Old 10-31-2023, 07:12 PM   #14239
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Originally Posted by DevilsReject97 View Post
Finally received my mats for the ZL1. I had these in my previous ZL1 and my Redeye.
Just need to finish the interior detail so I can put them in.
Great fitting mats and well priced, also one of the 1st thing I ordered when I got the car.
Old 10-31-2023, 07:26 PM   #14240
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
Yep, they were ordered before the paperwork even went through on my ZL1
I've had them now in a total of 4 cars, and I would recommend them over and over and over again. The last 2 have had the trunk mat as well. I didn't have the trunk mat in the first ZL1 and I regretted it.
Old 10-31-2023, 07:51 PM   #14241
ZPirate
ZPirate's Avatar
3D Maxpiders are the best all weather mats. I have them in several vehicles.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 10-31-2023, 09:15 PM   #14242
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
I did my first transmission oil, filter change and custom pan swap today. I just drilled a hole in the original pan for for a spill free no hassle drain, going to install drain plug bung in it as well. After draining for a day into the catch pan I measured what came out and pumped new oil back in. I will say this oil stinks worse than the diff oil!
I’m impressed. You made a pain in the ass job look easy, while improving the process when doing it.
Old 11-01-2023, 04:24 PM   #14243
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1978 Beechcraft Baron
Installed genuine sheepskin driver seat cover. I put these on all my vehicles at least on the driver's side. Greatly improves seat comfort and they are cool in the summer and warm in the winter. Also protects the seat from abrasion wear. It does impede the effectiveness of the seat warmer and fan in that it takes longer to feel the effects of the seat warmer and it's hard to tell when the cooling fan is working at all, but you really don't need either with this installed.
dfwcowboy is offline   Reply With Quote
Old 11-01-2023, 04:27 PM   #14244
dfwcowboy
dfwcowboy's Avatar
I installed a set of lift pads. This tool made quick work of the job with no jacking required to install them. I wish I had thought of using this with the set I installed on my last car instead of fumbling around with a regular allen wrench.
Old 11-01-2023, 05:05 PM   #14245
ZPirate
ZPirate's Avatar
LOL! I wish I had seen this before installing my lift pads this past weekend.
Old 11-01-2023, 05:26 PM   #14246
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Installed ZL1Addons rock guards, hopefully cut out the chips now
Also got the front bumper done with PPF
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-01-2023, 05:31 PM   #14247
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
link please
Old 11-01-2023, 07:25 PM   #14248
dfwcowboy
dfwcowboy's Avatar
Originally Posted by 302crossram View Post
link please
I’ve had this thing for well over 30 years. Didn’t know they still made them. You can get these from other brands a lot cheaper. Just need a 1/8 allen bit for it.
https://www.amazon.com/Apex-Tool-Gro...ps%2C91&sr=8-5
Old 11-01-2023, 08:18 PM   #14249
Here's an even better, slightly more modern alternative (made in Japan): https://www.amazon.com/gp/product/B002655H5U. I've had it for a year, it's sturdy and reliable.
The angled grip helps tremendously in tight spaces, say, in wheel wells when messing with liner screws or installing splash guards, and you don't want to pop the wheel off for just one or two itsy-bitsy torx screws.
Old 11-01-2023, 09:00 PM   #14250
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Used these to install the rear GM rock guards. Didn’t even have to remove the rear tires.
STYLO LT1 is offline   Reply With Quote
Old 11-02-2023, 11:26 AM   #14251
ClaunchOfficial
ClaunchOfficial's Avatar
Drives: 2024 SS 1LE
Panther emblem, decals and ACS rockguards
ClaunchOfficial is offline   Reply With Quote
Old 11-02-2023, 11:40 AM   #14252
Bumbleboy92
Long hauler
I just installed my rock guards by using a wrench twisting a Phillips's head and it sucked, didn't even think that these would work better since they're slimmer!
I didn't know the Panther emblem could be ordered separately
2016 1LT v6
- Totaled
Happiness: Infinite
