04-12-2024, 10:22 AM | #1 |
How much water is there expected to be around window seals after a wash?
Greetings!
Did my first wash and detail last weekend, unfortunately I have no pictures at this time, but I noticed something peculiar, and was curious as to how "normal" it is. Just using a regular hose, I washed around the windows and noticed water getting "stuck" between the weather strip and the glass, almost seemingly getting into the interior. Is this to be expected? I had a similar phenomenon on my 88 IROC, but I chalked that up to old seals and technology. Just curious!
2024 2SS Camaro, Riverside Blue Metallic, NPP, F55, CF5, 5ZZ, VTU, S0O, 5KP, JF5, 2nd Gen GFX
04-12-2024, 10:38 AM | #2 | |
Drives: 2024 Camaro 1SS M6 Join Date: Nov 2023
Have a look at where your windows meet the top seal. From the factory, the drivers side isn't aligned correctly on my '24 and I need to take it to the dealer for adjustment. Another user had the same issue and documented it here: https://www.camaro6.com/forums/showthread.php?t=623845 |
04-12-2024, 10:41 AM | #3 | |
It certainly isn't as extreme as that example, but I will have to take a deeper look. Taking it to the dealership soon for an option they initially lied about installing.
04-12-2024, 10:59 AM | #4 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
I get a little bit of water between the glass and the seal, but I wash my cars with a pressure washer (from a couple of feet away). It's not enough water to drip down the glass or get into the interior though. I figure with the frame-less design it's easier for a few drops of water to make it past the seal.
ΜΟΛΩΝ ΛΑΒΕ
04-12-2024, 11:08 AM | #5 | |
Speaking of pressure washer, what pressure do you use, and what methods do you use to dry? Last year I tried the leaf blower method and it took a comically long time and I kept getting worried about touching the car with the thing. My wash last weekend I had used some large towels that were suggested to me here, but they smudged a bit. Hoping that wont happen when I wash again, as I gave the towels a nice washing. Hoping to get some ppf on in the next week or two to assist with ease of cleaning.
04-12-2024, 11:12 AM | #6 | |
ΜΟΛΩΝ ΛΑΒΕ
04-12-2024, 11:17 AM | #7 | |
How long would it typically take you to dry?
04-12-2024, 11:22 AM | #8 | |
I use an older Toro handheld blower that honestly was too weak for leaf blowing. But it's great for drying cars. What I did was wrap the end in several layers of electrical tape just in case I accidentally touch the paint. It probably takes me a good 15-20 minutes to completely dry the car. I can probably towel dry it in half that time.
ΜΟΛΩΝ ΛΑΒΕ
04-12-2024, 11:28 AM | #9 | |
15mins or so isn't bad at all, and that electrical tape move is a great idea. Much appreciated! Hoping when I get my PPF on that they do a good job of clay barring it and cleaning up some of the clear coat issues that have been present since I picked it up from the dealership. Those sons of guns upset me many times, and added swirls and scuffs to my paint in multiple areas, among other things.
04-14-2024, 08:58 PM | #10 |
Drives: 2022 SS 1LE Join Date: Aug 2023
I use a leaf blower just to blow off larger accumulations of water before I go in with a high-quality drying towel. Then I finish off with an Adam's Handheld Mini Air Cannon. It was a game changer for me and does wonders on the mirrors, grills, around lights, spoiler, wheels, etc. It's my favorite detailing tool.
https://adamspolishes.com/products/a...hoCsr0QAvD_BwE |
04-15-2024, 05:59 AM | #11 | |
Would you say that, functionally, the Adams is worth the price versus using an air compressor with narrow tips? I use that on my headlights, seals, etc. |
04-15-2024, 05:12 PM | #12 |
That's a good question, but I think so. I think the pattern of air is a little wider than the nozzle I have for my air hose. I also don't know for sure, but I feel like with my 25gal tank I have might actually have to stop and let it refill once or twice for the amount of air I use. So overall, I guess it kind of depends on your person set up.
Thread Tools | |
