Old 02-02-2018, 11:42 AM   #1513
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
<<My argument is that the Camaro has less visibility, but none of that visibility has an actual impact on driving the vehicle. It simply seems like you can't see out of it. I can drive my ZL1 at any time of the day or night in heavy traffic and zigzag in and out of lanes without a worry at all. And it is because I can see everything that I need to see to operate the vehicle safely. Just because it has less visibility doesn't mean it doesn't have enough visibility.>>
Originally Posted by torqueaddict View Post
Very well said, and I wholeheartedly agree. I'm glad I didn't let the BS get in the way of me actually test driving this car.
Exactly. The first time I checked out the Gen 6 was early 2017. I got in and got right out. Never test rode it. I thought it was awful. Couldn't see out of it. When I checked out the 1LE last April, I decided to be a little less stupid. I actually ADJUSTED everything and went for a test ride. Bought the car on the spot. Is visibilty one of its strong points? No. But it's absolutely totally manageable. And, I'm 5'3", so there's that. Adjust the seat and the mirrors PROPERLY, and use the camera. Problem solved.
EVERY car has compromises, but bang for the buck, performance vs. visibility? Not even worth any discussion.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 02-02-2018, 11:45 AM   #1514
shaffe
Drives: 21 Bronco
Originally Posted by ST1LE View Post
Not to mention the GT has a V6.....WEAK!
Eh I don't think it's weak. I still think the GT is an amazing car. Even though there are faster cars out there I'd take the GT over any of them if i had you know 500K laying around lol
Originally Posted by DevilsReject97 View Post
Even though I'm a V8 guy, I don't see it as a weak option... I think it takes balls the size of Pluto to even consider doing that...much less doing it in such an iconic car.
And so far, it's performed very well....
What he said ^
Lets keep it simple. ..
Old 02-02-2018, 11:52 AM   #1515
SpeedIsLife
Drives: Current Camaro-less
Hint:
If you need a camera, then visibility *is* a problem.
Old 02-02-2018, 11:59 AM   #1516
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Originally Posted by SpeedIsLife View Post
Hint:
Umm, I didn't say it was needed, but I'll use what the car offers me.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 02-02-2018, 12:20 PM   #1517
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Hint:
Seeing as how backup cameras are pretty much standard these days I would say that you're wrong. Same with blind spot indicators. They are almost standard equipment. Are they absolutely necessary? Nope. I use them on my ZL1 but I also turn my head and check. Visibility is not a "problem" in these cars.
Old 02-02-2018, 12:24 PM   #1518
hotlap
hotlap's Avatar
Originally Posted by shaffe View Post
The other forums I'm on must just be a bit more laid back lol. Like said was more just busting your chops.
I actually am not shocked the GT was beat by the ZR1. It's got more power, more torque and they have had the whole lifespan of the C7 to create the perfect Vette. The Vette has always been able to chomp away at supercar performance.
Three points
1)
-------weight------power-----lb/hp
GT----3054 lbs---647 hp----4.72 lb/hp
ZR1---3560 lbs---755 hp----4.71 lb/hp
2) Any Ford fan will tell you torque means nothing...
3) more power, more torque, better power to weight means nothing if it can't be controlled. As shown in 2014
Ronald Reagan -
Old 02-02-2018, 12:25 PM   #1519
hotlap
hotlap's Avatar
4) ZR1 driven by an engineer. GT driven by a professional
5) GT msrp $400,000+, ~ZR1 $130,000
6) The GT has a much more sophisticated, DOHC engine that only displaces 3.5L
Ronald Reagan -
Old 02-02-2018, 12:32 PM   #1520
Gunmetalmissle
Drives: 16 ngm ss
Originally Posted by hotlap View Post
Three points
1)
I saw something recently that said the weight Ford was quoting for the GT is dry weight. It’s really more in the 3,350-3,450 range for comparison purposes.
Gunmetalmissle is offline   Reply With Quote
Old 02-02-2018, 12:48 PM   #1521
13vertss
13vertss's Avatar
Drives: 2013 Camaro convertible 2SS/RS
5) GT msrp $450,000+, ~ZR1 $130,000
Fixed. Tested car was $525,000
13vertss is offline   Reply With Quote
Old 02-02-2018, 01:01 PM   #1522
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Hint:
Like in any vehicle, the cam helps in tight spaces and is certainly nice to have, but very often I back up without glancing at it because I'm so used to not having one. It really isn't a problem.
torqueaddict is offline   Reply With Quote
Old 02-02-2018, 01:05 PM   #1523
shaffe
Drives: 21 Bronco
Three points
1)
1. The GT actually weighs something around 3300 IIRC. (Car & Driver estimates it 3250) the dry weight is 3050 pounds.
2. Good thing I know torque is actually important lol
3. Valid point,
4. Very valid point can't argue that
5. Also true. Now I know this comes off as a fanboyish response, but the GT truely does have a uniqueness and specialness to it. As we have seen with the last gen GT actually increasing in value.
6. I thought a few pages back we decided the DOHC weren't more sophisticated than OHV
Like I mentioned, it didn't shock me the ZR1 bested the GT. I think the ZR1 is going to best just about anything that stands in it's path. Same thing happened in 06 IIRC, the GT came out and I think it was the C6 Z06 that was able to match it's perfromance. And the 09 ZR1 put a hurting on it too.
Old 02-02-2018, 01:25 PM   #1524
FastCarFanBoy
Drives: 2013 GB GT
wake me when the ZR1 wins at LeMans...which was the sole purpose the GT was created and why its configued the way it is.
FastCarFanBoy is offline   Reply With Quote
Old 02-02-2018, 01:34 PM   #1525
AJL13
Drives: 2017 Camaro RS
Wake me up when Ford's half a million dollar mid-engined supercar is faster around the track than a Corvette that is 1/4 of the price and has a front-engine pushrod motor configuration on a 7 year-old platform.
Looks like I'll be sleeping for a while.
AJL13 is offline   Reply With Quote
Old 02-02-2018, 01:48 PM   #1526
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
For some reason this scene from Monty Python and the Holy Grail popped into my mind when I read this ^^^
