Old 11-06-2017, 08:50 AM   #141
JusticePete
Drives: Camaro Justice
Originally Posted by allenrayn View Post
Had the same problem. Took it in and the gm dealer replaced the nuts with the new ones. 2 weeks later, the clunking returned. Going to put on nordlock washers myself on all 4 nuts. This is absolutely crazy!
Question: I can't get my torque wrench and socket in the tight space for the lower nuts. I feel like i need a pass through torque wrench. Or a joint piece. How did you guys do it? Thanks!
These are the new nuts. But obviously they did not work.
The 3rd picture (sorry it is flipped 90 degrees) is the old factory nut
Originally Posted by Lt1z350 View Post
What’s weird is since my first tightening at home it’s stayed tight. No locktight no special nuts. Hit the tops with my 3/8 Milwaukee 3/8 gun and bottom two with a wrench. I have a zl1 drive the crap out of it and really bad roads in Jax so always beating the crap out of car. When I put wheels back on it I did torque all them to 120 flbs and haven’t had to touch in 1500 miles where see some say loose again with New nuts and or dealership Work. I was getting the bmr but for now if this stays tight will just let it be. Maybe a lot of people just don’t get them tight enough is all I can come up with since I didn’t even bother with locktight since had plans on changing when came loose again and just haven’t.
Here is the TSB for loose endlink nuts from GM: https://www.revbase.com/BBBMotor/TSb...dPdf?id=199084
It needs a washer, maybe a simple lock washer would work, but a Nordloc and LocTite are the known permanent fix.
JusticePete is offline   Reply With Quote
Old 11-06-2017, 11:01 AM   #142
rootus
Drives: 2018 HBM SS 1LE
I went the loctite route, but I did buy some nord-locks -- ended up not using them because the outside diameter was a couple mm less than the bolt, and I was not comfortable with that. If you have one of the nuts handy, measure before ordering expensive nord-locks...
rootus is offline   Reply With Quote
Old 11-07-2017, 10:20 AM   #143
FolkSS
FolkSS's Avatar
Drives: 2017 ZL1 A10 NGM Coupe
Ditto. Thank you for posting this, I was able to suggest the sway bar links as a cause at my dealer, and they were able to take care of it while I waited this morning.
'17 ZL1 A10 Coupe in NGM - New!
'12 2SS M6 Black Vert - Sold!
'71 Firebird Formula 400
'70 Nova - Under Resto
FolkSS is offline   Reply With Quote
Old 11-14-2017, 03:05 PM   #144
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Anybody can tell me the difference between red and blue loctite ?
What’s the best to use?
Biscuit.fr is offline   Reply With Quote
Old 11-14-2017, 03:59 PM   #145
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Red = Don't ever bother trying to get this nut/bolt off without a torch
Blue = I might want to take this off some day
Eric SS is offline   Reply With Quote
Old 11-14-2017, 05:00 PM   #146
Biscuit.fr
Tx
Got it now with the strength 243 and 263...
What about the nordlock washers?
M12 std nordlock washer for the 12mm
Or ss washer which seems to have more cranks?
Old 11-17-2017, 06:52 AM   #147
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
Brought the car in, had them add the nordlock washers. They put on the new bolts while there and supposedly added loctite.
It's still making a clunking sound not even two days later. Although now it just sounds different and it's when I hit the breaks... Like something is clunking forward when I try to stop. More of a metallic pinging sound now. I'm guessing it's something different now...
I'm out of ideas. This is maddening.
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
Old 11-17-2017, 07:01 AM   #148
JusticePete
Originally Posted by Childs Play View Post
Brought the car in, had them add the nordlock washers. They put on the new bolts while there.
It's still making a clunking sound. Although not it just sounds different and it's when I hit the breaks... Like something is clunking forward when I try to stop. More of a metallic pinging sound now. I'm guessing it's something different now...
Go back and ave them tighten the strut attention/ radius arm bolts
Old 11-17-2017, 07:12 AM   #149
Childs Play
Will do. I hate not knowing enough about suspension to be able to dig in and find the issues myself. I also hate relying on dealerships.
I appreciate the info. I'll bring it back by to have them take a look at that.
H-Town Camaro Club
Past Rides:
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Old 11-17-2017, 09:44 AM   #150
Childs Play
My lower control arms were loose so check them and check all wheels for the correct torque. I did mine to 120 foot lbs as I have a torque stick from dealer still that works well. Seems anything aluminum incthe supsension will stretch some and loosen a little. My Tahoe did same thing back in 2007. Once you get some miles and go through it then non issue. If can’t then make dealership check everything just say you feel the car isn’t safe and god help them if you get it back and something comes loose after they have checked the car over. They will then check it all. I worked for caddy for years and when heard that they normally jumped as it spelled lawsuit after that. Sometimes you have to push the delalership to do enough. We are finding out the factory isn’t catching half the stuff they should. That’s what you get when don’t want to pay good wages for good mechanics.
Yea I have a beam style torque wrench. I went through when I changed out the wheels and torqued them to 140 ft lb. I'm wondering if I missed torquing one fully at some point now...
I'm still going to drag it back to the dealership and make a list of things I'd like them to check. AFTER I go and re-torque all the bolts to see if maybe that's the problem.
H-Town Camaro Club
Past Rides:
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Old 11-17-2017, 06:30 PM   #151
cciepunk
cciepunk's Avatar
Drives: 2018 SS 1LE W/ PDR
Well, ‘18 1SS 1LE with 1700 miles and bang, clunk, clunk, clunk. Drove right to the dealer and they are replacing the endlinks, but didn’t have them in stock. Have to wait until Monday and am driving a loaner.
'18 SS 1LE Hyper Blue w/ PDR
cciepunk is offline   Reply With Quote
Old 11-18-2017, 04:24 PM   #152
datboi448
datboi448's Avatar
Drives: 2013 2LT RS, 2017 ZL1
Had mine tightened in August, just had to have them tightened again today.
Sounded at first like a tree limb was stuck and hanging from the bottom at first and hitting the ground every once in a while. Rode around the dealership with the manager and he thought it may be end links. Got to a bumpy area and it was constantly rattling and he immediately said, oh yeah let me get it looked at right now.
datboi448 is offline   Reply With Quote
Old 11-18-2017, 10:39 PM   #153
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
This is ridiculous. How many decades has Chevy been building cars? Jeez. I just received the new version of the nuts. They're not only rushed washers built in, but also lock nuts. Those plus loctite should never come lose again. If they do, there's some weird stuff going on w/ the the geometry, vibrations, or something.
Cgocifer is offline   Reply With Quote
Old 11-19-2017, 08:02 AM   #154
Cldgin2
Cldgin2's Avatar
Drives: 2017 1LE SS
Thanks for this post. Mine started in at 4500 miles. Let them know info from here and was out of dealer in about an hour
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
Cldgin2 is offline   Reply With Quote
