 06-11-2023, 02:17 PM   #143
SOCAL.M6.ZLE
Thanks for the feedback! I can see that I am now at the top of a slippery slope with fueling / traction. Sounds like it's not possible to forecast the current headway in the lowside?
So I need to upgrade the injectors, and dial up the E content until either the injectors or low-side max out? Another 30rwhp sounds fair... Guess I need to determine if the $3k to purchase and re-tune is worth it...
Anyone else been in this situation?
Old 06-11-2023, 07:15 PM   #144
Crusher Camaro
Drives: 19 ZL1
Right there with you. putting on whipple, guessing I will be down to pump or low E30-E40 before pretty much maxing out the fuel system.
HP fuel pump and injectors get pricy quick.
More than likely, will go for Fore triple pump and port injection next year.
that should take care of any fuel issues.
Crusher Camaro is offline   Reply With Quote
Old 06-13-2023, 06:16 PM   #145
SOCAL.M6.ZLE
Dyno graph attached
Already hungry for more!
Old 06-13-2023, 07:54 PM   #146
JSH
JSH's Avatar
Drives: '20 ZLE
Nice car
Thoughts?
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 06-14-2023, 10:45 AM   #147
w.ross
Drives: 94 Toyota Pickup
A few sneak peak photos, of some new rubber that was just wrapped around my new Apex SM.10 wheels... I'll share some updated photos and driving impressions once they are mounted
What widths and offsets did you end up going with on these?
w.ross is offline   Reply With Quote
Old 06-14-2023, 11:31 AM   #148
SOCAL.M6.ZLE
19" x 12" in the rear...
19" x 11" up front
I believe the offsets are standard.
Old 06-14-2023, 11:37 AM   #149
w.ross
19" x 11" up front
Thanks!
Old 06-15-2023, 06:14 PM   #150
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Just saw this thread..
Garage envy
Photography: Quality
Kudos on the build and results
So sorry about your mom, it hurts and sucks to go through.
You asked for numbers of similar builds
My build is similar(ish) a slightly smaller cam, flex fuel, ported blower and heads with an A10 though. Tuned by Ted. My fueling was limited by the injectors. I did end up able to run E70 but usually don't exceed E60, the gains aren't much at that point anyway.
The build info starts in post #116
Dyno screenshot is here
https://www.camaro6.com/forums/showp...&postcount=121
745hp/786ft-lbs
My focus was drive-ability, increase the air efficiency in/out, reducing heat as much as possible at the track AND of course some more power too!
Your ZLE should be a blast to drive! Modding never ends
Old 06-17-2023, 03:02 PM   #151
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Now after all the beautiful hard work and money could you please go buy a Roto fab coolant cover to hide that hideous orange coolant
Old 07-11-2023, 07:02 PM   #152
SOCAL.M6.ZLE
Hey guys... as expected... 735rwhp was not enough, So I just finished installing some FIC 30's, but the 9.17" lower back on, and bumped the E content from E33 to E60.
TED tuned her up, and she is back to feeling scary in 2nd / 3rd. The 345/30/19 R888R's hook amazing out back when warm and on the right road, and it takes all my strength to take it to redline, and shirt... DAMN...
Planning to go back to the DYNO next weekend to see how much we picked up. We have now maxed the lowside / JMS... Boost seems to be around 13.5psi at peak...
How much do you think she will pick up?
Old 07-11-2023, 07:45 PM   #153
BZSS
BZSS's Avatar
Drives: 2023 Camaro ZL1
Just read through this whole thread and wow what a project. Your photos are stunning. Are you using a legit camera or is that all iPhone?
2023 Camaro ZL1 - Rapid Blue, M6
3800 - 6/12/23 | 4800 - 6/26/23 | 5000 - 6/30/23 | 6000 - 6/30/23
SOLD - 2017 Camaro 2SS 50th Anniversary - H50, M6, NPP, MRC
BZSS is offline   Reply With Quote
Old 07-11-2023, 08:42 PM   #154
JSH
JSH's Avatar
Drives: '20 ZLE
Thoughts?
First, let me say I think you've got the most mods of anybody that I've ever seen on this website. My x-port made around 730 on gasoline so there's got to be more in it but I don't see it making 830
2020 ZL1LE A10.
