View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.97%
2017 57 34.13%
2018 77 46.11%
2019 3 1.80%
2020 4 2.40%
2021 1 0.60%
Voters: 167. You may not vote on this poll
Old 10-24-2024, 01:12 PM   #1415
hawk02
Coupe Newbie
hawk02's Avatar
Yes, the pumps have been updated a few times, but anything from 2019+ is safe.
I traded my '17 ZL1 for a '23 5BW in May. My ZL1 was from the first production run with a build date of 10/20/2016. The oil pressure at idle when warmed up was in the low 30s, usually 31-32 psi. On the Blackwing, it's in the upper 30s, typically 37-38 psi. Shows something was definitely changed in these later LT4 engines.
Old 10-24-2024, 03:40 PM   #1416
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Mine was 42psi when i first got it. Over time it settled to around 32psi at idle until the pump started to break down around 14k miles.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 10-24-2024, 06:10 PM   #1417
ZL1 C ya
ZL1 C ya's Avatar
Drives: 2018 ZL1 Camaro Convertible
Approximately $4200 including the Katech pump. I just did the pump. This car has all the power I need. I can barely use the power this car has. I have had it up at New England Dragway and ran a 11.50 on street tires so I am pretty happy with its performance.
Thank you to Jannetty Racing for doing the repair. They started the job on a Monday and I was picking it up the same week on that Friday. They did an amazing job, I could'nt be happier.
ZL1 C ya is offline   Reply With Quote
Old 10-24-2024, 07:53 PM   #1418
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Originally Posted by ZL1 C ya View Post
All loaded up and on its way to Jannetty Racing for voluntary surgery. I am outside of my warranty and I was not willing to wait and see if my oil pump would let go.
Spoke with Al over at Jannetty Racing a couple of weeks ago and setup the appointment to have the pump replaced with a Katech Pump.
Al was great to work with. He got right back to me with a very reasonable estimate considering they are removing the entire motor to ensure they do the job correctly.
I will be excited to get the car back and to drive it without the stress of damaging a 15-20k motor.
They did mine in April of 2023. Top notch work. Same deal. Change it before it broke.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 03-04-2025, 09:52 PM   #1419
F N MUSCLE
F N MUSCLE's Avatar
Hey everyone. Been a while since I last posted. Kind of concerned my 2018 ZLE is about to be added to the list of oil pump failures. Warm idle usually runs just above 30psi with cold idle in socal around 38psi. Once the car is warmed up though and i park in the garage a few minutes, been noticing the psi dropping to 27 or 28 psi. Some of you that had failures noticed this too right and once it starts dipping to the low 20s, thats basically it and the pump is on its way to failure? Bought a non GM service plan / extended warranty from my local chevy dealership last year. Car has 14,643 on the odo. No mods. Should I call a few of my dealers to see if theyll replace it or do i need to anxiously wait until it completely fails? Option 2 is obviously concerning. Any thoughts are appreciated.
F N MUSCLE is offline   Reply With Quote
Old 03-05-2025, 09:21 AM   #1420
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
The car I bought (2018 ZLE) had its pump fail on them ended up replacing the whole motor with a LME long block, added my car to the poll
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 03-05-2025, 11:20 AM   #1421
Mark R
Drives: 2018 ZL-1
No warranty company will replace the pump proactively. If you want to eliminate worry, you will have to replace it before it breaks. Your car is an '18. It's in the breakage zone. I replaced my pump with a Katech.
Old 05-21-2025, 08:59 AM   #1422
Outahand
Drives: 2018 ZL1
I am joining the club with my 2018 ZL1. Yes I added it to the poll.
Any recommendations for a shop in the Ca Bay Area? I am in San Jose.
Planning to use a Katech. Not sure if my local dealer would install a Katech if I wind up going that route.
Mark E.
2018 ZL1 NGM A10
87 Grand National. Modified Hot Rod for sale *SOLD*
87 Grand National. Stock
65 Olds Vista Cruiser wagon Grand National motor/tran
66 Bronco Rockbuggy
2006 Dodge 2500 4x4 Cummins 6 speed
Outahand is offline   Reply With Quote
Old 05-21-2025, 03:11 PM   #1423
Outahand
Drives: 2018 ZL1
Katech recommended Abel Chevrolet in Rio Vista.
One of my Buddies in our local Buick GN club that used to work there recommended them also.
Mark E.
2018 ZL1 NGM A10
66 Bronco Rockbuggy
Old 06-06-2025, 10:35 PM   #1424
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
I think the oil pump in my 2016 SS just failed. I pulled into my driveway and shifted to park and then the low oil pressure warning came on. I shut it off. I started it back up a little bit later and gave it a few tiny revs in park and the oil pressure did go up but then down to zero again. I'm hoping there's no engine damage. I'll be having it replaced with the Katech one though.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 06-10-2025, 11:07 AM   #1425
Outahand
Drives: 2018 ZL1
Sounds like mine. I got a reduced power message on the highway but pressure was still almost 40.
When I idled it gave me the low oil pressure message.
Waiting for my pump now. Katech said it should ship this week. About 3 weeks from order date.
I got their timing chain and guide also just because....
Mark E.
2018 ZL1 NGM A10
66 Bronco Rockbuggy
Old 06-22-2025, 08:50 PM   #1426
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
I'm sorry to hear about your oil pump. How many miles were on your car? Did you have any modifications done to your car?
george is offline   Reply With Quote
Old 06-23-2025, 12:18 AM   #1427
Outahand
Drives: 2018 ZL1
65k
Factory stock.
Katech pump arrived in 2.5 weeks.
It’s at Abel Chevrolet now.
Mark E.
2018 ZL1 NGM A10
66 Bronco Rockbuggy
Old 09-18-2025, 09:31 PM   #1428
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
Well it got me guys, 27k miles. Took it to CSP in west Chester PA. They put in a katech and their big boy cam while they were in there.
02fbody35th is offline   Reply With Quote
