#29 | ||
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
#30 | |
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
, both the systems they compared are just about low cost. A dynamic tensioner is a must and the tensioner system must have enough travel to absorb the amount of belt stretch that occurs at max load. Any system with a manual tensioner will have problems.It's also amazing to see how far technology has come over the last few years, they were running 12psi on a pretty well worked over 366ci engine (certainty not CARB approved) to get essentially the same power that was posted earlier with a completely stock LT1 and only 7.5psi of boost. |
#31 | |
| Thread Tools | |
