Old 04-12-2020, 11:53 AM   #127
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Originally Posted by Trochoidal View Post
One week short of 6 months!
So this wasn’t a terrible install. Going in from the top makes good sense. IDK what I liked more, the radiator cover, the 3 Christmas tree fasteners or hood latch alignment. The actual install of Velossa was quick.
Tip#1
Put the small side in first, where the hood release was, down and to the left. Wiggle it beyond the headlight housing and start tucking behind the rubber.
Tip#2
Use a long 3/8”’extension, swivel and shallow socket to remove the 13mm hood latch boots. I went in through the grill.
Tip#3
When re-installing the hood latch bolts, the Velossa was in the way for the driver side bolt. The 3/8” extension fits without the socket. I sat the hood latch on top of the radiator cover. Once the extension was within reach I attached the 13mm socket and swivel to the extension. Grabbed the bolt, put it in the socket and guided it through the hood latch and put the bolt back in. (This is a balancing act. I didn’t drop any bolts, but be careful if you do it this way, there’s a cooler below).
Took it out for a drive!
Thanks for the hood latch re-install tips!
Approximately, how long did it take you to install from the top?
I just ordered mine yesterday, so hopefully by next week Sat. it will be here.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 04-12-2020, 02:28 PM   #128
Trochoidal
Drives: 2017 Camaro 2SS A8
You’re welcome. Hope it helps. 2 hours.
Old 04-13-2020, 11:07 AM   #129
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Originally Posted by 6spdhyperblue View Post
It doesn’t skew the maf reporting on the gm cai. Do it.
Tune or not skewing is skewing. The important factor is that i checked it(I datalog with a wideband way to much and validated to 140mph) with the same cai as u. Ur good bruh. Enjoy
Thanks brother, this is the greenlight I was waiting on. Hopefully I'lll get to it soon with all this down time at home.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 04-13-2020, 12:20 PM   #130
Trochoidal
There were a few people that wanted some data. In an effort to do some incremental data logs, RF and port TB were not on after the Velossa was installed.
I’m going to get one more log and that will be with ported IM/TB & stock CAI. I might even toss the RF back on for grins.
No Velossa Stock CAI, TB & IM
RPM - 6246
MPH - 84
Cyl airmass - 0.81g
MAP - 96 kPa
MAF (SAE) - 2629 lb/hr (331 g/s)
MAF sensor- 8403 hz
RPM - 6243
MPH - 86
Cyl airmass - 0.83g
MAP - 96 kPa
MAF (SAE) - 2695 lb/hr (339 g/s)
MAF sensor- 8438 hz
Edit:
Velossa, Stock CAI, Katech TB & PP IM
RPM - 6252
MPH - 87
Cyl airmass - .84g
MAP - 97 kPa
MAF (SAE) - 2817 lb/hr (355 g/s)
MAF sensor - 8421 hz
