Old 02-15-2024, 07:15 PM   #14687
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Paid it a visit at the dealership...
https://www.camaro6.com/forums/showthread.php?t=622725
Daily Driver mileage update: 64k mi. @ Apr 2026
Old 02-16-2024, 05:50 PM   #14688
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Home recuperating from hip surgery so I ordered a MishimotoCatch Can.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is offline   Reply With Quote
Old 02-17-2024, 01:45 PM   #14689
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Should probably get myself a catch can before putting too many miles on it.. Sounds like they greatly benefit Direct Infected engines.
speedyink1 is offline   Reply With Quote
Old 02-17-2024, 02:08 PM   #14690
SSShark
SSShark's Avatar
I've read several threads regarding catch cans for our LT1's and it sounded like a very worth while investment.
Old 02-17-2024, 02:34 PM   #14691
beowulf556
Drives: Camaro SS 1LE M6
put on some EOS ZL1 side skirts
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 02-17-2024, 03:05 PM   #14692
SSShark
SSShark's Avatar
Gotta have the side skirts. Nice looking ride.
Old 02-17-2024, 04:38 PM   #14693
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
how easy / difficult is the install of the side skirts?
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 02-17-2024, 04:58 PM   #14694
beowulf556
Thank you sir!
Super easy. I put the car up on some ramps, and the skirts line up with the tabs under the car. 3M tape on the sides, and screwed in on the bottom. Took about 45 minutes.
Old 02-17-2024, 06:07 PM   #14695
SSShark
SSShark's Avatar
Thank you sir!
Old 02-18-2024, 03:19 PM   #14696
SSShark
SSShark's Avatar
It's been monsoon rains here today so I took advantage and installed the Mishimoto catch can today
Old 02-18-2024, 03:32 PM   #14697
LeonardS
Looks like you need some coolant in both tanks.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 02-18-2024, 03:36 PM   #14698
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I think that’s the best position for the can! Also, make sure you top up antifreeze reservoir! completely full for the top section and the bottom one is halfway to the line
Old 02-18-2024, 03:56 PM   #14699
SSShark
SSShark's Avatar
Good catch guys! Thanks for pointing that out. Honestly, the car has 12k miles and I've never thought to check the coolant since the gauge is always right on.
Old 02-18-2024, 04:06 PM   #14700
CalgaryZL1
CalgaryZL1's Avatar
Yes, it is a non-pressure system and if you look in the mid section of the picture, you see the two breather ports where evaporation occurs. We are so use to having a closed system that we tend to overlook it.
