Old 01-16-2020, 06:19 AM   #127
wnta1ss
Drives: 2017 Camaro 1SS
Loss of boost from better flowing exhaust doesn't mean less power...it just means you removed a restriction and that is all Boost is a measure of.
YES! So true.
I keep seeing people worrying about 'losing boost' from other mods. THE BLOWER IS STILL SPINNING THE SAME RPM after you install long tubes or whatever, so you did not lose anything guys. The idea that you have to then pulley down to 'get the boost back' is bogus.
Old 01-16-2020, 07:13 AM   #128
laynlo15
Drives: 2022 Lt1 A10
The cure for this problem is to install a larger supercharger or smaller supercharger pulley if its available for your application.
Improving Engine Breathing:
Heads, cams, header, cat back exhaust, etc., that increase HP, may lower boost. As with a larger displacement engine, the supercharger speed or size may have to be increased to match the additional air flow/HP of an engine with improved breathing characteristics. The cure for this problem is to install a larger supercharger or a smaller supercharger pulley if its available for your application.
This is not from me or Magnuson but from Kenne Belle Superchargers
Old 01-16-2020, 08:14 AM   #129
IneedAZ
IneedAZ's Avatar
Originally Posted by SienarSystems View Post
@IneedAZ: I’m going to have to use an adapter for the 95 tb. The standard snout is for an 87mm (stock ZL1). Magnuson offers optional 103 and 112mm snouts. See Ted J’s posts about the 112mm snout.
@laynlow15, King or others- how do I determine belt size for the smaller pulleys? Looks like the only LT4 pulley ZPE has in stock is an 85mm. What gates belt do I need?
I may have missed it, but what RWHP is the goal now? Now that you have the SC installed, i like to see if you can reach 725-750rwhp without a cam or meth.
Old 01-16-2020, 08:55 AM   #130
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by IneedAZ View Post
Gotta ask, why the ported 95tb vs just getting a 103tb? Like to here from the Tuners as well, why 95 and not go with the 103?
in throttle bodies bigger is not alway better it should be sized for your build.
A 95 easilly makes 850 RWHP.
Moving to a 103 might be worth another 5-10 at that power level but near nothing at 750 RWHP.
Cabish? Italian for Understand?
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-16-2020, 08:56 AM   #131
JANNETTYRACING
Originally Posted by wnta1ss View Post
YES! So true.
I have gained 125 RWHP 155 RWTQ without pulley changes on my ZL-1
So there is a lot of power through efficiency if you know where to look and how to unleash it.
Ted.
Old 01-16-2020, 09:26 AM   #132
laynlo15
Yep that's true also.
Old 01-16-2020, 09:33 AM   #133
IneedAZ
IneedAZ's Avatar
Ted.
Thanks for the reply. Guess i was thinking the 103 would match nicely to the 103 snout, but the 95 with the adapter is still being reduced to the 87 snout. That is why i wondered why not just go 103.
Old 01-16-2020, 09:43 AM   #134
JANNETTYRACING
The standard snout is larger than 87 so it matches up nicely
Remember even an 87 bore flows more air than an 87 TB due to the blade and shaft taking up space.
Ted.
Old 01-16-2020, 10:06 AM   #135
IneedAZ
IneedAZ's Avatar
Ted.
ok, Gotcha!!
Ted, have you done any 2650's without a cam or meth but did TB, CAI, LT exhaust, and tune? Just wondering if those are enough mods to get to the 725-750rwhp range reliably?
Old 01-16-2020, 10:21 AM   #136
JANNETTYRACING
ok, Gotcha!!
750 would be easy with a 2650 and about 13-14 psi boost but would max out the fuel system.
Ted.
Old 01-16-2020, 10:35 AM   #137
IneedAZ
IneedAZ's Avatar
Ted.
forgot to include the FP booster...I assume that is a must.
Old 01-16-2020, 10:50 AM   #138
JANNETTYRACING
Definitely.
Old 01-16-2020, 10:54 AM   #139
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Diane Feinstein and Nancy Pelosi will be at your house with an impeachment article to have it removed and take your car from you.
ssmofo is offline   Reply With Quote
Old 01-16-2020, 11:23 AM   #140
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I am TRIGGERED...
'20 ZL1 Black "Fury"
