Old 02-05-2021, 04:31 PM   #141
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
Checkout these awesome shots of Lynn's 5th Gen 1LE on a set of 19" ARC-8s in Anthracite Finish!
APEX Wheel Fitment Specs:
  • Front: 19x10" ET20 ARC-8s with 285/35-19 Bridgestone RE71R
  • Rear: 19x11" ET43 ARC-8s with 305/30-19 Bridgestone RE71R
Owner's Instagram
Apex Wheels is offline   Reply With Quote
Old 02-06-2021, 07:11 PM   #142
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Originally Posted by APEXRaceParts View Post
18"
18x11" ET7 - front only
18x11" ET35 - rear, or front with 26mm spacer
18x12" ET41 - rear only
19"
19x10" ET20 - front/rear
19x11" ET11 - front only
19x11" ET35 - rear, or front with 26mm spacer
19x12" ET41 - rear only
All will have the direct fit center bore and knurled beads! Not to mention 18" will clear the ZL1 brakes and Z/28 Carbon too.
Have a 2020 SS1LE.
Fronts only? Is that because they’ll make contact with the rear fender?
I prefer Cameron specific square wheels but if these doesn’t work, looks like 19x10.5 et22 is the way to go. Right?
Dabjbr is offline   Reply With Quote
Old 02-07-2021, 12:50 AM   #143
SHessler
SHessler's Avatar
Drives: 2021 1SS 1LE [Shock]
Originally Posted by Dabjbr View Post
Have a 2020 SS1LE.
Depends on if you want to run the big spacer for the front. You can go with the smaller spacer with 10.5's with a centering ring or the bigger spacer at 11.0.
I'm still on the fence a bit about the direction to go.
I admit it, I like Mustangs.
Ex Spec Miata driver.
SHessler is offline   Reply With Quote
Old 02-08-2021, 09:37 AM   #144
c4racer
Drives: 2016 SS Convertible
I went with 19x10.5's ET35 square with a 16mm front spacer. Pics on page 4 post #52.
Note - the specs on the post are not correct, I think Apex sells a 20mm spacer, but I used a 16mm. Either will work, but the 16mm doesn't give as much poke on the wheels / tires.
On for a year - no issues, still loving the set-up. GMPP lowering kit going on the car shortly followed by an alignment with some neg camber.
c4racer is offline   Reply With Quote
Old 02-14-2021, 08:18 PM   #145
S2000_Europe
Drives: Corvette GS w Z07 Package
I have my18 Zl1. I want a square set up with 19". I found that only apex ARC8 works:
19x10” ET20 with 285/35-19 tires but I will have smaller tires in the back
Front: 19x11” ET11 - 305/30-19
Rear: 19x11” ET43 - 305/30-19 but it is not truly a square set up.
in your fitment guide I found this:
Front and Rear: 19x10.5” ET22 with 305/30-19 tire BUT needs 12 mm spacer and negative camber in the rear, is this recommendation for just SS owners or spacers are needed for ZL1?
I am between sm10 and arc8
MY02 S2000 > MY11STI > MY01 E46 M3 > MY05 S2000 > MY06 911 C2S > MY88 944 TURBO S > MY17 STI > MY17 SS 1LE > C7 GS w/ ZO7 package > MY18 ZL1
S2000_Europe is offline   Reply With Quote
Old 02-14-2021, 09:31 PM   #146
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
19 x 10.5 ET22
I run APEX SM-10 19 x 10.5 ET22 wheels on my SS 1LE all four corners with MS 4S 305 30 19 . This is rotatable and I do that every 4K miles. Tires has roughly 12K miles on them with 10 track days. Tires still have 60 per cent left. I DO NOT run a spacer up front but I did slightly grind the shock tower for clearance. I run 2.2 degrees NEGATIVE camber on front and 2.0 degrees negatve camber on the rear for my street setting. I change the camber on the front to - 3.6 degrees camber at the track using camber plates. Anything LESS than roughly -1.5 degrees negative camber, then you will have a small amount of tire poke at the top of the fender on BOTH the rear and front tires
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 02-15-2021, 11:31 AM   #147
Bwaahhh
Drives: 2019 SS 1LE
sr71bb, mind posting pictures?
Bwaahhh is offline   Reply With Quote
Old 02-15-2021, 01:00 PM   #148
sr71bb
sr71bb's Avatar
pics
Already did. LOOK BACK UP AT POST 94 on PAGE 7 of this thread. That's with SG3 suspension installed,ZL1 brakes, and 1LE suspension.
Retired Cars BELOW:
Old 02-18-2021, 05:58 PM   #149
Apex Wheels
Drives: Camaro Z28
Take a look at these rad photos our customer Kunal sent in last year of his 2018 Camaro SS 1LE on Satin Black 19" ARC-8s at Chuckwalla Valley Raceway.
  • Front: 19x11" ET11 ARC-8s with 305/30-19 Goodyear Eagle F1 tires
  • Rear: 19x12" ET41 ARC-8s with 325/30-19 Goodyear Eagle F1 tires
  • Suspension: ZL1 1LE DSSV full suspension -3.6 degrees front camber and -2.4 degrees in back
Owner's Instagram: @kunal_the_foodie
Old 02-18-2021, 06:31 PM   #150
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Sexy and all, but they are still not these!!!!
We are aiming for Camaro Specific SM-10s to be available in March!
-Ian
driven2exceSS is offline   Reply With Quote
Old 02-18-2021, 06:36 PM   #151
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
he has the sm10s on now 19x11 squared haha he was at the track with me in january for ongrid super gt cup
Old 02-19-2021, 08:03 AM   #152
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Tell him to get those tire deflectors off of there to get more air to his poor brakes. Then buy the track brake deflectors
Old Ride: 2016 Callaway SC630 Camaro SS
Old 02-19-2021, 11:06 AM   #153
kropscamaro16
haha i gave him some shit about those last time his is a ss 1le and he added em i have a 1ss and i removed them and then added the brake deflector kit
Old 02-20-2021, 06:39 PM   #154
Fijititan
Drives: 2018 Camaro SS 1LE
They are now off 😆 lol also added the GM performance bigger brake ducts. The old ducts didn’t scavenge much air.
Fijititan is offline   Reply With Quote
