Old 07-16-2021, 08:45 PM   #1443
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Originally Posted by FollowMyLine View Post
Hey! I'm glad you asked! As of yesterday my 2022 allocation went status code 2000, which means it was accepted by GM.
I have officially ordered a 2022 2SS 1LE in Wild Cherry Tintcoat with the M6. I kept it simple and optioned the red seat belts, PDR, aluminum sport pedals and illuminated footwell lighting. That’s it.
Stock photos but as soon as I get it, I’ll post some more in another thread somewhere:
Love it! Glad to hear the good news!
driven2exceSS is offline   Reply With Quote
Old 07-23-2021, 05:54 PM   #1444
Mountain
Mountain's Avatar
Track = Gingerman
Elapsed Time = 1:39.776
Year / Model / Trim = 2017 SS 1LE
Date = 7/17/2021
Tires = Falken RT660 305/315
Mods = Ferodo DS1.11 pads, Ferodo Super Fluid, Hotchkis rear sway bar (softest setting)
*Start/Finish line was not being set early in the day. Further verification of time: https://timetrials.scca.com/events/1...-1626527525-19
After trying out the Falken RT660 at the SCCA TT Nats, during one of the practice sessions, and really liking the way the tire acts on this car, I decided to grab a pair of 305/30R19's and 19x10.5 M716 wheels to compliment the rear 315/30R19's on 19x11 M716 wheels. I considered running the 275/30R19's I have, but after the one practice session I ran them, I see them wearing out really fast and being a lot more susceptible to over-heating. With 305's - larger heat sink. Plus I wanted to see what more grip up front would do.
I had tried this 305/315 setup in an autocross setting, nothing else different from the times I ran 275/315, and it's pretty notable how much more confident the front of the car becomes. In an autocross setting, the car seemed basically dead-neutral.
For the Gingerman TT, I also swapped over to the Hotchkis rear sway bar from the FE3 coupe bar I've been running. The reason I did this is because, at NCM, I noted a bit of understeer in the tight, technical sections of the track. It wasn't enough to kill lap times, but enough to force you to be a lot more careful about what you do with the car, how you setup corners. The Hotchkis rear bar, in the softest setting, provides a bar that has the same rate as the OEM FE4 bar, but allows for non-bonded bushing, freeing up the rear suspension movement. That is the reason why I decided to try the bar.
At the SCCA TT event, before I threw on the RT660's, I ran the OE SC3 setup. The reason being as I wanted to see how the car felt, what the car was doing, compared to how it acted prior, with the OE bars I've tried. If you page to the Group 1, Session 1 practice sheet, you'll see that my times aren't representative of "a fast lap" for the setup, comparing to my past times - my focus was to put down "a good time" and to note what the car was doing over trying for my fastest lap. In particular, the car would have some very mild push at corner exit of T11 of Gingerman. I also wanted to see how the car took T10b. From what I could tell, the Hotchkis bar, in the softest setting, seemed to keep the balance I remember from past events (including past Gingerman events); however, the rear of the car had a slightly different feel - it definitely felt a bit less "tangled". To be clear: the car was cornering just as it was with the OE FE4 bar, the roll stiffness balanced did not seem to have changed, but the rear of the car did seem to be able to move freer.
I am really eager to run at another tight, technical track to really see if the non-bonded bushings show a bit more.
On the 305/315 setup, as it moves closer to a square setup, I did notice the car become a bit more loose (balance more a bit more toward oversteer). I think there is a low-1:39 or high-1:38 there, from looking at my data. I wasn't able to improve my time during competition, as I kinda lost my head on my laps through the weekend, overly focusing on a few areas for improvements, and not minding other areas where I was a bit off. I was having issues with my PDR, at first, getting the Start/Finish line to set and then my laptop was all jacked up, so I couldn't analyze my data - once I got home and fixed my laptop, it was very evident I wasn't doing the T7-8-9 sequence right during competition, for some reason, and my line out of T2 evolved a bit too tight, which killed some speed out of T2.
If you guys haven't yet done the SCCA Time Trial events, I highly, highly recommend them!
On a scale of 1-10, with 5 being "neutral", 1 being "complete oversteer" and 10 being "complete understeer", I would rate:
-OE setup = 6
-FE3 rear bar = 6.5
-RT660 305/315 setup w/FE3 bar = 5
-RT660 305/315 w/Hotchkis bar = 4 or 4.5.
Update: I’m very confident that the Hotchkis rear bar is likely the ticket to curing my concern, as I’ve done some street driving on the shitty Metro-Detroit roads and the ride quality out of the rear of the car is noticeably better than before. A lot less shimmy from the rear over bumps. Much smoother.
Old 07-26-2021, 12:50 AM   #1445
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
Track = Ridge Motorsports Park
Elapsed Time = 1:46.61 (PDR), 1:46.629 (Official event timing)
Year / Model / Trim = 2019 ZL1 1LE
Date = 7/25/2021
Tires = Goodyear Supercar 3 325/30-19
Mods = MCS 2WNR, 19x12 square Apex SM10, DOT4 fluid, DS2500 pads, front bar
rotis is offline   Reply With Quote
Old 07-26-2021, 04:57 AM   #1446
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
Date = 7/25/2021
Nice lap!!!
khcoaching is offline   Reply With Quote
Old 07-26-2021, 07:29 AM   #1447
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Originally Posted by Mountain View Post
Track = Gingerman
Date = 7/17/2021
-OE setup = 6
-FE3 rear bar = 6.5
As always, thank you for the detail on the post and the experimentation with the rear sway bar, it looks like you have found a winning combo!
Times have been updated!
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 07-26-2021, 11:45 AM   #1448
Krispy
Drives: Camaro SS 1LE
Originally Posted by GTASS1LE View Post
Thanks! Ya, I'm not quite there yet...and the Cup2's were losing grip after 5 or 6 laps so didn't want to get too close to the limit in turns 4 and 8. I had a couple of laps that were spoiled at 10 which would have been in the 1:32's...next time
Hopefully this video will help in your quest for 32's, keep at it!
Track= Mosport (Canadian Tire Motorsport Park - CTMP)
Elapsed Time = 1:31.42
Year / Model / Trim = 2017 Camaro SS 1LE
Date = 7/26/2021
Tires = OEM SC3
Mods = Camber plates + alignment + StopTech 660 brake fluid
Krispy is offline   Reply With Quote
Old 07-26-2021, 11:55 AM   #1449
FollowMyLine
Driver for Hire
Updated
Luan Zeqollari
YouTube Channel
Old 07-26-2021, 02:04 PM   #1450
TrackClub
TrackClub's Avatar
Date = 7/26/2021
Tires = OEM SC3
One word Chris: TREMENDOUS!!!
Old 07-26-2021, 03:05 PM   #1451
Mountain
Mountain's Avatar
You’re welcome.
Question: Why delete my old time from the list? Wouldn't that be of some value to see same driver, different setup improvements/comparisons? Not just a constantly moving “leader board”…
Old 07-26-2021, 06:52 PM   #1452
NEZL1
Drives: ZL1 1LE
Track= Thompson Motorsports Park
Elapsed Time = 1:19.04
Year / Model / Trim = 2018 Camaro ZL1 1LE
Date = 7/24/2021
Tires = OEM SC3r Rear / Well worn RE71Rs Front
Mods = Heartbeat blower / 1 7/8 headers / Hawk DTC 70/60 Pads
NEZL1 is offline   Reply With Quote
Old 07-26-2021, 11:42 PM   #1453
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
Elapsed Time = 1:49.88
Year / Model / Trim = 2018 Camaro SS 1LE
Date = 7/25/21
Tires = GYSC3
Mods = Alignment, RBF600, BMR cradle lockout.
Video:
https://youtu.be/5WtYIVNIEOs
Official timing: https://timetrials.scca.com/events/1...ssions/overall
eimarshall is offline   Reply With Quote
Old 07-27-2021, 06:25 AM   #1454
khcoaching
khcoaching's Avatar
Date = 7/25/21
Tires = GYSC3
Video:
Nice!
Old 07-27-2021, 03:52 PM   #1455
eimarshall
eimarshall's Avatar
Originally Posted by khcoaching View Post
Nice!
Thanks Ken! I really tried to trail the brakes into 2, 8a and 11 and it really paid off! I still left some on the table into 12 and through 6. But I’ll take the sub 1:50 to close out my year!
Old 07-27-2021, 04:23 PM   #1456
khcoaching
khcoaching's Avatar
So glad we got to do a few laps and hopefully (HA! You did!) see why those lines make more sense as you go faster. Super impressive!
I saw you were on SC3Rs? How did they work? Did that noise go away?
Ken
