Old 07-07-2017, 03:58 PM   #141
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Ok so what an adventure!!! There is so much to talk about and share I am exhausted but I want to leave you guys with some information.... my baseline dyno on this dynocon was low real low only 238 HP.... things to remember florida 90 degree weather 80 percent humidity.. Dyno round one recorded on my cell phone I should have brought my pro camera but I was an idiot so phone microphone blows out pretty bad in the high RPM's.. Dyno night yes night was recorded @ 91 degrees and 68 percent humidity round one netted 345 hp on the initial tune and around 335lb of torque I do have the dynograph saved but this is just a quick post to keep you guys updated when I get everything together I will make a more legit post and yes we got much more then the 345hp by the end of the night on a heat soaked engine after around 9 pulls..
Enjoy
https://youtu.be/dTf7BJkZ2n4
disregard the squeaking at the beginning of the video the car does not make this noise
warning very load and in very raw form - 24 hours no sleep need rest please enjoy
This is not a public video yet and is viewed by link only.
Dustya is offline   Reply With Quote
Old 07-07-2017, 05:35 PM   #142
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
by initial tune, are you referring to the tune you'd get if you purchased the SC kit and didn't have the option of being there in person?
Like if i bought it and installed it myself.
Old 07-08-2017, 08:35 AM   #143
goshawk823
goshawk823's Avatar
Drives: 2017 RS convertible
Originally Posted by Dustya View Post
holy crap. enjoy? yep, I did.
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250
1970 Camaro
2010 2LT RS
2013 2SS RS
Current ride:
2017 Camaro 2LT RS convertible
goshawk823 is offline   Reply With Quote
Old 07-08-2017, 02:23 PM   #144
Dustya
Here you go boys and girls right around 150hp in gains probably a bit more but after 9 pulls on the dyno the engine is def heat soaked. These are 5th gear pulls. 90 deg 68 % humidity 11.4 lbs of boost. I would forsee on a higher reading dyno with a prepped engine possibly over 400
Things to take into consideration this is on a dynocon diff dyno then Storm was dyno'd on. Her baseline was almost 30hp more then mine on the dynojet
Things done - Overkill Supercharger system - Alky Methanol injection kit - Injectors - Fuel Pump - MBPR SS exhaust which deletes the secondary cats and the mufflers so its 3" pipes back from the primary cats with J pipes on it ( Its loud but sounds really really really good ).
More pictures and video's coming
Old 07-08-2017, 02:33 PM   #145
Dustya
So the thing is there really will never be a canned tune when you are getting this kit. You will get the tuner module and you can even rent the exhaust air readout device from Will and you can remote tune with him. I am not sure they will use the final tune from my car for the stage 2 canned tune because I have 3" exhaust going all the way out.
Old 07-08-2017, 06:23 PM   #146
MyneS
STORM
MyneS's Avatar
Drives: 2021 Satin Steel Metallic 2SS
Simply AweSome Dustya!
IG: nacol2012
Check out: The creation of STORM
American Authority Front Bumper, ACS Rockers, GM Dark taillights, ZL1 Carbon Fiber interior dash, Engine Bay “red hot” Dress Up, 6LE Skorpion hood, Borla ATAK w Xpipes (TRADED)
MyneS is offline   Reply With Quote
Old 07-10-2017, 10:46 AM   #147
Dustya
Hoping to make it out to the street racing made safe event in jupiter @ palm beach international raceway on july 22nd few things being finalized and tweaked on the car I will keep you guys updated.
Here is another dyno pull little longer https://youtu.be/2c_nbJl__p4
I know its not much but you can hear how smooth everything sounds no surging at low rpm cruising or anything.
Old 07-10-2017, 12:17 PM   #148
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Congrats on the build!!
Old 07-10-2017, 12:42 PM   #149
Dustya
Thanks cant wait to see what happens with a intake TB and higher stall converter.. launching the v6 on some drag radials at 3500+ RPM could result in some nice times.
Old 07-10-2017, 01:12 PM   #150
goshawk823
goshawk823's Avatar
that is awesome. out of our little 6 banger, no less.
Camaros I've owned:
1970 Camaro
2010 2LT RS
2013 2SS RS
Current ride:
Old 07-10-2017, 01:29 PM   #151
MarkZ
MarkZ's Avatar
Drives: 2016 Camaro RS 2LT
Here is another dyno pull little longer https://youtu.be/2c_nbJl__p4 .
Dude.
Mark
MarkZ is offline   Reply With Quote
Old 07-12-2017, 05:54 PM   #152
Dustya
Hey guys so here we go it's been storming non stop since I got my car back. I will be doing a full review walkthrough and everything once I get a nice day until then just some teasers for you.
Blow off valve sounds https://youtu.be/MTBXph3F08w
And a photo of underhood dirty atm it's been through lots of miles and lots of rain storms lately with no wash. Alky kit is using washer fluid tank tucks everything neatly away. So you can see the new washer fluid on the right placed where the stock air intake box was. I have some underhood appearance stuff happening soon.
Old 07-12-2017, 06:04 PM   #153
lgx6113
lgx6113's Avatar
Drives: 2016 Camaro LGX
Thats a beautiful thing!
lgx6113 is offline   Reply With Quote
Old 07-12-2017, 06:12 PM   #154
cellsafemode
Is their catch can a top screw-on type or do you have to disconnect everything to access the can to empty it?
Also, what's up with the dyno chart at around 6500 rpm? That dip seems weird but it appears it was not tuned out. Any ideas?
