Old 04-13-2017, 12:03 PM   #127
TrackClub
TrackClub's Avatar
That's what I saw on your vid. The car seems incredibly stable on entry.
Old 04-14-2017, 07:57 PM   #128
Chub2000
Chub2000's Avatar
Drives: 2018 camaro zl1 , 2007 porsche GT3,
im very low tech..how do i download the video from my SD card to my computer ?
Chub2000 is offline   Reply With Quote
Old 04-14-2017, 08:08 PM   #129
slowman
Drives: 2017 SS 1LE|08 Civic Mugen Si
You would need an SD card reader that plugs into a USB port on your computer. Once that's accomplished, it should show up in your Windows File Explorer as a drive then you can manage the files how you want from there.
2017 Camaro SS 1LE Krypton Green
YouTube
slowman is offline   Reply With Quote
Old 04-14-2017, 08:35 PM   #130
Chub2000
Chub2000's Avatar
I can watch the videos while the SD card is in the computer but it wont let me transfer them to the computer. Will the sd reader do that ?
Old 04-15-2017, 11:13 AM   #131
Chub2000
Chub2000's Avatar
here are a couple of my videos from NJMP Lightning track...im very low tech with all of these tech buttons on cars...i had full traction control on and didnt realize it. it just seemed like the car was underpowered to me. i guess it was fast considering i was only using about 75% of its capability.
Old 04-15-2017, 04:37 PM   #132
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Yes, you need to access PTM. Read the performance supplement included with your owners manual. The stability control cuts timing quite a bit outside PTM, so yes... most of the time you were trying to accelerate with yaw in the car, it wasn't giving you full power.
Provoste is offline   Reply With Quote
Old 04-15-2017, 05:35 PM   #133
Chub2000
Chub2000's Avatar
Thank you. A friend of mine told me about all of those buttons at the end of the day.
All things considered i was still able to overtake most of the cars on the track. Im very impressed with this car so far.
Old 04-15-2017, 09:50 PM   #134
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Here's my best session from today at Gingerman Raceway. Skip to 11:00 for the good laps. 1:41.04 was my best, which is damn impressive for showroom stock on street tires.
Old 04-16-2017, 02:33 AM   #135
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
cool, car seems to be hooked up and easy to rotate at those pressures and you're alive
How did you like the pads? It didn't seem like a track that could be very harsh on the pads ( some of straights to cool them down) What kind of camber you were running?
glamcem is offline   Reply With Quote
Old 04-16-2017, 08:29 AM   #136
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
In the 13 years I've been tracking at Gingerman I've never heard anyone say it's easy on brakes. The pads are perfectly fine, the tires don't have enough grip for the pads and the ABS calibration is frankly rather poor. If you apply the brake too quickly the ABS goes into a kind of "coast down mode" and braking distance goes frustratingly long. You have to lift and reapply to get out of the "coast down mode".
The car rotates best by rolling back on the throttle early. It refuses to lift oversteer unless the rear tires are cold. Speaking of tires, the staggered setup seems stupid. The fronts heat up quicker than the rears, and then once the rears come in you only have a couple laps before the fronts get greasy. The entire session is dominated by tire temp management rather than complimenting the suspension.
Overall the car is easy to acclimate to and its behavior is benevolent.
Old 04-16-2017, 10:12 PM   #137
glamcem
glamcem's Avatar
I didn't say "easy" I said "didn't seem too harsh on brakes " at least compared to our local tracks where there are al lot of elevation changes and multiple tight corners followed after long straights.
For the reference, I didn't run into that ABS issue even when I matched the Oem tires with ST43S but I also didn't get a chance to use them for an extended session either. Thanks for sharing
Old 04-18-2017, 10:48 AM   #138
tx6g1le
tx6g1le's Avatar
Drives: 2017 Camaro 1LE
Some shots from Track Night in America.
2017 Hyper Blue 1LE
tx6g1le is offline   Reply With Quote
Old 04-18-2017, 01:09 PM   #139
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Nice! Did you get PDR footage from the track night event? I'm looking to do my first SCCA Track Night event next month, any pros or cons in comparison to other HPDE's?
Old 04-20-2017, 12:23 AM   #140
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I posted this in the tire thread that got moved, so for 1LE owners who don't venture out of this section here it is below:
I took the car out this weekend in show room condition (minus different brake fluid and alignment) just to see where it was at. This car is so incredible in factory form and the tires surpassed my expectations for a street tire. They will be good to go for 95% of owners.
Below is some data from this weekend at Thunderhill West, a relatively short 2 mile course in Northern California. Ambient temps were around 60-70*.
Alignment:
F: -2.4* Camber, 1/16th toe out
R: -1.6* camber, 1/16th toe in
TEMPS after 3rd session:
LF: 156/158/160 RF: 160/161/167
LR: 159/162/162 RR: 158/165/173
Pressures after 3rd session:
LF: 37 RF: 39
LR: 37 RR:38
So you can see that this track is much harder on the right side tires. Towards the end of the day the tires got a little greasy, mid corner and corner exit push increased a lot. You can see by the temps that the car could actually use a bit more camber (you want the middle of the tire to be the hottest), at least at this specific track. Tire pressures were also increasing throughout the day, despite starting at 28 cold. It appears that the tires work better in the 36 range, but don't quote me on that.
I haven't checked tire wear with a gauge, but I noticed the outside of the tire seemed worked, which would make sense looking at the tire temps. I may see if I can get a bit more camber, and also play with temps a bit. Overall really impressed with the car and tires, they will support most owners.
I would highly suggest everyone check their alignment, even if they plan on leaving the factory street specs. My car along with other owners on here have had a factory alignment that was a bit off. I had mix matched camber and toe.
seanblurr is offline   Reply With Quote
