Old 10-20-2023, 07:55 AM   #127
split_bumper
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper
Originally Posted by SwL_Wildcat View Post
With Bumbleboy's list of VIN's I pasted them into an excel sheet to populate column 2, then added the prefix "https://cws.gm.com/vs-cws/vehshop/v2/vehicle/windowsticker?vin=" into column 1. Column 3 I told it to CONCATENATE the first 2 columns which gives the window sticker VIN. Column 4 grabs column 3 and makes it a hotlink. No copying and pasting every VIN (That would suck!), just clicking links. Bumbleboy and raidator did all the hard work locating valid VIN's.
Yes I got in touch with radiator and he filled me in. If i was better at coding I would have done the same. What I wish I knew how to do was write a code to go through and search each vin txt doc that radiator sent me, and from that populate the exterior colour, transmission, body style, msrp, and dealer location and name. From that I think we could get a pretty good handle on every car config. And to add to that, with a vin link for window sticker we could basically have every car specced out. Just how far we want to go with it. I have a friend thats good at coding who is going to ty and help me work on it, but maybe radiator or bumbleboy can help some if they find the time.
The list you have for collectors edition, I basically have for any radiant red ones, i manually searched and went through the 700 window stickers lol.
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531
split_bumper is offline   Reply With Quote
Old 10-20-2023, 09:19 AM   #128
Originally Posted by Bumbleboy92 View Post
Sorry I meant at current production as in maybe this is the latest one they’ve built, they still have a good 120 at least to build at this rate. If by chance they aren’t skipping sequences and it’s rather like what I said above where stickers aren’t uploaded for already built cars then I’m willing to bet current production as of today is around #180 and yours will be at the least after #180
Gotcha... Camaro Cave reported a couple weeks ago that there were only 24 coupes left to build. Not sure how accurate that is though.
Old 10-20-2023, 09:42 AM   #129
raidator
raidator's Avatar
Drives: 24 2SS CE M6 convertible
I'll take a stab at them tonight or tomorrow, won't take that long to put them into csv for the things you're looking for, (body and trans is already pretty much done based on VIN #) I'll just have to dig up the RPO codes for this year for the colors and can break them out that way, then dig for the options like NPP and F55 that a lot of folks look for.
raidator is offline   Reply With Quote
Old 10-21-2023, 12:39 AM   #130
raidator
raidator's Avatar
I have something you all will probably like, I took all the info and built a csv (easy to import in to excel and make it a fancy xls file) that has serial #, vin#, trim, body, trans, color, MSRP, dealer, city, state, order #, link to window sticker, and then all the RPO codes in a single column its about 5600 lines or so and took about 15 mins to build using every window sticker I've scraped so far...
I had to convert it to a zip so I could upload it here
Old 10-21-2023, 04:20 AM   #131
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Very interesting! Did you have to download each pdf and have a script search through?
Edit: having looked at the file I see I misunderstood how you were getting the data, where did you get all that data from? I’ve been solely going through and doing API calls to the window sticker link and matching them manually for CE VIN’s but you have way more information including RPO codes which I didn’t even know you could find online for a specific VIN
2016 1LT v6
- Totaled
Happiness: Infinite
Old 10-21-2023, 05:29 AM   #132
Bumbleboy92
Long hauler
I see another potential error as well in the list. Nicholas Brown on Facebook has #69, but mentions that Serra was excellent to deal with. He also lives in Michigan, where Serra is. If that is correct it may be possible that the cars are not in chronological sequence off the line.
I reached out to them and they confirmed they are sequence 105876!
2016 1LT v6
- Totaled
Happiness: Infinite
Old 10-21-2023, 05:50 AM   #133
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
I talked to Nicholas yesterday morning too, he was going to confirm the VIN. That throws a monkey wrench into the theory that they all came off the line sequentially. I'm wondering if this is just a 1 off and there were 2 cars on the line and the steering wheels got accidentally swapped? I'll leave the list in chronological order by VIN for now until we see how wide spread the issue is.
SwL_Wildcat is offline   Reply With Quote
Old 10-21-2023, 07:51 AM   #134
SwL_Wildcat
Drives: 2024 ZL1
Half way there! We now have 175 of the cars found, 50%.
Old 10-21-2023, 09:21 AM   #135
motorhead-mwc-
Cars and Crosbie
motorhead-mwc-'s Avatar
Drives: 16 1SS / 24 ZL1 CE
PPF is done, Updates on the door spears and watch
https://youtu.be/EU-kXZRMdsI?si=EoiqPOVSf7F5hKHY
Live and breathe in the Automotive world. Proud GM emp and owner of a 6th gen
motorhead-mwc- is offline   Reply With Quote
Old 10-21-2023, 09:49 AM   #136
I'm going to Austin next week and it looks like they have one or maybe two on the floor. Will be interesting to see what the markup is.
Old 10-21-2023, 09:56 AM   #137
SwL_Wildcat
Drives: 2024 ZL1
That stealth wrap looks awesome! I think the glossy parts look out of place. Do they make a semi gloss wrap between the stealth and the clear? I'd like to tone my glossy bits down a bit.
Last edited by SwL_Wildcat; 10-21-2023 at 03:55 PM. Reason: Apparently I can't spell... ;)
Old 10-22-2023, 12:50 AM   #138
raidator
raidator's Avatar
finished another scrape of VINs and found 2 more ZL1 CEs... so I show 177 total.
Including the updated numbers for all trims. now seeing ~6400 units.
Old 10-22-2023, 07:55 AM   #139
SwL_Wildcat
Drives: 2024 ZL1
Thanks. The window stickers aren't working just yet. I'll put those 2 on when I can get the state and dealer off the sticker.
The big question is why, after numerous runs through all the VIN's, are we missing cars, Like #2? There are big gaps between known car numbers. Are they going to assign #2 to a car that was built near the end of the production run? Or did they change a VIN digit? Just a bad example, but say instead of a R for the engine digit they used a T? I can't see you missing any VIN's within your search, so we have to be searching for the wrong thing.
Old 10-22-2023, 09:51 AM   #140
raidator
raidator's Avatar
not sure why you didn't pull the right sticker, that's how I found them...
1st R/D is restraint system (coupes have more airbags obviously), 2nd R is the year... engine is the 6 after the D/R
1G1FK3D63R0112477,$100125,SIMPSON CHEVROLET OF GARDEN GROVE,GARDEN GROVE,CA
1G1FK3D62R0112485,$98385,HARBOR CHEVROLET,LONG BEACH,CA
